Hi,
Since a few days, to get my touchpad working “properly” (speed and natural scrolling) I have to log out/log in after every single reboot.
Right after a reboot, the touchpad is slow & without natural scrolling, but after logging out / logging in it’s as fast as I wanted with natural scrolling
Here’s the output of xinput
<lucas> ~ % ~> xinput
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ Logitech Wireless Mouse id=10 [slave pointer (2)]
⎜ ↳ SYNA2393:00 06CB:7A13 Mouse id=12 [slave pointer (2)]
⎜ ↳ SYNA2393:00 06CB:7A13 Touchpad id=13 [slave pointer (2)]
⎜ ↳ SynPS/2 Synaptics TouchPad id=18 [slave pointer (2)]
After looking at input properties and more specifically the Natural scrolling property :
<lucas> ~ % ~> xinput list-props 13
Device 'SYNA2393:00 06CB:7A13 Touchpad':
Device Enabled (196): 1
Coordinate Transformation Matrix (198): 1.000000, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000, 0.000000, 0.000000, 1.000000
libinput Natural Scrolling Enabled (333): 1
libinput Natural Scrolling Enabled Default (334): 0
and
<lucas> ~ % ~> xinput list-props 18
Device 'SynPS/2 Synaptics TouchPad':
libinput Natural Scrolling Enabled (333): 0
I saw that SynPS/2 doesn’t have natural scrolling enabled and if I try to enable by default it I get this output (I get the same when I do it with the other one [id=13]):
<lucas> ~ % ~> sudo xinput set-prop 18 334 1
X Error of failed request: BadAccess (attempt to access private resource denied)
Major opcode of failed request: 131 (XInputExtension)
Minor opcode of failed request: 57 ()
Serial number of failed request: 20
Current serial number in output stream: 21
Though xinput set-prop 18 333 1 enable Natural scrolling for SynPS/2, the pointer is still slow until I log out / log in. I can changed any setting (in Settings > Input devices > Touchpad) and then apply, it won’t do anything (which is why I think of a second “profile”)
After a log out / log in after rebooting, I get other settings (the ones I set) and then any modification (acceleration, natural scrolling) takes affect right after applying
The only thing I do to get my settings back is logging out then logging (not rebooting)
This are my Xorg confs
<lucas> /etc/X11 % ~> ls
tigervnc xinit xorg.conf.d
<lucas> /etc/X11 % ~> ls xorg.conf.d
00-keyboard.conf 30-touchpad.conf
<lucas> /etc/X11 % ~> cat xorg.conf.d/30-touchpad.conf
Section "InputClass"
Identifier "touchpad"
Driver "libinput"
MatchIsTouchpad "on"
Option "Tapping" "on"
EndSection
And here is my inxi
<lucas> ~ % ~> inxi -Fazy
Kernel: 5.8.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=1884314f-01c5-450d-9611-ea5b7efa5247 rw mem_sleep_default=deep
Desktop: KDE Plasma 5.20.3 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: Dell product: XPS 15 7590 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 0VYV0G v: A00 serial: <filter> UEFI: Dell v: 1.8.1
date: 07/03/2020
ID-1: BAT0 charge: 95.9 Wh condition: 95.9/97.0 Wh (99%) volts: 12.9/11.4
model: LGC-LGC8.33 DELL 5XJ2809 type: Li-ion serial: <filter> status: Full
Info: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 9E (158) stepping: A (10) microcode: DE
L2 cache: 12.0 MiB
bogomips: 62431
Speed: 800 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
Type: l1tf
Device-1: Intel UHD Graphics 630 vendor: Dell driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:3e9b
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Dell
driver: nvidia v: 455.45.01 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:1f91
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus ID: 1-12:5 chip ID: 0c45:6d13
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11
driver: modesetting,nvidia unloaded: intel alternate: fbdev,nouveau,nv,vesa
display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.2.2
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3
chip ID: 8086:a348
Sound Server: ALSA v: k5.8.18-1-MANJARO
Device-1: Intel Wi-Fi 6 AX200 vendor: Bigfoot Networks driver: iwlwifi
v: kernel port: 3000 bus ID: 3b:00.0 chip ID: 8086:2723
IF: wlp59s0 state: up mac: <filter>
Local Storage: total: 953.87 GiB used: 97.91 GiB (10.3%)
ID-1: /dev/nvme0n1 vendor: SK Hynix model: PC611 NVMe 1TB size: 953.87 GiB
block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
serial: <filter> rev: 11001111 scheme: GPT
ID-1: / raw size: 467.46 GiB size: 459.13 GiB (98.22%)
used: 97.82 GiB (21.3%) fs: ext4 dev: /dev/nvme0n1p7
System Temperatures: cpu: 47.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2428 fan-2: 2394
Processes: 311 Uptime: 6h 50m Memory: 15.28 GiB used: 3.06 GiB (20.1%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 11.0.0 Packages:
pacman: 5863 lib: 446 rpm: 0 flatpak: 0 Shell: Zsh v: 5.8
running in: konsole inxi: 3.1.08
If anyone has an idea of how I can “delete” this “second” profile of touchpad, I’ll be very thankful. In the
meantime, i’ll stick to logging out and logging in
