I’m trying to run a program and I get the below error. I found an old forum post saying to install mesa-amber, which I have done but the error was not resolved. Is there anything else I am missing?
This is an older computer with a Intel Core 2 Duo E6750 (2) @ 2.667GHz CPU and Intel 82Q35 Express integrated graphics.
libGL error: MESA-LOADER: failed to open i915: /usr/lib32/dri/i915_dri.so: cannot open shared object file: No such file or directory (search paths /usr/lib32/dri, suffix _dri)
libGL error: failed to load driver: i915
Thank you - I installed that package and the error has now changed.
sudo pacman -S lib32-mesa-amber
Do you know what this means?
X Error of failed request: BadDrawable (invalid Pixmap or Window parameter)
Major opcode of failed request: 155 ()
Minor opcode of failed request: 4
Resource id in failed request: 0x4200006
Serial number of failed request: 246
Current serial number in output stream: 246
Thanks for your posts. I have a different error now but it’s an error stack in the program so it’s probably something in the app itself. I’ll reach out to the developer and see if this is a defect or if they know of a solution.
