For the first time error, it has failed to install packages, because of this error:
(357/357) checking for file conflicts [###############################################] 100%
error: failed to commit transaction (conflicting files)
vlc: /usr/lib/vlc/plugins/codec/libfluidsynth_plugin.so exists in filesystem (owned by vlc-plugin-fluidsynth-bin)
Please, what is the correct sequence of operations? Should FluidSynth be uninstalled first?
Probably was a good idea at many points, as this is not only an unsupported package (not in the repos) … its an old ghost … it doesnt exist even in the AUR.
sudo pacman -Rns vlc-plugin-fluidsynth-bin
In the future … try to stay on top of your packages … especially if they are third party. Even if they dont need to be removed, they may need to be rebuilt, etc. And as they are third-party … its all your responsibility.
