Hallo liebe Manjaro user ,
Bräuche eure Unterstützung mein Manjaro Cinammon ist allgemein langsam geworden , extrem merkt man das beim öffnen libre office writer Dokumenten, muss über eine Minute warten bis es sich öffnet ,
hier Systemdaten :
[user@user-lenovoc325 ~]$ lsb_release -sirc
ManjaroLinux 23.0.3 Uranos
[user@user-lenovoc325 ~]$ inxi -v7azy
Kernel: 5.10.197-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=c3aa409d-dea4-41da-a8ca-1bd2c3155a59 rw quiet apparmor=1
Desktop: Cinnamon v: 5.8.4 tk: GTK v: 3.24.38 vt: 7 dm: LightDM v: 1.32.0
Type: Desktop System: LENOVO product: Lenovo C325 v: Lenovo Product
serial: <superuser required>
Mobo: LENOVO model: Inagua CRB serial: <superuser required> BIOS: LENOVO
v: E3KT17AUS date: 07/06/2011
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M185
status: discharging
System RAM: total: 8 GiB note: est. available: 9.23 GiB
used: 2.75 GiB (29.8%)
Info: model: AMD E-450 APU with Radeon HD Graphics bits: 64 type: MCP
arch: Bobcat level: v1 built: 2011-13 process: GF 40nm family: 0x14 (20)
model-id: 2 stepping: 0 microcode: 0x5000119
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 1024 KiB desc: 2x512 KiB
Speed (MHz): avg: 841 high: 858 min/max: 825/1650 boost: disabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 824 2: 858 bogomips: 6588
Flags: 3dnowprefetch abm aperfmperf apic arat clflush cmov cmp_legacy
constant_tsc cpuid cr8_legacy cx16 cx8 de extapic extd_apicid fpu fxsr
fxsr_opt ht hw_pstate ibs lahf_lm lbrv lm mca mce misalignsse mmx mmxext
monitor msr mtrr nonstop_tsc nopl npt nrip_save nx pae pat pausefilter
pdpe1gb pge pni popcnt pse pse36 rdtscp rep_good sep skinit sse sse2 sse4a
ssse3 svm svm_lock syscall tsc vme vmmcall wdt
Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: AMD Wrestler [Radeon HD 6320] vendor: Lenovo driver: radeon
v: kernel arch: TeraScale-2 code: Evergreen process: TSMC 32-40nm
built: 2009-15 ports: active: VGA-1 empty: HDMI-A-1 bus-ID: 00:01.0
chip-ID: 1002:9806 class-ID: 0300
Device-2: Z-Star Micro Lenovo IdeaCentre Web Camera
driver: snd-usb-audio,uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
mode: 2.0 bus-ID: 2-5:2 chip-ID: 0ac8:c412 class-ID: 0102
Display: x11 server: X.Org v: 21.1.8 driver: X: loaded: radeon
unloaded: modesetting alternate: fbdev,vesa dri: r600 gpu: radeon
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.65x9.37")
s-diag: 485mm (19.11")
Monitor-1: VGA-1 mapped: VGA-0 model: Lenovo AIO serial: <filter>
built: 2011 res: 1600x900 hz: 60 dpi: 99 gamma: 1
size: 410x230mm (16.14x9.06") diag: 506mm (19.9") ratio: 16:9, 15:9 modes:
max: 1600x900 min: 720x400
API: OpenGL Message: Unable to show GL data. glxinfo is missing.
Device-1: AMD SBx00 Azalia vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 00:14.2 chip-ID: 1002:4383 class-ID: 0403
API: ALSA v: k5.10.197-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.80 status: off tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl,pavucontrol
Device-1: Realtek RTL8188CE 802.11b/g/n WiFi Adapter driver: rtl8192ce
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0
chip-ID: 10ec:8176 class-ID: 0280
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: down mac: <filter>
Local Storage: total: 465.76 GiB used: 46.86 GiB (10.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST3500413AS
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: JC66 scheme: MBR
Optical-1: /dev/sr0 vendor: PLDS model: DVD-RW DS8A5SH rev: XL32
dev-links: cdrom
Features: speed: 6 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 50 GiB size: 48.91 GiB (97.83%) used: 45.5 GiB (93.0%)
fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: c3aa409d-dea4-41da-a8ca-1bd2c3155a59
ID-2: /home raw-size: 50 GiB size: 48.91 GiB (97.83%) used: 1.36 GiB (2.8%)
fs: ext4 dev: /dev/sda6 maj-min: 8:6 label: N/A
uuid: 7a3ebf06-2e45-4074-b152-72e03db87df5
ID-1: /dev/sda1 maj-min: 8:1 size: 100 GiB fs: ntfs label: win10
uuid: 4D96AF5E5B173DF2
ID-2: /dev/sda2 maj-min: 8:2 size: 10 GiB fs: swap label: N/A
uuid: dedf5037-d8fe-4345-889d-84eddab49a02
ID-3: /dev/sda3 maj-min: 8:3 size: 150 GiB fs: ntfs label: Datensicherung
uuid: 724C7490229E75A5
ID-4: /dev/sda4 maj-min: 8:4 size: 1 KiB fs: <superuser required>
label: N/A uuid: N/A
ID-5: /dev/sda7 maj-min: 8:7 size: 50 GiB fs: ext4 label: N/A
uuid: ece94f94-8638-4ba8-a171-bdc6ca400929
ID-6: /dev/sda8 maj-min: 8:8 size: 55.76 GiB fs: ext4 label: N/A
uuid: f59ec2ef-7b35-403f-b52e-e9532b1ff050
Hub-1: 1-0:1 info: full speed or root hub ports: 5 rev: 2.0
Hub-2: 2-0:1 info: full speed or root hub ports: 5 rev: 2.0
Device-1: 2-5:2 info: Z-Star Micro Lenovo IdeaCentre Web Camera
type: video,audio driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.0
Hub-3: 3-0:1 info: full speed or root hub ports: 4 rev: 2.0
Hub-4: 4-0:1 info: full speed or root hub ports: 5 rev: 1.1
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 1d6b:0001
Device-1: 4-2:2 info: Novatek Micro Keyboard (Labtec Ultra Flat Keyboard)
type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 1.1
chip-ID: 0603:00f2 class-ID: 0300
Device-2: 4-3:3 info: Logitech Unifying Receiver type: mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
chip-ID: 046d:c52f class-ID: 0300
Hub-5: 5-0:1 info: full speed or root hub ports: 5 rev: 1.1
Hub-6: 6-0:1 info: full speed or root hub ports: 2 rev: 1.1
Hub-7: 7-0:1 info: full speed or root hub ports: 4 rev: 1.1
System Temperatures: cpu: 55.0 C mobo: N/A gpu: radeon temp: 56.0 C
Fan Speeds (rpm): N/A
Processes: 182 Uptime: 18m wakeups: 4 Init: systemd v: 254 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: pm: pacman
pkgs: 1267 libs: 391 tools: pamac,yay pm: flatpak pkgs: 0 Shell: Bash
v: 5.1.16 running-in: gnome-terminal inxi: 3.3.30
[user@user-lenovoc325 ~]$ LANG=C lscpu
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Address sizes: 36 bits physical, 48 bits virtual
Byte Order: Little Endian
CPU(s): 2
On-line CPU(s) list: 0,1
Vendor ID: AuthenticAMD
Model name: AMD E-450 APU with Radeon(tm) HD Graphics
CPU family: 20
Model: 2
Thread(s) per core: 1
Core(s) per socket: 2
Socket(s): 1
Stepping: 0
CPU(s) scaling MHz: 50%
CPU max MHz: 1650,0000
CPU min MHz: 825,0000
BogoMIPS: 3294,30
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mc
a cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall n
x mmxext fxsr_opt pdpe1gb rdtscp lm constant_tsc rep_go
od nopl nonstop_tsc cpuid extd_apicid aperfmperf pni mo
nitor ssse3 cx16 popcnt lahf_lm cmp_legacy svm extapic
cr8_legacy abm sse4a misalignsse 3dnowprefetch ibs skin
it wdt hw_pstate vmmcall arat npt lbrv svm_lock nrip_sa
ve pausefilter
Virtualization features:
Virtualization: AMD-V
Caches (sum of all):
L1d: 64 KiB (2 instances)
L1i: 64 KiB (2 instances)
L2: 1 MiB (2 instances)
NUMA:
NUMA node(s): 1
NUMA node0 CPU(s): 0,1
Gather data sampling: Not affected
Itlb multihit: Not affected
L1tf: Not affected
Mds: Not affected
Meltdown: Not affected
Mmio stale data: Not affected
Retbleed: Not affected
Spec rstack overflow: Not affected
Spec store bypass: Vulnerable
Spectre v1: Mitigation; usercopy/swapgs barriers and __user pointer
Spectre v2: Mitigation; Retpolines, STIBP disabled, RSB filling, PB
RSB-eIBRS Not affected
Srbds: Not affected
Tsx async abort: Not affected
[user@user-lenovoc325 ~]$ mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
[user@user-lenovoc325 ~]$ mhwd-kernel -li
Currently running: 5.10.197-1-MANJARO (linux510)
* linux510
[user@user-lenovoc325 ~]$ lsblk -fa
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
loop0
sda
├─sda1 ntfs win10 4D96AF5E5B173DF2
├─sda2 swap 1 dedf5037-d8fe-4345-889d-84eddab49a02
├─sda3 ntfs Datensicherung 724C7490229E75A5
├─sda4
├─sda5 ext4 1.0 c3aa409d-dea4-41da-a8ca-1bd2c3155a59 915,5M 93% /
├─sda6 ext4 1.0 7a3ebf06-2e45-4074-b152-72e03db87df5 45G 3% /home
├─sda7 ext4 1.0 ece94f94-8638-4ba8-a171-bdc6ca400929
└─sda8 ext4 1.0 f59ec2ef-7b35-403f-b52e-e9532b1ff050
sr0
[user@user-lenovoc325 ~]$ LANG=C sudo parted -l
[sudo] password for user:
Model: ATA ST3500413AS (scsi)
Disk /dev/sda: 500GB
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
1 1049kB 107GB 107GB primary ntfs
2 107GB 118GB 10,7GB primary linux-swap(v1) swap
3 118GB 279GB 161GB primary ntfs
4 279GB 500GB 221GB extended
5 279GB 333GB 53,7GB logical ext4
6 333GB 387GB 53,7GB logical ext4
7 387GB 440GB 53,7GB logical ext4 boot
8 440GB 500GB 59,9GB logical ext4
[user@user-lenovoc325 ~]$ free
gesamt benutzt frei gemns. Puffer/Cache verfügbar
Speicher: 9451 2845 5340 18 1558 6605
Swap: 0 0 0
[user@user-lenovoc325 ~]$ LANG=C df -h
Filesystem Size Used Avail Use% Mounted on
dev 4,7G 0 4,7G 0% /dev
run 4,7G 1,5M 4,7G 1% /run
/dev/sda5 49G 46G 916M 99% /
tmpfs 4,7G 0 4,7G 0% /dev/shm
tmpfs 4,7G 120K 4,7G 1% /tmp
/dev/sda6 49G 1,4G 46G 3% /home
tmpfs 946M 156K 946M 1% /run/user/1000
[user@user-lenovoc325 ~]$ df -h
Dateisystem Größe Benutzt Verf. Verw% Eingehängt auf
