Hi,
Short story: what could be the Manjaro package for networking support for 32bit binaries?
Long story:
I’ve been trying to install Uppaal on my machine
Long story short, it doesn’t work, but I’ve been able to trace some possible cause back to this error to a missing dependency, which shows up for instance when doing ls
in the directory of the Uppaal server program:
ls: libc.so.6: version `GLIBC_2.34' not found (required by ls)
It is said in the UPPAAL documentation that:
On 64bit Linux host, install 32bit libc
library to enable networking support for 32bit binaries, e.g. sudo apt-get install libc6:i386
(you may need to enable i386 architecture in /etc/apt/sources.list
, sudo apt-get update
and then sudo apt-get install libc6:i386
How can I install such package on Manjaro?
I’ve googled the package but to no avail: I saw that lib32-glibc could be the equivalent and I installed it, but i’ve still got the same error
Has anyone installed Uppaal on Manjaro, or knows what kind of package could solve the problem?
