Lenovo Z13 - Issues with Kernel >5.15
I am trying to get Manjaro up and running on my Lenovo Z13 (AMD Ryzen™ 7 Pro 6850U), but I am facing many Kernel related issues.
Manjaro Live boots up just perfect (Kernel 6.1.9-1) with WLAN and everything running fine.
After installation the Laptop boots up fine aswell, everything running (Kernel 6.1.11).
After rebooting reproducibly, Manjro won’t boot anymore, it gets stuck at the bootscreen with the “three progress dots” keeping animated.
I retried installation several time, and the issue persists.
I installed Kernel 6.0.19 the (6.1.11 removed), and it gets stranger. Bootup still does not work. But I now got to advanced boot and select the Kernel manually (only have 6.0.19 installed) I still gets stuck, but after a reboot Manjaro boots up. This is not working with 6.1.11 and it never successfully boots without going to advanced.
Unfortunatly on Kernel 6.0.19 sleep does not work at all, after resuming from sleep I get a Kernal Panik with blinking caps lock. I also tried hibernate, here it gets stuck at trying to hibernate with black screen and full CPU load.
Next test was Kernel 5.15. Here Manjaro is booting up fine every single time, sleep is working, hibernate is working, but there is a major issue: Wireless LAN (Qualcomm® Wi-Fi 6E NFA725A 11AX) is not supported.
provide full system info:
inxi -zav7
and boot with the 6.1 kernel, then boot with the 5.15 and provide logs from the failed 6.1 boot:
journalctl -b-1 -p4 --no-pager
and use formatting, click this icon in editor: </> and copy the output there
inxi -zav7 (Kernel 6.0.19-4)
  Kernel: 6.0.19-4-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.0-x86_64
    root=UUID=5104c835-2830-4dea-a3fb-fe377f644a42 rw rootflags=subvol=@
    quiet
    cryptdevice=UUID=ea8a3b00-befd-4de3-83e0-6563b15943c4:luks-ea8a3b00-befd-4de3-83e0-6563b15943c4
    root=/dev/mapper/luks-ea8a3b00-befd-4de3-83e0-6563b15943c4 splash
    udev.log_priority=3 resume=UUID=5104c835-2830-4dea-a3fb-fe377f644a42
    resume_offset=3483067
  Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: LENOVO product: 21D2CTO1WW v: ThinkPad Z13 Gen 1
  Mobo: LENOVO model: 21D2CTO1WW serial: <superuser required> UEFI: LENOVO
    v: N3GET47W (1.27 ) date: 12/08/2022
  ID-1: BAT0 charge: 51.1 Wh (99.2%) condition: 51.5/51.5 Wh (100.0%)
    volts: 13.3 min: 11.6 model: Celxpert 5B10W51882 type: Li-poly
    serial: <filter> status: not charging cycles: 2
  RAM: total: 30.63 GiB used: 2.74 GiB (8.9%)
  RAM Report: permissions: Unable to run dmidecode. Root privileges
    required.
  Info: model: AMD Ryzen 7 PRO 6850U with Radeon Graphics bits: 64
    type: MT MCP arch: Zen 3+ gen: 4 level: v3 note: check built: 2022
    process: TSMC n6 (7nm) family: 0x19 (25) model-id: 0x44 (68) stepping: 1
    microcode: 0xA404102
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1114 high: 2667 min/max: 400/4768 boost: enabled
    scaling: driver: amd-pstate governor: schedutil cores: 1: 2665 2: 2171
    3: 400 4: 1181 5: 1486 6: 1166 7: 400 8: 400 9: 1186 10: 1328 11: 400
    12: 400 13: 400 14: 400 15: 2667 16: 1186 bogomips: 86280
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs
    ibs invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext
    monitor movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke
    osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
    perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt pse pse36 rapl
    rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap
    smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm
    svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
    v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
    x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
    STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: AMD Rembrandt [Radeon 680M] vendor: Lenovo driver: amdgpu
    v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22
    pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1,
    DP-2, DP-3, DP-4, DP-5, DP-6, DP-7 bus-ID: 63:00.0 chip-ID: 1002:1681
    class-ID: 0300 temp: 44.0 C
  Device-2: Acer Integrated RGB Camera type: USB driver: uvcvideo
    bus-ID: 5-1:2 chip-ID: 5986:2145 class-ID: fe01 serial: <filter>
  Display: x11 server: X.Org v: 21.1.7 compositor: kwin_x11 driver: X:
    loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
    gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x317mm (20.00x12.48")
    s-diag: 599mm (23.57")
  Monitor-1: eDP-1 mapped: eDP model: AU Optronics 0x1e9b built: 2021
    res: 1920x1200 hz: 60 dpi: 171 gamma: 1.2 size: 286x178mm (11.26x7.01")
    diag: 337mm (13.3") ratio: 16:10 modes: max: 1920x1200 min: 640x480
  API: OpenGL v: 4.6 Mesa 22.3.5 renderer: AMD Radeon Graphics (rembrandt
    LLVM 15.0.7 DRM 3.48 6.0.19-4-MANJARO) direct-render: Yes
  Device-1: AMD Rembrandt Radeon High Definition Audio vendor: Lenovo
    bus-ID: 63:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo
    driver: snd_pci_acp6x v: kernel
    alternate: snd_pci_acp3x,snd_rn_pci_acp3x,snd_pci_acp5x,snd_acp_pci,snd_rpl_pci_acp6x,snd_sof_amd_renoir
    pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 63:00.5 chip-ID: 1022:15e2
    class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 63:00.6
    chip-ID: 1022:15e3 class-ID: 0403
  Sound API: ALSA v: k6.0.19-4-MANJARO running: yes
  Sound Server-3: PipeWire v: 0.3.65 running: yes
  Device-1: Qualcomm QCNFA765 Wireless Network Adapter vendor: Lenovo
    driver: ath11k_pci v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 link-max:
    gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 17cb:1103 class-ID: 0280
  IF-ID-1: wwp99s0f4u1 state: unknown mac: <filter>
  IP v6: <filter> type: noprefixroute scope: global
  Device-1: USI type: USB driver: btusb v: 0.8 bus-ID: 3-2:3
    chip-ID: 10ab:9309 class-ID: e001
  Device-1: luks-ea8a3b00-befd-4de3-83e0-6563b15943c4 maj-min: 254:0
    type: LUKS dm: dm-0 size: 757.45 GiB
  Components:
  p-1: nvme0n1p5 maj-min: 259:5 size: 757.45 GiB
  Local Storage: total: 953.87 GiB used: 63.36 GiB (6.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: MTFDKCD1T0TFK
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 type: SSD serial: <filter> rev: 7003V5LN temp: 33.9 C scheme: GPT
  ID-1: / raw-size: 757.45 GiB size: 757.45 GiB (100.00%)
    used: 63.33 GiB (8.4%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-ea8a3b00-befd-4de3-83e0-6563b15943c4 label: N/A
    uuid: 5104c835-2830-4dea-a3fb-fe377f644a42
    used: 29.5 MiB (30.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: N/A uuid: 9062-FBC1
  ID-3: /home raw-size: 757.45 GiB size: 757.45 GiB (100.00%)
  ID-4: /swap raw-size: 757.45 GiB size: 757.45 GiB (100.00%)
  ID-5: /var/cache raw-size: 757.45 GiB size: 757.45 GiB (100.00%)
  ID-6: /var/log raw-size: 757.45 GiB size: 757.45 GiB (100.00%)
  ID-1: swap-1 type: file size: 50.18 GiB used: 0 KiB (0.0%) priority: -2
    file: /swap/swapfile
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 195.68 GiB fs: ntfs label: N/A
    uuid: 50BC63F8BC63D6CE
  ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 641 MiB fs: ntfs label: N/A
    uuid: 5C08003308000F28
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 3 rev: 2.0
  Device-1: 3-1:2 info: Quectel Wireless Solutions EM05-G
    type: Communication,CDC-Data driver: cdc_mbim,option,option1 interfaces: 3
    rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 2c7c:030a class-ID: 0a00
  Device-2: 3-2:3 info: USI type: Bluetooth driver: btusb interfaces: 2
    rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 10ab:9309 class-ID: e001
  Device-3: 3-3:4 info: Synaptics type: <vendor specific> driver: N/A
    interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 06cb:0123
    class-ID: ff00 serial: <filter>
  Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
  Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
  Device-1: 5-1:2 info: Acer Integrated RGB Camera type: Video
    driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s power: 500mA
  Hub-6: 6-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
    speed: 5 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
  Hub-7: 7-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-8: 8-0:1 info: Super-speed hub ports: 1 rev: 3.1 speed: 10 Gb/s
  Hub-9: 9-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-10: 10-0:1 info: Super-speed hub ports: 1 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 49.0 C mobo: N/A gpu: amdgpu temp: 44.0 C
  Fan Speeds (RPM): fan-1: 2742 fan-2: 2801
  Processes: 354 Uptime: 7m wakeups: 436 Init: systemd v: 252
  default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
  Packages: pm: pacman pkgs: 1118 libs: 319 tools: pamac pm: flatpak pkgs: 0
  Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.25
journalctl -b-1 -p4 --no-pager (Kernel 6.0.19-4)
Feb 13 20:27:27 Z13-Manjaro kernel: TSC synchronization [CPU#0 -> CPU#1]:
Feb 13 20:27:27 Z13-Manjaro kernel: Measured 2960028738 cycles TSC warp between CPUs, turning off TSC clock.
Feb 13 20:27:27 Z13-Manjaro kernel:   #2  #3  #4  #5  #6  #7  #8  #9 #10 #11 #12 #13 #14 #15
Feb 13 20:27:27 Z13-Manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GP17.XHC0.PSTA], AE_ALREADY_EXISTS (20210730/dswload2-326)
Feb 13 20:27:27 Z13-Manjaro kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
Feb 13 20:27:27 Z13-Manjaro kernel: Expanded resource Reserved due to conflict with PCI Bus 0000:00
Feb 13 20:27:27 Z13-Manjaro kernel: pci 0000:00:00.2: can't derive routing for PCI INT A
Feb 13 20:27:27 Z13-Manjaro kernel: pci 0000:00:00.2: PCI INT A: not connected
Feb 13 20:27:27 Z13-Manjaro kernel: ACPI: thermal: [Firmware Bug]: No valid trip found
Feb 13 20:27:27 Z13-Manjaro kernel: Unstable clock detected, switching default tracing clock to "global"
                                    If you want to keep using the local clock, then add:
                                      "trace_clock=local"
                                    on the kernel command line
Feb 13 20:27:27 Z13-Manjaro kernel: usb: port power management may be unreliable
Feb 13 20:27:27 Z13-Manjaro kernel: hub 6-0:1.0: config failed, hub doesn't have any ports! (err -19)
Feb 13 20:27:27 Z13-Manjaro kernel: acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Feb 13 20:27:27 Z13-Manjaro kernel: acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Feb 13 20:27:27 Z13-Manjaro kernel: acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Feb 13 20:27:27 Z13-Manjaro kernel: acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Feb 13 20:27:27 Z13-Manjaro kernel: acpi PNP0C14:05: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Feb 13 20:27:27 Z13-Manjaro kernel: acpi PNP0C14:06: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Feb 13 20:27:28 Z13-Manjaro kernel: kvm: disabled by bios
Feb 13 20:27:28 Z13-Manjaro kernel: pcie_mp2_amd 0000:63:00.7: Failed to discover, sensors not enabled
Feb 13 20:27:28 Z13-Manjaro kernel: pcie_mp2_amd: probe of 0000:63:00.7 failed with error -95
Feb 13 20:27:28 Z13-Manjaro kernel: ath11k_pci 0000:01:00.0: Unsupported WCN6855 SOC hardware version: 18 17
Feb 13 20:27:28 Z13-Manjaro kernel: ath11k_pci: probe of 0000:01:00.0 failed with error -95
Feb 13 20:27:28 Z13-Manjaro bluetoothd[599]: profiles/audio/vcp.c:vcp_init() D-Bus experimental not enabled
Feb 13 20:27:28 Z13-Manjaro bluetoothd[599]: src/plugin.c:plugin_init() Failed to init vcp plugin
Feb 13 20:27:28 Z13-Manjaro bluetoothd[599]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
Feb 13 20:27:28 Z13-Manjaro bluetoothd[599]: src/plugin.c:plugin_init() Failed to init mcp plugin
Feb 13 20:27:28 Z13-Manjaro bluetoothd[599]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
Feb 13 20:27:28 Z13-Manjaro bluetoothd[599]: src/plugin.c:plugin_init() Failed to init bap plugin
Feb 13 20:27:28 Z13-Manjaro kernel: amdgpu 0000:63:00.0: amdgpu: PSP runtime database doesn't exist
Feb 13 20:27:29 Z13-Manjaro kernel: amdgpu: SRAT table not found
Feb 13 20:27:30 Z13-Manjaro systemd[696]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
Feb 13 20:27:30 Z13-Manjaro systemd[696]: Failed to start Update XDG user dir configuration.
Feb 13 20:27:30 Z13-Manjaro sddm-greeter[707]: QFont::fromString: Invalid description '(empty)'
Feb 13 20:27:31 Z13-Manjaro sddm-greeter[707]: QObject: Cannot create children for a parent that is in a different thread.
                                               (Parent is QGuiApplication(0x7ffdb44c8cc0), parent's thread is QThread(0x5644bb0a2450), current thread is QThread(0x5644bb1f87d0)
Feb 13 20:27:31 Z13-Manjaro sddm-greeter[707]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Feb 13 20:27:31 Z13-Manjaro sddm-greeter[707]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
Feb 13 20:27:31 Z13-Manjaro sddm-greeter[707]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:138:5: Type Keyboard unavailable
Feb 13 20:27:31 Z13-Manjaro sddm-greeter[707]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Feb 13 20:27:31 Z13-Manjaro sddm-greeter[707]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
Feb 13 20:27:31 Z13-Manjaro sddm-greeter[707]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.16'
Feb 13 20:27:33 Z13-Manjaro kernel: kauditd_printk_skb: 68 callbacks suppressed
Feb 13 20:27:34 Z13-Manjaro ModemManager[619]: <warn>  [modem0/sim0] couldn't load operator identifier: Couldn't get home network: QMI protocol error (16): 'NotProvisioned'
Feb 13 20:27:34 Z13-Manjaro ModemManager[619]: <warn>  [modem0/sim0] couldn't load operator name: Couldn't get home network: QMI protocol error (16): 'NotProvisioned'
Feb 13 20:27:35 Z13-Manjaro ModemManager[619]: <warn>  [modem0] couldn't load 5GNR registration settings: 5GNR registration settings are unsupported
Feb 13 20:27:35 Z13-Manjaro ModemManager[619]: <warn>  [modem0] couldn't load supported assistance data types: LOC service: general failure
Feb 13 20:27:35 Z13-Manjaro ModemManager[619]: <warn>  [modem0] Failure
Feb 13 20:27:35 Z13-Manjaro ModemManager[619]: <warn>  [modem0] couldn't load operator code: Current operator MCC/MNC is still unknown
Feb 13 20:27:35 Z13-Manjaro ModemManager[619]: <warn>  [modem0] couldn't load operator name: Current operator name is still unknown
Feb 13 20:27:36 Z13-Manjaro ksplashqml[780]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
Feb 13 20:27:36 Z13-Manjaro ksplashqml[780]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:81:29: Unable to assign int to QEasingCurve
Feb 13 20:27:36 Z13-Manjaro ksmserver[839]: Qt: Session management error: networkIdsList argument is NULL
Feb 13 20:27:36 Z13-Manjaro kwin_x11[842]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
Feb 13 20:27:36 Z13-Manjaro kwin_x11[842]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Feb 13 20:27:36 Z13-Manjaro ksmserver[839]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.15'
Feb 13 20:27:36 Z13-Manjaro plasmashell[892]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Feb 13 20:27:36 Z13-Manjaro plasmashell[892]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Feb 13 20:27:36 Z13-Manjaro pipewire[999]: mod.rt: Can't find org.freedesktop.portal.Desktop. Is xdg-desktop-portal running?
Feb 13 20:27:36 Z13-Manjaro pipewire[999]: mod.rt: found session bus but no portal
Feb 13 20:27:36 Z13-Manjaro wireplumber[1000]: Failed to set scheduler settings: Die Operation ist nicht erlaubt
Feb 13 20:27:36 Z13-Manjaro kded5[841]: kscreen.kded: PowerDevil SuspendSession action not available!
Feb 13 20:27:36 Z13-Manjaro org_kde_powerdevil[935]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Feb 13 20:27:37 Z13-Manjaro wireplumber[1000]: <WpPortalPermissionStorePlugin:0x556037054e90> Failed to call Lookup: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for camera
Feb 13 20:27:37 Z13-Manjaro plasmashell[892]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Feb 13 20:27:38 Z13-Manjaro plasmashell[892]: org.kde.plasma.containmentlayoutmanager: Error: cannot change the containment to AppletsLayout
Feb 13 20:27:38 Z13-Manjaro plasmashell[892]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:534:9: QML Label: Binding loop detected for property "height"
Feb 13 20:27:38 Z13-Manjaro plasmashell[892]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:499:13: QML Label: Binding loop detected for property "height"
Feb 13 20:27:38 Z13-Manjaro plasmashell[892]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
Feb 13 20:27:38 Z13-Manjaro plasmashell[892]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x55b917a642e0)
Feb 13 20:27:38 Z13-Manjaro plasmashell[892]: org.kde.plasma.kicker: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x55b917a68c00)
Feb 13 20:27:38 Z13-Manjaro plasmashell[892]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x55b917a64330)
Feb 13 20:27:38 Z13-Manjaro plasmashell[892]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x55b917a62610)
Feb 13 20:27:38 Z13-Manjaro plasmashell[892]: org.kde.plasma.kicker: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x55b917a21f80)
Feb 13 20:27:38 Z13-Manjaro plasmashell[892]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x55b917a666e0)
Feb 13 20:27:38 Z13-Manjaro plasmashell[892]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:556:5: QML Label: Binding loop detected for property "height"
Feb 13 20:27:38 Z13-Manjaro plasmashell[892]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Feb 13 20:27:38 Z13-Manjaro plasmashell[892]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
Feb 13 20:27:38 Z13-Manjaro kwin_x11[842]: kwin_core: XCB error: 152 (BadDamage), sequence: 1990, resource id: 16777260, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Feb 13 20:27:38 Z13-Manjaro kernel: kauditd_printk_skb: 33 callbacks suppressed
Feb 13 20:27:38 Z13-Manjaro pulseaudio[1291]: stat('/etc/pulse/default.pa.d'): Datei oder Verzeichnis nicht gefunden
Feb 13 20:27:38 Z13-Manjaro plasmashell[892]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:18:1: QML MouseArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Feb 13 20:27:38 Z13-Manjaro plasmashell[892]: Both point size and pixel size set. Using pixel size.
Feb 13 20:27:38 Z13-Manjaro plasmashell[892]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/Tooltip.qml:68:9: QML GridLayout (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Feb 13 20:27:38 Z13-Manjaro plasmashell[892]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Feb 13 20:27:38 Z13-Manjaro plasmashell[892]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55b918510bc0) QQmlContext(0x55b917dca3c0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Feb 13 20:27:38 Z13-Manjaro plasmashell[892]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Feb 13 20:27:38 Z13-Manjaro plasmashell[892]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Feb 13 20:27:38 Z13-Manjaro plasmashell[892]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Feb 13 20:27:39 Z13-Manjaro plasmashell[892]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_63_00.6.analog-stereo.monitor"
Feb 13 20:27:40 Z13-Manjaro plasmashell[892]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Feb 13 20:27:41 Z13-Manjaro plasmashell[892]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Feb 13 20:27:41 Z13-Manjaro plasmashell[892]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Feb 13 20:27:41 Z13-Manjaro plasmashell[892]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Feb 13 20:27:42 Z13-Manjaro plasmashell[892]: file:///usr/lib/qt/qml/org/kde/plasma/workspace/calendar/InfiniteList.qml:43:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Feb 13 20:27:42 Z13-Manjaro plasmashell[892]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Feb 13 20:27:42 Z13-Manjaro plasmashell[892]: file:///usr/lib/qt/qml/org/kde/plasma/workspace/calendar/MonthView.qml:381: TypeError: Cannot read property 'cellHeight' of null
Feb 13 20:27:43 Z13-Manjaro plasmashell[892]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Feb 13 20:27:43 Z13-Manjaro kdesud[1367]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Copyright (c) 1999,2000 Geert Jansen" msgid_plural: "" msgctxt: ""
Feb 13 20:27:43 Z13-Manjaro kdesud[1367]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Daemon used by kdesu" msgid_plural: "" msgctxt: ""
Feb 13 20:27:43 Z13-Manjaro kdesud[1367]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "KDE su daemon" msgid_plural: "" msgctxt: ""
Feb 13 20:27:43 Z13-Manjaro kdesud[1367]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Author" msgid_plural: "" msgctxt: ""
Feb 13 20:27:43 Z13-Manjaro kdesud[1367]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Geert Jansen" msgid_plural: "" msgctxt: ""
Feb 13 20:27:44 Z13-Manjaro plasmashell[892]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Feb 13 20:27:47 Z13-Manjaro systemsettings[1387]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ScrollablePage.qml:200:9: QML MouseArea: Binding loop detected for property "width"
Feb 13 20:27:47 Z13-Manjaro systemsettings[1387]: QFSFileEngine::open: No file name specified
Feb 13 20:27:47 Z13-Manjaro systemsettings[1387]: kf.coreaddons.desktopparser: Error: Failed to open  ""
Feb 13 20:27:47 Z13-Manjaro systemsettings[1387]: QFileDevice::seek: IODevice is not open
Feb 13 20:27:48 Z13-Manjaro plasmashell[892]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55b9198d66c0) QQmlContext(0x55b917dca3c0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Feb 13 20:27:48 Z13-Manjaro plasmashell[892]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Feb 13 20:27:48 Z13-Manjaro plasmashell[892]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Feb 13 20:27:53 Z13-Manjaro kwin_x11[842]: kwin_core: XCB error: 152 (BadDamage), sequence: 11876, resource id: 16777967, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Feb 13 20:28:36 Z13-Manjaro kwin_x11[842]: kwin_core: XCB error: 152 (BadDamage), sequence: 23265, resource id: 16778328, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Feb 13 20:28:41 Z13-Manjaro kwin_x11[842]: kwin_core: XCB error: 152 (BadDamage), sequence: 25539, resource id: 16780131, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Feb 13 20:28:51 Z13-Manjaro kwin_x11[842]: kwin_core: XCB error: 152 (BadDamage), sequence: 30592, resource id: 16780424, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Feb 13 20:28:51 Z13-Manjaro kwin_x11[842]: kwin_core: XCB error: 152 (BadDamage), sequence: 30704, resource id: 16777936, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Feb 13 20:28:51 Z13-Manjaro sddm[643]: Authentication error: "Process crashed"
Feb 13 20:28:51 Z13-Manjaro sddm[643]: Auth: sddm-helper crashed (exit code 15)
Feb 13 20:28:51 Z13-Manjaro sddm[643]: Auth: sddm-helper exited with 15
Feb 13 20:28:51 Z13-Manjaro systemd-coredump[8571]: Failed to connect to coredump service: Connection refused
Feb 13 20:28:51 Z13-Manjaro systemd[1]: udisks2.service: Main process exited, code=dumped, status=6/ABRT
Feb 13 20:28:51 Z13-Manjaro systemd[1]: udisks2.service: Failed with result 'core-dump'.
Feb 13 20:28:51 Z13-Manjaro systemd[752]: obex.service: Failed with result 'exit-code'.
Feb 13 20:28:51 Z13-Manjaro pulseaudio[1291]: Error opening PCM device front:1: Datei oder Verzeichnis nicht gefunden
Feb 13 20:28:51 Z13-Manjaro pulseaudio[1291]: Failed to create sink input: sink is suspended.
Feb 13 20:28:51 Z13-Manjaro pulseaudio[1291]: Lost I/O connection in module "module-gsettings"
Feb 13 20:28:51 Z13-Manjaro kded5[841]: kf.notifications: Failed to play sound with canberra: Invalid state
Feb 13 20:28:51 Z13-Manjaro kded5[841]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
Feb 13 20:28:51 Z13-Manjaro kded5[841]: The X11 connection broke: I/O error (code 1)
Feb 13 20:28:51 Z13-Manjaro systemd[752]: plasma-kded.service: Failed with result 'exit-code'.
Feb 13 20:28:53 Z13-Manjaro sddm[643]: Signal received: SIGTERM
Feb 13 20:28:54 Z13-Manjaro sddm[643]: QProcess: Destroyed while process ("/usr/lib/sddm/sddm-helper") is still running.
journalctl -b-1 -p4 --no-pager (Kernel 5.15.93-1)
Feb 13 20:29:50 Z13-Manjaro kernel: TSC synchronization [CPU#0 -> CPU#1]:
Feb 13 20:29:50 Z13-Manjaro kernel: Measured 2960258184 cycles TSC warp between CPUs, turning off TSC clock.
Feb 13 20:29:50 Z13-Manjaro kernel:   #2  #3  #4  #5  #6  #7  #8  #9 #10 #11 #12 #13 #14 #15
Feb 13 20:29:50 Z13-Manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GP17.XHC0.PSTA], AE_ALREADY_EXISTS (20220331/dswload2-326)
Feb 13 20:29:50 Z13-Manjaro kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20220331/psobject-220)
Feb 13 20:29:50 Z13-Manjaro kernel: Expanded resource Reserved due to conflict with PCI Bus 0000:00
Feb 13 20:29:50 Z13-Manjaro kernel: pci 0000:00:00.2: can't derive routing for PCI INT A
Feb 13 20:29:50 Z13-Manjaro kernel: pci 0000:00:00.2: PCI INT A: not connected
Feb 13 20:29:50 Z13-Manjaro kernel: ACPI: thermal: [Firmware Bug]: No valid trip found
Feb 13 20:29:50 Z13-Manjaro kernel: blacklist: Problem blacklisting hash (-13)
Feb 13 20:29:50 Z13-Manjaro kernel: Unstable clock detected, switching default tracing clock to "global"
                                      "trace_clock=local"
Feb 13 20:29:50 Z13-Manjaro kernel: usb: port power management may be unreliable
Feb 13 20:29:50 Z13-Manjaro kernel: hub 6-0:1.0: config failed, hub doesn't have any ports! (err -19)
Feb 13 20:29:50 Z13-Manjaro kernel: acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Feb 13 20:29:50 Z13-Manjaro kernel: acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Feb 13 20:29:50 Z13-Manjaro kernel: acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Feb 13 20:29:50 Z13-Manjaro kernel: acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Feb 13 20:29:50 Z13-Manjaro kernel: acpi PNP0C14:05: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Feb 13 20:29:50 Z13-Manjaro kernel: acpi PNP0C14:06: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Feb 13 20:29:51 Z13-Manjaro kernel: pcie_mp2_amd 0000:63:00.7: Failed to discover, sensors not enabled
Feb 13 20:29:51 Z13-Manjaro kernel: pcie_mp2_amd: probe of 0000:63:00.7 failed with error -95
Feb 13 20:29:51 Z13-Manjaro kernel: kvm: support for 'kvm_amd' disabled by bios
Feb 13 20:29:52 Z13-Manjaro kernel: kvm: support for 'kvm_amd' disabled by bios
Feb 13 20:29:52 Z13-Manjaro kernel: amdgpu 0000:63:00.0: amdgpu: PSP runtime database doesn't exist
Feb 13 20:29:53 Z13-Manjaro bluetoothd[624]: profiles/audio/vcp.c:vcp_init() D-Bus experimental not enabled
Feb 13 20:29:53 Z13-Manjaro bluetoothd[624]: src/plugin.c:plugin_init() Failed to init vcp plugin
Feb 13 20:29:53 Z13-Manjaro bluetoothd[624]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
Feb 13 20:29:53 Z13-Manjaro bluetoothd[624]: src/plugin.c:plugin_init() Failed to init mcp plugin
Feb 13 20:29:53 Z13-Manjaro bluetoothd[624]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
Feb 13 20:29:53 Z13-Manjaro bluetoothd[624]: src/plugin.c:plugin_init() Failed to init bap plugin
Feb 13 20:29:53 Z13-Manjaro kernel: amdgpu: SRAT table not found
Feb 13 20:29:53 Z13-Manjaro kernel: kvm: support for 'kvm_amd' disabled by bios
Feb 13 20:29:53 Z13-Manjaro kernel: Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
Feb 13 20:29:53 Z13-Manjaro bluetoothd[624]: src/device.c:device_set_wake_support() Unable to set wake_support without RPA resolution
Feb 13 20:29:54 Z13-Manjaro kernel: kvm: support for 'kvm_amd' disabled by bios
Feb 13 20:29:54 Z13-Manjaro kernel: ath11k_pci 0000:01:00.0: Failed to set the requested Country regulatory setting
Feb 13 20:29:54 Z13-Manjaro systemd-udevd[524]: could not read from '/sys/module/acpi_cpufreq/initstate': No such device
Feb 13 20:29:55 Z13-Manjaro systemd[747]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
Feb 13 20:29:55 Z13-Manjaro systemd[747]: Failed to start Update XDG user dir configuration.
Feb 13 20:29:55 Z13-Manjaro sddm-greeter[756]: QFont::fromString: Invalid description '(empty)'
Feb 13 20:29:55 Z13-Manjaro sddm-greeter[756]: QObject: Cannot create children for a parent that is in a different thread.
                                               (Parent is QGuiApplication(0x7ffcbd650570), parent's thread is QThread(0x55fdb306c450), current thread is QThread(0x55fdb31c2ac0)
Feb 13 20:29:55 Z13-Manjaro sddm-greeter[756]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Feb 13 20:29:55 Z13-Manjaro kernel: kauditd_printk_skb: 41 callbacks suppressed
Feb 13 20:29:55 Z13-Manjaro sddm-greeter[756]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
Feb 13 20:29:55 Z13-Manjaro sddm-greeter[756]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:138:5: Type Keyboard unavailable
Feb 13 20:29:55 Z13-Manjaro sddm-greeter[756]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Feb 13 20:29:56 Z13-Manjaro sddm-greeter[756]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
Feb 13 20:29:56 Z13-Manjaro sddm-greeter[756]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.18'
Feb 13 20:29:59 Z13-Manjaro ModemManager[636]: <warn>  [modem0/sim0] couldn't load operator identifier: Couldn't get home network: QMI protocol error (16): 'NotProvisioned'
Feb 13 20:29:59 Z13-Manjaro ModemManager[636]: <warn>  [modem0/sim0] couldn't load operator name: Couldn't get home network: QMI protocol error (16): 'NotProvisioned'
Feb 13 20:29:59 Z13-Manjaro ModemManager[636]: <warn>  [modem0] couldn't load 5GNR registration settings: 5GNR registration settings are unsupported
Feb 13 20:29:59 Z13-Manjaro ModemManager[636]: <warn>  [modem0] couldn't load supported assistance data types: LOC service: general failure
Feb 13 20:29:59 Z13-Manjaro ModemManager[636]: <warn>  [modem0] Failure
Feb 13 20:30:00 Z13-Manjaro ModemManager[636]: <warn>  [modem0] couldn't load operator code: Current operator MCC/MNC is still unknown
Feb 13 20:30:00 Z13-Manjaro ModemManager[636]: <warn>  [modem0] couldn't load operator name: Current operator name is still unknown
Feb 13 20:30:01 Z13-Manjaro ksplashqml[845]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
Feb 13 20:30:01 Z13-Manjaro ksplashqml[845]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:81:29: Unable to assign int to QEasingCurve
Feb 13 20:30:02 Z13-Manjaro ksmserver[903]: Qt: Session management error: networkIdsList argument is NULL
Feb 13 20:30:02 Z13-Manjaro kwin_x11[906]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
Feb 13 20:30:02 Z13-Manjaro kwin_x11[906]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Feb 13 20:30:02 Z13-Manjaro ksmserver[903]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.14'
Feb 13 20:30:02 Z13-Manjaro plasmashell[953]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Feb 13 20:30:02 Z13-Manjaro plasmashell[953]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Feb 13 20:30:02 Z13-Manjaro pipewire[1066]: mod.rt: Can't find org.freedesktop.portal.Desktop. Is xdg-desktop-portal running?
Feb 13 20:30:02 Z13-Manjaro pipewire[1066]: mod.rt: found session bus but no portal
Feb 13 20:30:02 Z13-Manjaro kded5[905]: kscreen.kded: PowerDevil SuspendSession action not available!
Feb 13 20:30:02 Z13-Manjaro wireplumber[1068]: Failed to set scheduler settings: Die Operation ist nicht erlaubt
Feb 13 20:30:02 Z13-Manjaro org_kde_powerdevil[997]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Feb 13 20:30:02 Z13-Manjaro wireplumber[1068]: <WpPortalPermissionStorePlugin:0x55f11d697880> Failed to call Lookup: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for camera
Feb 13 20:30:03 Z13-Manjaro plasmashell[953]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Feb 13 20:30:03 Z13-Manjaro plasmashell[953]: org.kde.plasma.containmentlayoutmanager: Error: cannot change the containment to AppletsLayout
Feb 13 20:30:03 Z13-Manjaro kwin_x11[906]: kwin_core: XCB error: 152 (BadDamage), sequence: 1659, resource id: 16777260, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Feb 13 20:30:03 Z13-Manjaro plasmashell[953]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:534:9: QML Label: Binding loop detected for property "height"
Feb 13 20:30:03 Z13-Manjaro plasmashell[953]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:499:13: QML Label: Binding loop detected for property "height"
Feb 13 20:30:03 Z13-Manjaro plasmashell[953]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
Feb 13 20:30:03 Z13-Manjaro plasmashell[953]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x56512eb844d0)
Feb 13 20:30:03 Z13-Manjaro plasmashell[953]: org.kde.plasma.kicker: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x56512eb88df0)
Feb 13 20:30:03 Z13-Manjaro plasmashell[953]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x56512eb84520)
Feb 13 20:30:03 Z13-Manjaro plasmashell[953]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x56512eb82800)
Feb 13 20:30:03 Z13-Manjaro plasmashell[953]: org.kde.plasma.kicker: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x56512eb421d0)
Feb 13 20:30:03 Z13-Manjaro plasmashell[953]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x56512eb868d0)
Feb 13 20:30:03 Z13-Manjaro plasmashell[953]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:556:5: QML Label: Binding loop detected for property "height"
Feb 13 20:30:03 Z13-Manjaro plasmashell[953]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Feb 13 20:30:03 Z13-Manjaro plasmashell[953]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
Feb 13 20:30:04 Z13-Manjaro pulseaudio[1223]: stat('/etc/pulse/default.pa.d'): Datei oder Verzeichnis nicht gefunden
Feb 13 20:30:04 Z13-Manjaro plasmashell[953]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:18:1: QML MouseArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Feb 13 20:30:04 Z13-Manjaro plasmashell[953]: Both point size and pixel size set. Using pixel size.
Feb 13 20:30:04 Z13-Manjaro plasmashell[953]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/Tooltip.qml:68:9: QML GridLayout (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Feb 13 20:30:04 Z13-Manjaro plasmashell[953]: org.kde.plasma.containmentlayoutmanager: Error: cannot change the containment to AppletsLayout
Feb 13 20:30:04 Z13-Manjaro plasmashell[953]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Feb 13 20:30:04 Z13-Manjaro plasmashell[953]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Feb 13 20:30:05 Z13-Manjaro plasmashell[953]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Feb 13 20:30:06 Z13-Manjaro kernel: kauditd_printk_skb: 9 callbacks suppressed
Feb 13 20:30:07 Z13-Manjaro plasmashell[953]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x56512faa7eb0) QQmlContext(0x56512eee66f0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Feb 13 20:30:07 Z13-Manjaro plasmashell[953]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Feb 13 20:30:07 Z13-Manjaro plasmashell[953]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Feb 13 20:30:07 Z13-Manjaro plasmashell[953]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Feb 13 20:30:07 Z13-Manjaro plasmashell[953]: file:///usr/lib/qt/qml/org/kde/plasma/workspace/calendar/InfiniteList.qml:43:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Feb 13 20:30:07 Z13-Manjaro plasmashell[953]: file:///usr/lib/qt/qml/org/kde/plasma/workspace/calendar/MonthView.qml:381: TypeError: Cannot read property 'cellHeight' of null
Feb 13 20:30:08 Z13-Manjaro plasmashell[953]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Feb 13 20:30:08 Z13-Manjaro plasmashell[953]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:433: Unable to assign [undefined] to QString
Feb 13 20:30:09 Z13-Manjaro plasmashell[953]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Feb 13 20:30:17 Z13-Manjaro kwin_x11[906]: kwin_core: XCB error: 152 (BadDamage), sequence: 12415, resource id: 16777421, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Feb 13 20:30:22 Z13-Manjaro plasmashell[953]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x56512f8b8f70) QQmlContext(0x56512eee66f0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Feb 13 20:30:22 Z13-Manjaro plasmashell[953]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Feb 13 20:30:22 Z13-Manjaro plasmashell[953]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Feb 13 20:30:27 Z13-Manjaro kwin_x11[906]: kwin_core: XCB error: 152 (BadDamage), sequence: 18302, resource id: 16779036, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Feb 13 20:37:13 Z13-Manjaro plasmashell[953]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:433: Unable to assign [undefined] to QString
Feb 13 20:37:13 Z13-Manjaro konsole[2350]: kf.xmlgui: Shortcut for action  "" "Schnellbefehle anzeigen" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Feb 13 20:37:13 Z13-Manjaro konsole[2350]: kf.xmlgui: Shortcut for action  "" "SSH-Verwaltung anzeigen" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Feb 13 20:37:19 Z13-Manjaro sudo[2502]:    burda : a password is required ; TTY=pts/1 ; PWD=/home/burda ; USER=root ; COMMAND=/sbin/file -s /dev/nvme0n1p2
Feb 13 20:39:15 Z13-Manjaro plasmashell[953]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:433: Unable to assign [undefined] to QString
Feb 13 20:39:16 Z13-Manjaro pamac-manager[2565]: flatpak_plugin.vala:311: Fehler beim Holen der Informationen für Datei »/var/lib/flatpak/appstream/flathub/x86_64/.timestamp«: No such file or directory
Feb 13 20:39:16 Z13-Manjaro pamac-manager[2565]: gdk_window_set_cursor: assertion 'GDK_IS_WINDOW (window)' failed
Feb 13 20:39:18 Z13-Manjaro plasmashell[953]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Feb 13 20:39:19 Z13-Manjaro plasmashell[953]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Feb 13 20:39:21 Z13-Manjaro systemsettings[2679]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ScrollablePage.qml:200:9: QML MouseArea: Binding loop detected for property "width"
Feb 13 20:39:21 Z13-Manjaro systemsettings[2679]: QFSFileEngine::open: No file name specified
Feb 13 20:39:21 Z13-Manjaro systemsettings[2679]: kf.coreaddons.desktopparser: Error: Failed to open  ""
Feb 13 20:39:21 Z13-Manjaro systemsettings[2679]: QFileDevice::seek: IODevice is not open
Feb 13 20:40:56 Z13-Manjaro plasmashell[953]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Feb 13 20:41:46 Z13-Manjaro kded5[905]: org.kde.plasma.nm.kded: Unhandled active connection state change:  3
Feb 13 20:41:47 Z13-Manjaro NetworkManager[629]: <warn>  [1676317307.0198] modem-broadband[cdc-wdm0]: failed to disconnect modem: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: Object does not exist at path “/org/freedesktop/ModemManager1/Modem/0”
Feb 13 20:41:47 Z13-Manjaro kscreenlocker_greet[2791]: Qt: Session management error: networkIdsList argument is NULL
Feb 13 20:41:47 Z13-Manjaro kscreenlocker_greet[2791]: kf.kirigami: Failed to find a Kirigami platform plugin
Feb 13 20:41:48 Z13-Manjaro kscreenlocker_greet[2791]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "de_DE" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
Feb 13 20:41:48 Z13-Manjaro plasmashell[953]: qt.qpa.clipboard: QXcbClipboard::setMimeData: Cannot set X11 selection owner
on the newer kernel the sddm crashes but who knows why…
try enabling early loading of your video drivers:
kate /etc/mkinitcpio.conf
and edit the MODULES section to look like this:
MODULES=(amdgpu)
save it and update it:
sudo mkinitcpio -P
reboot and test with newer kernel
Thanks, this way I found a solution!!
First I tried again Kernel 6.0.19-4
Three everything was just as before. Startup every second time and crash after returning from sleep or when going to hibernation still persists, but I can live with shutting down the computer better than with no WiFi.
BUT, with the edited mkinitcpio.conf I am now able to successfully boot start Kernel 6.1.11-1.
And here Sleep works!!
Hibernate still has issues, but I can live with that. Laptop is also successfully hibernating now, not stuck anymore on a black screen, but when waking up from hibernate the computer is crashing on the login screen (without Caps-Lock flashing Kernel Panic though)
But I can perfectly live without hibernate.
I added a Kernel 6.1.11-1 journalctl from post hibernation crash for additional information:
eb 14 22:01:59 Z13-Manjaro kernel: TSC synchronization [CPU#0 -> CPU#1]:
Feb 14 22:01:59 Z13-Manjaro kernel: Measured 2960881344 cycles TSC warp between CPUs, turning off TSC clock.
Feb 14 22:01:59 Z13-Manjaro kernel:   #2  #3  #4  #5  #6  #7  #8  #9 #10 #11 #12 #13 #14 #15
Feb 14 22:01:59 Z13-Manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GP17.XHC0.PSTA], AE_ALREADY_EXISTS (20220331/dswload2-326)
Feb 14 22:01:59 Z13-Manjaro kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20220331/psobject-220)
Feb 14 22:01:59 Z13-Manjaro kernel: Expanded resource Reserved due to conflict with PCI Bus 0000:00
Feb 14 22:01:59 Z13-Manjaro kernel: pci 0000:00:00.2: can't derive routing for PCI INT A
Feb 14 22:01:59 Z13-Manjaro kernel: pci 0000:00:00.2: PCI INT A: not connected
Feb 14 22:01:59 Z13-Manjaro kernel: ACPI: thermal: [Firmware Bug]: No valid trip found
Feb 14 22:01:59 Z13-Manjaro kernel: blacklist: Problem blacklisting hash (-13)
Feb 14 22:01:59 Z13-Manjaro kernel: Unstable clock detected, switching default tracing clock to "global"
                                      "trace_clock=local"
Feb 14 22:01:59 Z13-Manjaro kernel: amdgpu 0000:63:00.0: amdgpu: PSP runtime database doesn't exist
Feb 14 22:01:59 Z13-Manjaro kernel: amdgpu: SRAT table not found
Feb 14 22:01:59 Z13-Manjaro kernel: usb: port power management may be unreliable
Feb 14 22:01:59 Z13-Manjaro kernel: hub 6-0:1.0: config failed, hub doesn't have any ports! (err -19)
Feb 14 22:01:59 Z13-Manjaro systemd-vconsole-setup[491]: KD_FONT_OP_GET failed while trying to get the font metadata: Das Argument ist ungültig
Feb 14 22:01:59 Z13-Manjaro systemd-vconsole-setup[491]: Fonts will not be copied to remaining consoles
Feb 14 22:01:59 Z13-Manjaro kernel: kvm: support for 'kvm_amd' disabled by bios
Feb 14 22:02:00 Z13-Manjaro kernel: pcie_mp2_amd 0000:63:00.7: Failed to discover, sensors not enabled
Feb 14 22:02:00 Z13-Manjaro kernel: pcie_mp2_amd: probe of 0000:63:00.7 failed with error -95
Feb 14 22:02:00 Z13-Manjaro kernel: Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
Feb 14 22:02:01 Z13-Manjaro kernel: ath11k_pci 0000:01:00.0: Failed to set the requested Country regulatory setting
Feb 14 22:02:01 Z13-Manjaro bluetoothd[679]: profiles/audio/vcp.c:vcp_init() D-Bus experimental not enabled
Feb 14 22:02:01 Z13-Manjaro bluetoothd[679]: src/plugin.c:plugin_init() Failed to init vcp plugin
Feb 14 22:02:01 Z13-Manjaro bluetoothd[679]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
Feb 14 22:02:01 Z13-Manjaro bluetoothd[679]: src/plugin.c:plugin_init() Failed to init mcp plugin
Feb 14 22:02:01 Z13-Manjaro bluetoothd[679]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
Feb 14 22:02:01 Z13-Manjaro bluetoothd[679]: src/plugin.c:plugin_init() Failed to init bap plugin
Feb 14 22:02:01 Z13-Manjaro bluetoothd[679]: src/device.c:device_set_wake_support() Unable to set wake_support without RPA resolution
Feb 14 22:02:05 Z13-Manjaro kernel: kauditd_printk_skb: 28 callbacks suppressed
Feb 14 22:02:05 Z13-Manjaro systemd[760]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
Feb 14 22:02:05 Z13-Manjaro systemd[760]: Failed to start Update XDG user dir configuration.
Feb 14 22:02:05 Z13-Manjaro sddm-greeter[769]: QFont::fromString: Invalid description '(empty)'
Feb 14 22:02:05 Z13-Manjaro sddm-greeter[769]: QObject: Cannot create children for a parent that is in a different thread.
                                               (Parent is QGuiApplication(0x7ffc9eeeba10), parent's thread is QThread(0x55b7b01c3450), current thread is QThread(0x55b7b03195f0)
Feb 14 22:02:05 Z13-Manjaro sddm-greeter[769]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Feb 14 22:02:05 Z13-Manjaro sddm-greeter[769]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
Feb 14 22:02:05 Z13-Manjaro sddm-greeter[769]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:138:5: Type Keyboard unavailable
Feb 14 22:02:05 Z13-Manjaro sddm-greeter[769]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Feb 14 22:02:06 Z13-Manjaro sddm-greeter[769]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
Feb 14 22:02:06 Z13-Manjaro sddm-greeter[769]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.21'
Feb 14 22:02:08 Z13-Manjaro ModemManager[719]: <warn>  [modem0/sim0] couldn't load operator identifier: Couldn't get home network: QMI protocol error (16): 'NotProvisioned'
Feb 14 22:02:08 Z13-Manjaro ModemManager[719]: <warn>  [modem0/sim0] couldn't load operator name: Couldn't get home network: QMI protocol error (16): 'NotProvisioned'
Feb 14 22:02:08 Z13-Manjaro ModemManager[719]: <warn>  [modem0] couldn't load 5GNR registration settings: 5GNR registration settings are unsupported
Feb 14 22:02:08 Z13-Manjaro ModemManager[719]: <warn>  [modem0] couldn't load supported assistance data types: LOC service: general failure
Feb 14 22:02:08 Z13-Manjaro ModemManager[719]: <warn>  [modem0] Failure
Feb 14 22:02:09 Z13-Manjaro ModemManager[719]: <warn>  [modem0] couldn't load operator code: Current operator MCC/MNC is still unknown
Feb 14 22:02:09 Z13-Manjaro ModemManager[719]: <warn>  [modem0] couldn't load operator name: Current operator name is still unknown
Feb 14 22:02:10 Z13-Manjaro kernel: kauditd_printk_skb: 7 callbacks suppressed
Feb 14 22:02:11 Z13-Manjaro ksplashqml[862]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
Feb 14 22:02:11 Z13-Manjaro ksplashqml[862]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:81:29: Unable to assign int to QEasingCurve
Feb 14 22:02:11 Z13-Manjaro ksmserver[919]: Qt: Session management error: networkIdsList argument is NULL
Feb 14 22:02:11 Z13-Manjaro kwin_x11[923]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
Feb 14 22:02:11 Z13-Manjaro kwin_x11[923]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Feb 14 22:02:11 Z13-Manjaro ksmserver[919]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.16'
Feb 14 22:02:12 Z13-Manjaro plasmashell[974]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Feb 14 22:02:12 Z13-Manjaro plasmashell[974]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Feb 14 22:02:12 Z13-Manjaro kded5[922]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
Feb 14 22:02:12 Z13-Manjaro pipewire[1083]: mod.rt: Can't find org.freedesktop.portal.Desktop. Is xdg-desktop-portal running?
Feb 14 22:02:12 Z13-Manjaro pipewire[1083]: mod.rt: found session bus but no portal
Feb 14 22:02:12 Z13-Manjaro kded5[922]: kscreen.kded: PowerDevil SuspendSession action not available!
Feb 14 22:02:12 Z13-Manjaro wireplumber[1086]: Failed to set scheduler settings: Die Operation ist nicht erlaubt
Feb 14 22:02:12 Z13-Manjaro org_kde_powerdevil[1017]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Feb 14 22:02:12 Z13-Manjaro wireplumber[1086]: <WpPortalPermissionStorePlugin:0x560f0618e2a0> Failed to call Lookup: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for camera
Feb 14 22:02:13 Z13-Manjaro plasmashell[974]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Feb 14 22:02:13 Z13-Manjaro plasmashell[974]: org.kde.plasma.containmentlayoutmanager: Error: cannot change the containment to AppletsLayout
Feb 14 22:02:13 Z13-Manjaro plasmashell[974]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:534:9: QML Label: Binding loop detected for property "height"
Feb 14 22:02:13 Z13-Manjaro plasmashell[974]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:499:13: QML Label: Binding loop detected for property "height"
Feb 14 22:02:13 Z13-Manjaro plasmashell[974]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
Feb 14 22:02:13 Z13-Manjaro plasmashell[974]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x557020749100)
Feb 14 22:02:13 Z13-Manjaro plasmashell[974]: org.kde.plasma.kicker: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x55702074d990)
Feb 14 22:02:13 Z13-Manjaro plasmashell[974]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x557020749150)
Feb 14 22:02:13 Z13-Manjaro plasmashell[974]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x557020747430)
Feb 14 22:02:13 Z13-Manjaro plasmashell[974]: org.kde.plasma.kicker: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x5570207070b0)
Feb 14 22:02:13 Z13-Manjaro plasmashell[974]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x55702074b500)
Feb 14 22:02:13 Z13-Manjaro plasmashell[974]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:556:5: QML Label: Binding loop detected for property "height"
Feb 14 22:02:13 Z13-Manjaro plasmashell[974]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Feb 14 22:02:13 Z13-Manjaro plasmashell[974]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
Feb 14 22:02:13 Z13-Manjaro pulseaudio[1242]: stat('/etc/pulse/default.pa.d'): Datei oder Verzeichnis nicht gefunden
Feb 14 22:02:14 Z13-Manjaro plasmashell[974]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:18:1: QML MouseArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Feb 14 22:02:14 Z13-Manjaro plasmashell[974]: Both point size and pixel size set. Using pixel size.
Feb 14 22:02:14 Z13-Manjaro plasmashell[974]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/Tooltip.qml:68:9: QML GridLayout (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Feb 14 22:02:14 Z13-Manjaro plasmashell[974]: org.kde.plasma.containmentlayoutmanager: Error: cannot change the containment to AppletsLayout
Feb 14 22:02:14 Z13-Manjaro plasmashell[974]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Feb 14 22:02:14 Z13-Manjaro plasmashell[974]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x557021265e60) QQmlContext(0x557020aeaea0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Feb 14 22:02:14 Z13-Manjaro plasmashell[974]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Feb 14 22:02:14 Z13-Manjaro plasmashell[974]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Feb 14 22:02:14 Z13-Manjaro plasmashell[974]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Feb 14 22:02:15 Z13-Manjaro plasmashell[974]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Feb 14 22:02:16 Z13-Manjaro plasmashell[974]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Feb 14 22:02:16 Z13-Manjaro plasmashell[974]: file:///usr/lib/qt/qml/org/kde/plasma/workspace/calendar/InfiniteList.qml:43:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Feb 14 22:02:16 Z13-Manjaro plasmashell[974]: file:///usr/lib/qt/qml/org/kde/plasma/workspace/calendar/MonthView.qml:381: TypeError: Cannot read property 'cellHeight' of null
Feb 14 22:02:17 Z13-Manjaro plasmashell[974]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Feb 14 22:02:18 Z13-Manjaro plasmashell[974]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Feb 14 22:02:19 Z13-Manjaro kwin_x11[923]: kwin_core: XCB error: 152 (BadDamage), sequence: 5847, resource id: 16777415, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Feb 14 22:02:21 Z13-Manjaro kernel: kauditd_printk_skb: 10 callbacks suppressed
Feb 14 22:02:21 Z13-Manjaro kded5[922]: org.kde.plasma.nm.kded: Unhandled active connection state change:  3
Feb 14 22:02:21 Z13-Manjaro NetworkManager[706]: <warn>  [1676408541.5586] modem-broadband[cdc-wdm0]: failed to disconnect modem: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: Object does not exist at path “/org/freedesktop/ModemManager1/Modem/0”
Feb 14 22:02:21 Z13-Manjaro kscreenlocker_greet[1298]: Qt: Session management error: networkIdsList argument is NULL
Feb 14 22:02:22 Z13-Manjaro kscreenlocker_greet[1298]: kf.kirigami: Failed to find a Kirigami platform plugin
Feb 14 22:02:22 Z13-Manjaro kscreenlocker_greet[1298]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "de_DE" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
Feb 14 22:02:22 Z13-Manjaro plasmashell[974]: qt.qpa.clipboard: QXcbClipboard::setMimeData: Cannot set X11 selection owner
Feb 14 22:02:28 Z13-Manjaro kernel: cs35l41-hda i2c-CSC3551:00-cs35l41-hda.1: Failed to read MBOX STS: -121
Feb 14 22:02:28 Z13-Manjaro kernel: cs35l41-hda i2c-CSC3551:00-cs35l41-hda.0: Failed to read MBOX STS: -121
Feb 14 22:02:28 Z13-Manjaro kernel: ACPI: button: The lid device is not compliant to SW_LID.
Feb 14 22:02:28 Z13-Manjaro kernel: [drm] Watermarks table not configured properly by SMU
Feb 14 22:02:28 Z13-Manjaro ModemManager[719]: <warn>  [/dev/cdc-wdm0] MBIM error: Transaction timed out
Feb 14 22:02:34 Z13-Manjaro ModemManager[719]: <warn>  [modem1] couldn't load 5GNR registration settings: 5GNR registration settings are unsupported
Feb 14 22:02:34 Z13-Manjaro ModemManager[719]: <warn>  [modem1] couldn't load supported assistance data types: LOC service: general failure
Feb 14 22:02:34 Z13-Manjaro plasmashell[974]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5570211c6160) QQmlContext(0x557020aeaea0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Feb 14 22:02:34 Z13-Manjaro plasmashell[974]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Feb 14 22:02:34 Z13-Manjaro plasmashell[974]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Feb 14 22:02:35 Z13-Manjaro kded5[922]: "Das Objekt existiert nicht am Pfad »/org/freedesktop/NetworkManager/ActiveConnection/2«"
Feb 14 22:02:35 Z13-Manjaro kdeconnectd[1143]: "Das Objekt existiert nicht am Pfad »/org/freedesktop/NetworkManager/ActiveConnection/2«"
Feb 14 22:02:35 Z13-Manjaro kded5[922]: "Das Objekt existiert nicht am Pfad »/org/freedesktop/NetworkManager/ActiveConnection/1«"
Feb 14 22:02:35 Z13-Manjaro kdeconnectd[1143]: "Das Objekt existiert nicht am Pfad »/org/freedesktop/NetworkManager/ActiveConnection/1«"
Feb 14 22:02:37 Z13-Manjaro plasmashell[974]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:433: Unable to assign [undefined] to QString
Feb 14 22:02:39 Z13-Manjaro kwin_x11[923]: kwin_core: XCB error: 152 (BadDamage), sequence: 13723, resource id: 16777972, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Feb 14 22:02:40 Z13-Manjaro NetworkManager[706]: <warn>  [1676408560.0013] sup-iface[8170427421137a36,1,wlp1s0]: wps: cancel failed (Zeitüberschreitung wurde erreicht)
Feb 14 22:02:42 Z13-Manjaro plasmashell[974]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x7fc6945f0bc0) QQmlContext(0x557020aeaea0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Feb 14 22:02:42 Z13-Manjaro plasmashell[974]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Feb 14 22:02:42 Z13-Manjaro plasmashell[974]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Feb 14 22:02:47 Z13-Manjaro kwin_x11[923]: kwin_core: XCB error: 152 (BadDamage), sequence: 20143, resource id: 16778959, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Feb 14 22:03:22 Z13-Manjaro plasmashell[974]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:433: Unable to assign [undefined] to QString
Feb 14 22:03:22 Z13-Manjaro pamac-manager[1873]: flatpak_plugin.vala:311: Fehler beim Holen der Informationen für Datei »/var/lib/flatpak/appstream/flathub/x86_64/.timestamp«: No such file or directory
Feb 14 22:03:22 Z13-Manjaro pamac-manager[1873]: gdk_window_set_cursor: assertion 'GDK_IS_WINDOW (window)' failed
Feb 14 22:03:26 Z13-Manjaro plasmashell[974]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Feb 14 22:03:27 Z13-Manjaro plasmashell[974]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Feb 14 22:03:28 Z13-Manjaro systemsettings[1954]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ScrollablePage.qml:200:9: QML MouseArea: Binding loop detected for property "width"
Feb 14 22:03:28 Z13-Manjaro systemsettings[1954]: QFSFileEngine::open: No file name specified
Feb 14 22:03:28 Z13-Manjaro systemsettings[1954]: kf.coreaddons.desktopparser: Error: Failed to open  ""
Feb 14 22:03:28 Z13-Manjaro systemsettings[1954]: QFileDevice::seek: IODevice is not open
Feb 14 22:04:55 Z13-Manjaro kded5[922]: org.kde.plasma.nm.kded: Unhandled active connection state change:  3
Feb 14 22:04:55 Z13-Manjaro kscreenlocker_greet[2004]: Qt: Session management error: networkIdsList argument is NULL
Feb 14 22:04:55 Z13-Manjaro NetworkManager[706]: <warn>  [1676408695.8608] modem-broadband[cdc-wdm0]: failed to disconnect modem: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: Object does not exist at path “/org/freedesktop/ModemManager1/Modem/1”
Feb 14 22:04:56 Z13-Manjaro kscreenlocker_greet[2004]: kf.kirigami: Failed to find a Kirigami platform plugin
Feb 14 22:04:56 Z13-Manjaro kscreenlocker_greet[2004]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "de_DE" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
the only suspicious is this log…
but i dont use hibernation, so wil not be much of help…
and when the after hibernation crash happens, do you have to reboot?
