Hi, I am using manajro for a couple of years.
I have earlier used virt-manager but this time it gave error
[gunit@gunit ~]$ virt-manager
File "/usr/bin/virt-manager", line 6, in <module>
from virtManager import virtmanager
File "/usr/share/virt-manager/virtManager/virtmanager.py", line 15, in <module>
import gi
File "/usr/lib/python3.9/site-packages/gi/__init__.py", line 40, in <module>
from . import _gi
ImportError: libffi.so.8: cannot open shared object file: No such file or directory
and i recently added arco linux repo to pacman and added variety and it also gave same error and even clang3.5.1 which i added to build unreal gave error
libffi.so.6: cannot open shared object file: No such file or directory
That’s cause – libffi package in Arch/Acrolinux repos provide libffi.so.8 while in Manjaro repos it’s libffi.so.7. You should remove Acrolinux repo and downgrade packages which are newer than in Manjaro repos.
I already have many package of arcolinux like vscode and themes and other dev tools so i cant remove it but i updated libffi and now its libffi.so.7 error and not only for virt-manager but for all other apps
and downgrading to its previous version gives same error i can now alteast run other apps
If the variety package from Arcolinux contains configurations/customisations that you like:
you now have that package in your cache - just extract the configuration files and use it/them with the variety that comes from Manjaro repo which does not contain ready made configuration files?
edit:
I just had a look at the variety packages from Arcolinux:
So you should install and use Acrolinux instead of Manjaro. You can wait for update or move to testing or unstable branch which should have already required version. But if you want to stay on stable branch, you should be aware that this problem may return from time to time (that may be also on testing or unstable, but you receive update faster). There is no other solutions for it if you don’t want to resign Acrolinux repos
ok ok i will remove arcolinux repo and try sudo pacman -Syu
it gave warning: libffi: ignoring package upgrade (3.3-4 => 3.4.2-4) resolving dependencies... warning: ignoring package libffi-3.4.2-4 warning: cannot resolve "libffi.so=8-64", a dependency of "glib2" warning: ignoring package libffi-3.4.2-4
what should i do now i skiped it as it gave error on upgrading libffi
[gunit@gunit ~]$ sudo pacman -Syuu
:: The following package cannot be upgraded due to unresolvable dependencies:
glib2
:: Do you want to skip the above package for this upgrade? [y/N] n
:: unable to satisfy dependency 'libffi.so=8-64' required by glib2
using yay to update it to 3.4.2 worked but then all apps gave error libffi.so.7 no such file or directory
can you help to solve this problem too [gunit@gunit ~]$ clang --version clang: error while loading shared libraries: libffi.so.6: cannot open shared object file: No such file or directory
i edited pacman, extra to download clang3.5.1 and then this error came
I’d have to try myself to see what happens - and then potentially troubleshoot
but I’m not going to …
I do remember having seen (rather recently) issues about building the unreal engine here on this very forum - just a couple of days ago.
Try to locate these and see if what is said there helps.
Yeah definitely it takes a day just to compile and download this massive 100gigs editor but i am building a very older version 4.10 and latest is 4.27 and on ubuntu clang works fine so i will just use live usb but thanks for your help
