Since my girlfried and I wanted to leave behind Windows for good, we chose to use Manjaro KDE on our machines.
On my Lenovo ThinkPad E580 everything worked smoothly.
For her I bought a Lenovo Yoga Slim 7 (her laptop was quite old) expecting the same. But there are a few issues still remaining I can’t fix with my WebDev knowledge (please forgive me ).
Touchpad doesn’t work after suspend
I got the touchpad to work in the first place by blacklisting the elan_i2c
module.
After suspending it doesn’t work anymore.
I’ve read something about a weird suspend mode introduced for new devices, but running dmesg | grep ACPI | grep supports
outputs [...] ACPI: (supports S0 S3 S4 S5)
and suspend works out of the box (I guess because S3
is supported).
Which information do you need to help me fix this?
Ethernet connected through USB-C drop every few minutes for a few seconds
Wi-Fi works out of the box. The machine doesn’t have a dedicated ethernet port. So I bought an adapter (RJ45 to USB-C) which works well on other machines. When used with the Yoga the connection drops after a few minutes and reconnects immediately (with a few seconds offline in between).
I’ve ran journalctl -b
after it happened. Following is the shortened output.
journalctl.txt
Jul 05 07:35:39 lenovo-yoga-angie kscreen_backend_launcher[1270]: kscreen.xcb.helper: State (newValue, Deleted): 0
Jul 05 07:35:40 lenovo-yoga-angie NetworkManager[463]: <info> [1625463340.7684] dhcp6 (enp0s13f0u2): activation: beginning transaction (timeout in 45 seconds)
Jul 05 07:35:40 lenovo-yoga-angie avahi-daemon[460]: Leaving mDNS multicast group on interface enp0s13f0u2.IPv6 with address fe80::bf49:5ac5:2aa3:2481.
Jul 05 07:35:40 lenovo-yoga-angie avahi-daemon[460]: Joining mDNS multicast group on interface enp0s13f0u2.IPv6 with address 2001:a61:b95:901:6027:6bef:9ca:988d.
Jul 05 07:35:40 lenovo-yoga-angie avahi-daemon[460]: Registering new address record for 2001:a61:b95:901:6027:6bef:9ca:988d on enp0s13f0u2.*.
Jul 05 07:35:40 lenovo-yoga-angie avahi-daemon[460]: Withdrawing address record for fe80::bf49:5ac5:2aa3:2481 on enp0s13f0u2.
Jul 05 07:35:40 lenovo-yoga-angie avahi-daemon[460]: Registering new address record for fd00::3fb5:780a:6e43:d281 on enp0s13f0u2.*.
Jul 05 07:35:40 lenovo-yoga-angie NetworkManager[463]: <info> [1625463340.7691] policy: set 'Kabelgebundene Verbindung 1' (enp0s13f0u2) as default for IPv6 routing and DNS
Jul 05 07:35:40 lenovo-yoga-angie dnsmasq[2009]: lese /etc/resolv.conf
Jul 05 07:35:40 lenovo-yoga-angie dnsmasq[2009]: Benutze Namensserver 192.168.178.1#53
Jul 05 07:35:40 lenovo-yoga-angie dnsmasq[2009]: Benutze Namensserver fd00::3a10:d5ff:fe7d:2afd#53
Jul 05 07:35:40 lenovo-yoga-angie dnsmasq[2009]: Cache geleert
Jul 05 07:35:40 lenovo-yoga-angie NetworkManager[463]: <info> [1625463340.7809] dhcp6 (enp0s13f0u2): state changed unknown -> bound
Jul 05 07:35:40 lenovo-yoga-angie ModemManager[506]: <info> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:0d.0/usb2/2-2': not supported by any plugin
Jul 05 07:35:47 lenovo-yoga-angie systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Jul 05 07:35:47 lenovo-yoga-angie audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 05 07:35:47 lenovo-yoga-angie kernel: audit: type=1131 audit(1625463347.767:141): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 05 07:35:50 lenovo-yoga-angie avahi-daemon[460]: Interface enp0s13f0u2.IPv6 no longer relevant for mDNS.
Jul 05 07:35:50 lenovo-yoga-angie avahi-daemon[460]: Leaving mDNS multicast group on interface enp0s13f0u2.IPv6 with address 2001:a61:b95:901:6027:6bef:9ca:988d.
Jul 05 07:35:50 lenovo-yoga-angie kernel: usb 2-2: USB disconnect, device number 6
Jul 05 07:35:50 lenovo-yoga-angie avahi-daemon[460]: Interface enp0s13f0u2.IPv4 no longer relevant for mDNS.
Jul 05 07:35:50 lenovo-yoga-angie avahi-daemon[460]: Leaving mDNS multicast group on interface enp0s13f0u2.IPv4 with address 192.168.178.91.
Jul 05 07:35:50 lenovo-yoga-angie avahi-daemon[460]: Withdrawing address record for fd00::3fb5:780a:6e43:d281 on enp0s13f0u2.
Jul 05 07:35:50 lenovo-yoga-angie avahi-daemon[460]: Withdrawing address record for 2001:a61:b95:901:6027:6bef:9ca:988d on enp0s13f0u2.
Jul 05 07:35:50 lenovo-yoga-angie avahi-daemon[460]: Withdrawing address record for 192.168.178.91 on enp0s13f0u2.
Jul 05 07:35:50 lenovo-yoga-angie NetworkManager[463]: <info> [1625463350.3243] device (enp0s13f0u2): state change: activated -> unmanaged (reason 'removed', sys-iface-state: 'removed')
Jul 05 07:35:50 lenovo-yoga-angie NetworkManager[463]: <info> [1625463350.3640] dhcp4 (enp0s13f0u2): canceled DHCP transaction
Jul 05 07:35:50 lenovo-yoga-angie NetworkManager[463]: <info> [1625463350.3641] dhcp4 (enp0s13f0u2): state changed bound -> terminated
Jul 05 07:35:50 lenovo-yoga-angie NetworkManager[463]: <info> [1625463350.3645] dhcp6 (enp0s13f0u2): canceled DHCP transaction
Jul 05 07:35:50 lenovo-yoga-angie NetworkManager[463]: <info> [1625463350.3645] dhcp6 (enp0s13f0u2): state changed bound -> terminated
Jul 05 07:35:50 lenovo-yoga-angie dnsmasq[2009]: lese /etc/resolv.conf
Jul 05 07:35:50 lenovo-yoga-angie dnsmasq[2009]: Benutze Namensserver fd00::3a10:d5ff:fe7d:2afd#53
Jul 05 07:35:50 lenovo-yoga-angie dnsmasq[2009]: Cache geleert
Jul 05 07:35:50 lenovo-yoga-angie dnsmasq[2009]: keine Server in /etc/resolv.conf gefunden, werde nochmal versuchen
Jul 05 07:35:50 lenovo-yoga-angie NetworkManager[463]: <info> [1625463350.3828] manager: NetworkManager state is now CONNECTED_LOCAL
Jul 05 07:35:50 lenovo-yoga-angie dbus-daemon[462]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=463 comm="/usr/bin/NetworkManager --no-daemon ")
Jul 05 07:35:50 lenovo-yoga-angie systemd[1]: Starting Network Manager Script Dispatcher Service...
Jul 05 07:35:50 lenovo-yoga-angie kded5[1132]: plasma-nm: Network connectivity limited, scheduling notification
Jul 05 07:35:50 lenovo-yoga-angie dbus-daemon[462]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jul 05 07:35:50 lenovo-yoga-angie systemd[1]: Started Network Manager Script Dispatcher Service.
Jul 05 07:35:50 lenovo-yoga-angie audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 05 07:35:50 lenovo-yoga-angie kernel: audit: type=1130 audit(1625463350.390:142): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 05 07:35:50 lenovo-yoga-angie plasmashell[1203]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationPopup.qml:116:15: QML QQuickItem: Binding loop detected for property "height"
Jul 05 07:35:50 lenovo-yoga-angie kernel: usb 2-2: new SuperSpeed Gen 1 USB device number 7 using xhci_hcd
Jul 05 07:35:50 lenovo-yoga-angie kernel: usb 2-2: New USB device found, idVendor=17ef, idProduct=720c, bcdDevice=30.00
Jul 05 07:35:50 lenovo-yoga-angie kernel: usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=6
Jul 05 07:35:50 lenovo-yoga-angie kernel: usb 2-2: Product: Lenovo USB-C to LAN
Jul 05 07:35:50 lenovo-yoga-angie kernel: usb 2-2: Manufacturer: Lenovo
Jul 05 07:35:50 lenovo-yoga-angie kernel: usb 2-2: SerialNumber: 5943B4000000
Jul 05 07:35:50 lenovo-yoga-angie kernel: usb 2-2: reset SuperSpeed Gen 1 USB device number 7 using xhci_hcd
Jul 05 07:35:50 lenovo-yoga-angie kernel: r8152 2-2:1.0: load rtl8153a-3 v2 02/07/20 successfully
Jul 05 07:35:50 lenovo-yoga-angie NetworkManager[463]: <info> [1625463350.7979] manager: (eth0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/9)
Jul 05 07:35:50 lenovo-yoga-angie kernel: r8152 2-2:1.0 eth0: v1.11.11
Jul 05 07:35:50 lenovo-yoga-angie mtp-probe[3682]: checking bus 2, device 7: "/sys/devices/pci0000:00/0000:00:0d.0/usb2/2-2"
Jul 05 07:35:50 lenovo-yoga-angie mtp-probe[3682]: bus: 2, device: 7 was not an MTP device
Jul 05 07:35:51 lenovo-yoga-angie upowerd[1028]: treating change event as add on /sys/devices/pci0000:00/0000:00:0d.0/usb2/2-2
Jul 05 07:35:51 lenovo-yoga-angie mtp-probe[3709]: checking bus 2, device 7: "/sys/devices/pci0000:00/0000:00:0d.0/usb2/2-2"
Jul 05 07:35:51 lenovo-yoga-angie mtp-probe[3709]: bus: 2, device: 7 was not an MTP device
Jul 05 07:35:51 lenovo-yoga-angie kernel: r8152 2-2:1.0 enp0s13f0u2: renamed from eth0
Jul 05 07:35:51 lenovo-yoga-angie NetworkManager[463]: <info> [1625463351.4230] device (eth0): interface index 8 renamed iface from 'eth0' to 'enp0s13f0u2'
Jul 05 07:35:51 lenovo-yoga-angie NetworkManager[463]: <info> [1625463351.4313] device (enp0s13f0u2): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Jul 05 07:35:51 lenovo-yoga-angie dolphin[2141]: UdevQt: unhandled device action "move"
Jul 05 07:35:51 lenovo-yoga-angie kate[2182]: UdevQt: unhandled device action "move"
Jul 05 07:35:51 lenovo-yoga-angie baloo_file[1212]: UdevQt: unhandled device action "move"
Jul 05 07:35:51 lenovo-yoga-angie org_kde_powerdevil[1197]: UdevQt: unhandled device action "move"
Jul 05 07:35:51 lenovo-yoga-angie plasmashell[1203]: UdevQt: unhandled device action "move"
Jul 05 07:35:52 lenovo-yoga-angie NetworkManager[463]: <info> [1625463352.4832] device (enp0s13f0u2): carrier: link connected
Jul 05 07:35:52 lenovo-yoga-angie NetworkManager[463]: <info> [1625463352.4842] device (enp0s13f0u2): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
Jul 05 07:35:52 lenovo-yoga-angie NetworkManager[463]: <info> [1625463352.4854] policy: auto-activating connection 'Kabelgebundene Verbindung 1' (b4074f34-86ac-3559-aaa5-44896c5a90eb)
Jul 05 07:35:52 lenovo-yoga-angie kernel: IPv6: ADDRCONF(NETDEV_CHANGE): enp0s13f0u2: link becomes ready
Jul 05 07:35:52 lenovo-yoga-angie kernel: r8152 2-2:1.0 enp0s13f0u2: carrier on
Jul 05 07:35:52 lenovo-yoga-angie NetworkManager[463]: <info> [1625463352.4862] device (enp0s13f0u2): Activation: starting connection 'Kabelgebundene Verbindung 1' (b4074f34-86ac-3559-aaa5-44896c5a90eb)
Jul 05 07:35:52 lenovo-yoga-angie NetworkManager[463]: <info> [1625463352.4864] device (enp0s13f0u2): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Jul 05 07:35:52 lenovo-yoga-angie NetworkManager[463]: <info> [1625463352.4870] manager: NetworkManager state is now CONNECTING
Jul 05 07:35:52 lenovo-yoga-angie NetworkManager[463]: <info> [1625463352.4874] device (enp0s13f0u2): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Jul 05 07:35:52 lenovo-yoga-angie NetworkManager[463]: <info> [1625463352.4881] device (enp0s13f0u2): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Jul 05 07:35:52 lenovo-yoga-angie NetworkManager[463]: <info> [1625463352.4885] dhcp4 (enp0s13f0u2): activation: beginning transaction (timeout in 45 seconds)
Jul 05 07:35:52 lenovo-yoga-angie avahi-daemon[460]: Joining mDNS multicast group on interface enp0s13f0u2.IPv6 with address fe80::bf49:5ac5:2aa3:2481.
Jul 05 07:35:52 lenovo-yoga-angie avahi-daemon[460]: New relevant interface enp0s13f0u2.IPv6 for mDNS.
Jul 05 07:35:52 lenovo-yoga-angie avahi-daemon[460]: Registering new address record for fe80::bf49:5ac5:2aa3:2481 on enp0s13f0u2.*.
Jul 05 07:35:52 lenovo-yoga-angie NetworkManager[463]: <info> [1625463352.4967] dhcp4 (enp0s13f0u2): state changed unknown -> bound, address=192.168.178.91
Jul 05 07:35:52 lenovo-yoga-angie avahi-daemon[460]: Joining mDNS multicast group on interface enp0s13f0u2.IPv4 with address 192.168.178.91.
Jul 05 07:35:52 lenovo-yoga-angie avahi-daemon[460]: New relevant interface enp0s13f0u2.IPv4 for mDNS.
Jul 05 07:35:52 lenovo-yoga-angie avahi-daemon[460]: Registering new address record for 192.168.178.91 on enp0s13f0u2.IPv4.
Jul 05 07:35:52 lenovo-yoga-angie NetworkManager[463]: <info> [1625463352.4977] device (enp0s13f0u2): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Jul 05 07:35:52 lenovo-yoga-angie NetworkManager[463]: <info> [1625463352.4989] device (enp0s13f0u2): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Jul 05 07:35:52 lenovo-yoga-angie NetworkManager[463]: <info> [1625463352.4991] device (enp0s13f0u2): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Jul 05 07:35:52 lenovo-yoga-angie NetworkManager[463]: <info> [1625463352.4994] manager: NetworkManager state is now CONNECTED_LOCAL
Jul 05 07:35:52 lenovo-yoga-angie NetworkManager[463]: <info> [1625463352.5000] manager: NetworkManager state is now CONNECTED_SITE
Jul 05 07:35:52 lenovo-yoga-angie NetworkManager[463]: <info> [1625463352.5001] policy: set 'Kabelgebundene Verbindung 1' (enp0s13f0u2) as default for IPv4 routing and DNS
Jul 05 07:35:52 lenovo-yoga-angie dnsmasq[2009]: lese /etc/resolv.conf
Jul 05 07:35:52 lenovo-yoga-angie dnsmasq[2009]: Benutze Namensserver 192.168.178.1#53
Jul 05 07:35:52 lenovo-yoga-angie dnsmasq[2009]: Cache geleert
Jul 05 07:35:52 lenovo-yoga-angie NetworkManager[463]: <info> [1625463352.5017] device (enp0s13f0u2): Activation: successful, device activated.
Jul 05 07:35:52 lenovo-yoga-angie NetworkManager[463]: <info> [1625463352.5629] manager: NetworkManager state is now CONNECTED_GLOBAL
Jul 05 07:35:53 lenovo-yoga-angie ModemManager[506]: <info> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:0d.0/usb2/2-2': not supported by any plugin
Jul 05 07:35:54 lenovo-yoga-angie NetworkManager[463]: <info> [1625463354.1701] dhcp6 (enp0s13f0u2): activation: beginning transaction (timeout in 45 seconds)
Jul 05 07:35:54 lenovo-yoga-angie avahi-daemon[460]: Leaving mDNS multicast group on interface enp0s13f0u2.IPv6 with address fe80::bf49:5ac5:2aa3:2481.
Jul 05 07:35:54 lenovo-yoga-angie avahi-daemon[460]: Joining mDNS multicast group on interface enp0s13f0u2.IPv6 with address 2001:a61:b95:901:6027:6bef:9ca:988d.
Jul 05 07:35:54 lenovo-yoga-angie avahi-daemon[460]: Registering new address record for 2001:a61:b95:901:6027:6bef:9ca:988d on enp0s13f0u2.*.
Jul 05 07:35:54 lenovo-yoga-angie avahi-daemon[460]: Withdrawing address record for fe80::bf49:5ac5:2aa3:2481 on enp0s13f0u2.
Jul 05 07:35:54 lenovo-yoga-angie avahi-daemon[460]: Registering new address record for fd00::3fb5:780a:6e43:d281 on enp0s13f0u2.*.
Jul 05 07:35:54 lenovo-yoga-angie NetworkManager[463]: <info> [1625463354.1714] policy: set 'Kabelgebundene Verbindung 1' (enp0s13f0u2) as default for IPv6 routing and DNS
Jul 05 07:35:54 lenovo-yoga-angie dnsmasq[2009]: lese /etc/resolv.conf
Jul 05 07:35:54 lenovo-yoga-angie dnsmasq[2009]: Benutze Namensserver 192.168.178.1#53
Jul 05 07:35:54 lenovo-yoga-angie dnsmasq[2009]: Benutze Namensserver fd00::3a10:d5ff:fe7d:2afd#53
Jul 05 07:35:54 lenovo-yoga-angie dnsmasq[2009]: Cache geleert
Jul 05 07:35:54 lenovo-yoga-angie NetworkManager[463]: <info> [1625463354.1759] dhcp6 (enp0s13f0u2): state changed unknown -> bound
Jul 05 07:36:00 lenovo-yoga-angie systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Jul 05 07:36:00 lenovo-yoga-angie audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 05 07:36:00 lenovo-yoga-angie kernel: audit: type=1131 audit(1625463360.770:143): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 05 07:36:07 lenovo-yoga-angie kwin_x11[1136]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 37856, resource id: 4194310, major code: 18 (ChangeProperty), minor code: 0
Jul 05 07:36:09 lenovo-yoga-angie audit[3752]: USER_AUTH pid=3752 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="angie" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Jul 05 07:36:09 lenovo-yoga-angie kernel: audit: type=1100 audit(1625463369.449:144): pid=3752 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="angie" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Jul 05 07:36:09 lenovo-yoga-angie dbus-daemon[462]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.129' (uid=0 pid=3752 comm="sudo journalctl -b ")
Jul 05 07:36:09 lenovo-yoga-angie dbus-daemon[462]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Jul 05 07:36:09 lenovo-yoga-angie sudo[3752]: pam_systemd_home(sudo:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Jul 05 07:36:09 lenovo-yoga-angie kernel: audit: type=1101 audit(1625463369.453:145): pid=3752 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="angie" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Jul 05 07:36:09 lenovo-yoga-angie kernel: audit: type=1110 audit(1625463369.453:146): pid=3752 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Jul 05 07:36:09 lenovo-yoga-angie kernel: audit: type=1105 audit(1625463369.453:147): pid=3752 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Jul 05 07:36:09 lenovo-yoga-angie audit[3752]: USER_ACCT pid=3752 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="angie" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Jul 05 07:36:09 lenovo-yoga-angie audit[3752]: CRED_REFR pid=3752 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Jul 05 07:36:09 lenovo-yoga-angie audit[3752]: USER_START pid=3752 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Jul 05 07:36:09 lenovo-yoga-angie sudo[3752]: angie : TTY=pts/2 ; PWD=/home/angie ; USER=root ; COMMAND=/usr/bin/journalctl -b
Jul 05 07:36:09 lenovo-yoga-angie sudo[3752]: pam_unix(sudo:session): session opened for user root(uid=0) by angie(uid=1000)
What further information should I provide?
I’m grateful there is something like this forum to help me fix these issues since I’m not planning on leaving Linux anytime soon!
(And please help me to get my girlfriend to stick around, too
