libarpack.so is present in arpack (from community repo) but there isn’t a library for arpack++. Can I copy the library “libarpack.so” from arpack to the folder where arpack++ is installed? So this way I just need to change his name and this wont happen:
-- Found Arpack++ lib: ARPACKPP_LIB-NOTFOUND
pkgfile libarpack++.so shows there is not package actually using this library
How can I make libraries given hearder files (.h)?
After I installed arpack++ from AUR I copied the missing files (.so and .a files) from ubuntu repo (I got them using a container) into a path /usr/lib
Im not sure it will work
FindArpackPP.make
# XC program; finite element analysis code
# for structural analysis and design.
# Copyright (C) Luis C. Pérez Tato
# Except for the restrictions that may arise from the copyright
# of the original program (see copyright below if any)
# XC is free software: you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation, either version 3 of the License, or
# (at your option) any later version.
# This software is distributed in the hope that it will be useful, but
# WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program.
# If not, see <http:// www.gnu.org/licenses/>.
# ARPACKPP
# Once done, this will define
# ARPACKPP_FOUND - system has libf2c
# ARPACKPP_INCLUDE_DIR - the libf2c include directories
# ARPACKPP_LIBRARY - link these to use libf2c
SET(ARPACKPP_SEARCH_PATHS ${CMAKE_SOURCE_DIR} /usr/include/arpack++ /usr/local/include/arpack++)
# Include dir
find_path(ARPACKPP_INCLUDE_DIR NAMES arbnsmat.h PATHS ${ARPACKPP_SEARCH_PATHS})
IF(NOT ARPACKPP_INCLUDE_DIR)
MESSAGE(FATAL_ERROR "arpack++ not found (arbnsmat.h)")
ENDIF()
FIND_LIBRARY(ARPACKPP_LIB NAMES arpack++ PATHS /usr/lib /usr/local/lib)
SET(ARPACKPP_FOUND FALSE)
IF (ARPACKPP_INCLUDE_DIR)
SET(ARPACKPP_FOUND TRUE)
MARK_AS_ADVANCED(ARPACKPP_INCLUDE_DIR)
ENDIF (ARPACKPP_INCLUDE_DIR)
IF (ARPACKPP_FOUND)
MESSAGE(STATUS "Found Arpack++: ${ARPACKPP_INCLUDE_DIR}")
MESSAGE(STATUS "Found Arpack++ lib: ${ARPACKPP_LIB}")
ELSE(ARPACKPP_FOUND)
IF (ARPACKPP_INCLUDE_DIR_REQUIRED)
MESSAGE(FATAL_ERROR "Could not find Arpack++")
ENDIF (ARPACKPP_INCLUDE_DIR_REQUIRED)
ENDIF (ARPACKPP_FOUND)
Looks like arpack++ does not contain a library by default. There is also arpackpp in the AUR, it matches the Debian version, but it provides just the headers. If you compile a application, this should be enough.
You might want to check what source the Debian project uses and try to compile it yourself.
