Libplacebo conflict
I get an error when I try to update my system :
sudo pacman -Su
:: Starting full system upgrade…
resolving dependencies…
:: installing libplacebo (3.104.0-1) breaks dependency ‘libplacebo.so=72-64’ required by mpv
pamac update
Warning: installing libplacebo (3.104.0-1) breaks dependency ‘libplacebo.so=72-64’ required by mpv
Add mpv to remove
Error: Failed to prepare transaction:
could not satisfy dependencies:
  • removing mpv breaks dependency ‘mpv’ required by smplayer,
  • if possible, remove smplayer and retry
    Resolving dependencies…
    Checking inter-conflicts…
sudo pacman-mirrors -f5 && sudo pacman -Syyu
How did you get that version?
It’s a good question… I didn’t do anything special to get it :
https://manjaro.mcofficer.me/arm-unstable/extra/aarch64/libplacebo-3.104.0-1-aarch64.pkg.tar.xz
Ok, managed to reproduce the issue.
@Strit - is something here i misunderstood? Even trying to install smplayer fresh, i get the same conflict error. Thanks!
Both mpv and libplacebo are packages we get from Arch ARM.
It seems a rebuild of mpv is in Arch comnmunity-staging to fix this issue:
https://archlinux.org/packages/community-staging/x86_64/mpv/
I just hit this today with today’s new arm-testing update.
I should sync to arm-staging to get past this? Or maybe you will push this update to testing and I should just try the update later today?
It’s still not in Arch ARM…
Now it does and I could update correctly. Thanks !
I rebuilt mpv with the new libplacebo library in both unstable and testing branches.
