It appears that the source code is not compatible with ffmpeg5. The PKGBUILD on the AUR should be updated (and potentially others changes are also needed). Others have noticed it too, see the comments: AUR (en) - libquicktime
but I may be mistaken - I don’t know what the output looks like when some package is in the ignore list - I have never done that.
libquicktime is marked as “orphan” and there are comments about this on the AUR page:
dvzrv commented on 2022-03-14 11:03 (UTC)
Yes, this package needs to be fixed to work with ffmpeg4.4 or ffmpeg 5. Either way, libquicktime’s upstream is dead. Feel free to adopt this package and fix it.
Consider what you need it for
or what other package needs it
and perhaps replace with something else from the regular repo?
in the build file(s) - there’s a few that are called “ffmpeg”. I have no idea what I’m looking at. I have not looked at text like this since when QB45 was new and actively being used Can you hold my hand (tell me exactly how to make it build?)
# Maintainer: David Runge <dvzrv@archlinux.org>
# Contributor: Federico Cinelli <cinelli@aur.archlinux.org>
# Contributor: Mateusz Herych <heniekk@gmail.com>
pkgname=libquicktime
_commit='27295919b3a1036ba8bc06cec414dcc501f72d89'
pkgver=1.2.4
pkgrel=26
pkgdesc="A library for reading and writing quicktime files"
arch=(x86_64)
license=(LGPL2.1)
url="http://libquicktime.sourceforge.net/"
depends=(glib2 glibc zlib)
# NOTE: not compatible with ffmpeg >= 5, so switch to ffmpeg4.4 or remove
makedepends=(alsa-lib doxygen faac faad2 ffmpeg git gtk2 lame libdv libglvnd
libjpeg-turbo libvorbis libx11 libxaw libxext libxt libxv schroedinger sndio
x264)
optdepends=('alsa-lib: for lqtplay'
'faac: for lqt_faac plugin'
'ffmpeg: for lqt_ffmpeg plugin'
'gtk2: for libquicktime_config'
'lame: for lqt_lame plugin'
'libdv: for lqt_dv plugin'
'libglvnd: for lqtplay'
'libjpeg-turbo: for lqt_mjpeg plugin'
'libpng: for lqt_png plugin'
'libvorbis: for lqt_lame and lqt_vorbis plugin'
'libx11: for lqtplay'
'libxaw: for lqtplay'
'libxext: for lqtplay'
'libxt: for lqtplay'
'libxv: for lqtplay'
'schroedinger: for lqt_schroedinger plugin'
'sndio: for lqtplay'
'x264: for lqt_x264 plugin')
provides=(libquicktime.so)
options=(!lto)
source=(
"https://downloads.sourceforge.net/sourceforge/$pkgname/$pkgname-$pkgver.tar.gz"
"${pkgname}-1.2.4-CVE-2016-2399.patch"
"${pkgname}-1.2.4-CVE-2017-9122_et_al.patch"
"${pkgname}-1.2.4-faad2.patch"
"${pkgname}-1.2.4-ffmpeg2.patch"
"${pkgname}-1.2.4-ffmpeg29.patch"
"${pkgname}-1.2.4-ffmpeg4.patch"
"${pkgname}-1.2.4-ffmpeg-codecs.patch"
"${pkgname}-1.2.4-libavutil.patch"
sha512sums=('6ab6cd62ae2361bb3ad73725e9e8baa2b03361bc23e9e34b24f90c0e2bec4337de950ed7f30a6a1d2e67ab33e8f0c43538369fd07e417f54b84583a3c331f8dd'
'759fee13bc96db036063efcd8288c0e467ce811b597cf6c0ceed1c8927593963174f4f3324512db0e773e936a4b9fe5c8d8fc9e0f00b2ce59110661175986f9c'
'93639d3fe12eefddd1b457be702ec0a4a64a73c44fce6b3134e50bb9a4e7e5f25d256d3ace6ec5e774f2db4c0d68725f3e35e901f7d932a4be9cba566eab528e'
'3e751330ebbc4026363efd45b21c60c313ea169a57a5cdfa46125e126aab34c2dea3629ce92e7b0b5f14693db4f11723177fd28611e2e979cc8fcd506077509e'
'32ddf394aad4ed80e89ec72a534e0466268ab0061b991815e905b78eae55a7d935117b0915faf6f7f51bd7e2d9fbaa4b0e07bfcef1ef1e2f4a7e2061c489122d'
'2a7e06c03b0f64f02b923c1a0e7121f4e1ea735f19a6df8ce8daf18177ead132d1ae921c64f3770042db3bbf29f15a7fcceece835d475e052c4c3bb7139c9e2e'
'1b11a82d694654976a5f79cd8feb27eec3810e09a66dc58ca576eaf1f96e4948abd4dae7955a7da6cf99ae6ffef9e183b39090d96cc6b5fe216b4c4f4faff7a8'
'20c535444de1f3e9a68c35ee4eb409f150e6340fd43dda4544791454f42c031b24c08f651e0351f5a22dcb59459ac372aa70d82a1d20482b2d997589e19087fd'
'691110dc18f6646e2e17f40c6a42911a6b8eaa8cea20b5595f20d218d51da11d11923a3001b7ad7c3ad6bd0d90e712b95ccee5526fa1bec176cd27813e4a775e')
b2sums=('6c50965be5d19fb4c57ea6b36f2581ebd575d78a34f2df7029ce2c6ee560e8135a953a2e85d91d189e2c01b97c99804d0eab602866b88a5f07c36351174680f0'
'2794d13a0afa8a948f8f1335d7ee0a3d75691bbb9c619716707f533f52e8a8826c4a883b25db2ad8fb6544ce8b7c0fa883158b110c10b896e124b6ade9d18945'
'8d5be1d1a297d89da1256035042a9760227815b8e73cb994b04b3ac4a2d7b83f79625bb62dc89266ac2f3eebd4cb033c8eb66388aca6097f4dbcc86d919dbd72'
'175a32d051c438d59f428fb5a5d082e267f5503d9ff5ecded8302b74278f0bd1d0c5680161c1dd99089a116f9617fb37cdc697115979c5901c88e201ab221039'
'1db6a761fa94a32741a05919d12d0211964647a61ffd32ba8619530ec089c980999aa1ded534c2652eb3baf15558bcb9842a23634eeef043a6ed3eb3f8e794ff'
'8a1e7b5df65f5297f59aa17c4a52706413c1ffd88d8645de7359ec26f7059101ab81ac135cf7ef707a8acbeb709e1a6dae03d6a7e7f70c7e88185ebb271acbe4'
'bd1299c24b738b3752e4d8d50ed1b2fa2f208c83e577876118d115fca22293e102614ae0cdc168060115f7145d951d290bccf21154fda4aabf55329d310b6aca'
'e770000ea0c39f77bc36e7e5252e281b9f9d06a136c655cd702332cc8581f128263e172e41eab3b7ce2543da7065d8efc28c048588e577db5ee6ec4bfeb1019b'
'0a29c9a3d1eae31731b76536a22aa23a4888b8ac55c3176c60a152330fce37e8031a4269fa28026133c7061cd769b1428bf24fe59fed574e39d52ea00b6e00a0')
prepare() {
cd "$pkgname-$pkgver"
# boatload of CVEs: http://cve.mitre.org/cgi-bin/cvekey.cgi?keyword=libquicktime
patch -Np1 -i "../${pkgname}-1.2.4-CVE-2016-2399.patch"
patch -Np1 -i "../${pkgname}-1.2.4-CVE-2017-9122_et_al.patch"
# checks for faad2 are broken in configure.ac
patch -Np1 -i "../${pkgname}-1.2.4-faad2.patch"
# ffmpeg compatibility is very ancient
patch -Np1 -i "../${pkgname}-1.2.4-ffmpeg2.patch"
patch -Np1 -i "../${pkgname}-1.2.4-ffmpeg29.patch"
patch -Np1 -i "../${pkgname}-1.2.4-ffmpeg4.patch"
patch -Np1 -i "../${pkgname}-1.2.4-libavutil.patch"
patch -Np1 -i "../${pkgname}-1.2.4-ffmpeg-codecs.patch"
autoreconf -fiv
build() {
cd $pkgname-$pkgver
./configure \
--prefix=/usr \
--enable-gpl \
--with-faac \
--with-ffmpeg \
--with-libdv \
--with-x264 \
--without-doxygen
# prevent excessive overlinking due to libtool
sed -i -e 's/ -shared / -Wl,-O1,--as-needed\0/g' libtool
make
package() {
depends+=(libfaad.so)
cd $pkgname-$pkgver
make DESTDIR="$pkgdir" install
install -vDm 644 {AUTHORS,ChangeLog,README,TODO} -t "${pkgdir}/usr/share/doc/${pkgname}"
I updated today to my surprise it worked, and found this post! Thank you!
Also, thank you for explaining where to put something like this. I’ll refer back to this post in the future to try and learn how to edit the package and maybe one day adopt a package. I just don’t know how to do this stuff yet. I only started building packages and roms with success in the last few years, but only following instructions and if it doesn’t work out the box often stuck. One day maybe!
