I installed those two packages and tried to make some gestures,
I wanted to make 2 fingers swipe left make go back
I wrote this line:
gesture: swipe left 2 xdotool key alt+Left
But it does not work ; (
I am sure that this packages are work because I add following line to config
gesture: swipe right 3 xdotool key super+ctrl+Right
gesture: swipe left 3 xdotool key super+ctrl+Left
and they work well, also after following command:
libinput-gestures-setup restart && libinput-gestures-setup status
I see libinput-gestures is running message
I also wanted to make that 3 finger swipe down change brightness to 0 and for up increase by 10, how can I do it by command not by simulate pressing key.
I’m afraid I don’t know about that… I guess there are some mechanisms in xdotool to debug and intercept keyboard shortcuts like the ones you use normally to decrease increase brightness
It depends on what software is installed on your machine. Maybe the software you use right now to manage the brightness has a D-bus API which can be easily invoked to set the brightness to zero.
xbacklight is in the xorg-xbacklight package, acpilight is also in the official repositories. Those programs which are marked “AUR”, are in the AUR.
