Lenovo V14-IIL brightness keys not working, also an issue with charging
Lenovo v14 laptop
Im gonna be brief. when i first installed manjaro everything was working great. until 2 issues popped up: at first the 2 buttons which controlled screen brightness worked then stopped working on their own and serve no function when pressed. (unless you count them being function keys)
the other issue which also popped up randomly is that, the system now takes a while to recognize that the laptop is or isnt being charged, it would say “discharging” but still think its plugged in. this also popped up on its own with no settings being changed. even though it used to work fine.
these 2 issues have popped up about a day after installation. i tried switching kernels (6.1, 6.16 and im on 6.12)
Nothing changed. Any help would be appreciated
  Kernel: 6.12.44-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=2f33c2ad-8df3-46c6-836b-0a9b10b9efe5 rw rootflags=subvol=@
  Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.17.0
  Type: Laptop System: LENOVO product: 82C4 v: Lenovo V14-IIL
    serial: <superuser required> Chassis: type: 10 v: Lenovo V14-IIL
  Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
    part-nu: LENOVO_MT_82C4_BU_idea_FM_V14-IIL uuid: <superuser required>
    UEFI: LENOVO v: DKCN55WW date: 05/24/2022
  ID-1: BAT0 charge: 14.6 Wh (100%) condition: 14.6/35 Wh (41.7%) volts: 8.41
    min: 7.6 model: LGC L16L2PB3 type: Li-poly serial: <filter> charging:
    status: full cycles: 329
  System RAM: total: 12 GiB available: 11.48 GiB used: 2.4 GiB (20.9%)
  Array-1: capacity: 16 GiB note: est. slots: 2 modules: 2 EC: None
  Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 8 GiB
    speed: 2667 MT/s volts: curr: 1 width (bits): data: 64 total: 64
    manufacturer: Micron part-no: 8ATF1G64HZ-3G2R1 serial: <filter>
  Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 4 GiB
    speed: 2667 MT/s volts: curr: 1 min: 2 max: 2 width (bits): data: 64
    total: 64 manufacturer: Samsung part-no: M471A5244CB0-CTD serial: N/A
  Info: model: Intel Core i3-1005G1 bits: 64 type: MT MCP arch: Ice Lake
    gen: core 10 level: v4 note: check built: 2019-21 process: Intel 10nm
    family: 6 model-id: 0x7E (126) stepping: 5 microcode: 0xCA
  Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
    smt: enabled cache: L1: 160 KiB desc: d-2x48 KiB; i-2x32 KiB L2: 1024 KiB
    desc: 2x512 KiB L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 400 min/max: 400/3400 scaling: driver: intel_pstate
    governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 bogomips: 9524
    arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
    avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts clflush clflushopt cmov
    constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
    ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fsrm
    fxsr gfni ht hwp hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs
    ibrs_enhanced ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx
    monitor movbe msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
    pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid
    rdrand rdseed rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect
    ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
    tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
    vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
    xtpr
  Type: indirect_target_selection mitigation: Aligned branch/return thunks
  Type: retbleed mitigation: Enhanced IBRS
    conditional; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
  Device-1: Intel Iris Plus Graphics G1 vendor: Lenovo driver: i915 v: kernel
    arch: Gen-11 process: Intel 10nm built: 2019-21 ports: active: eDP-1
    empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:8a56 class-ID: 0300
  Device-2: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:2 chip-ID: 04f2:b624
    alternate: fbdev,vesa dri: iris gpu: i915 display-ID: 0
  Monitor-1: eDP-1 model: AU Optronics 0x203d built: 2018 res:
    mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 158 gamma: 1.2 chroma: red:
    x: 0.569 y: 0.341 green: x: 0.349 y: 0.573 blue: x: 0.161 y: 0.122 white:
    x: 0.314 y: 0.329 size: 309x174mm (12.17x6.85") diag: 355mm (14")
    ratio: 16:9 modes: 1920x1080
    drv: iris x11: drv: iris
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.2.1-arch1.4
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (ICL GT1)
    device-ID: 8086:8a56 memory: 11.21 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.4.321 layers: N/A device: 0 type: integrated-gpu
    name: Intel UHD Graphics (ICL GT1) driver: mesa intel v: 25.2.1-arch1.4
    device-ID: 8086:8a56 surfaces: N/A
  Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Lenovo
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_icl
    bus-ID: 00:1f.3 chip-ID: 8086:34c8 class-ID: 0403
  API: ALSA v: k6.12.44-3-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.7 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
    vendor: Lenovo driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 01:00.0 chip-ID: 10ec:c82f
    class-ID: 0280
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:4 chip-ID: 0bda:c02f
  Local Storage: total: 698.65 GiB used: 35.88 GiB (5.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT250P2SSD8
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: P2CR048 temp: 35.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WD5000LPVX-80V0TT0 size: 465.76 GiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
    fw-rev: 1A01 scheme: MBR
  ID-1: / raw-size: 91.94 GiB size: 91.94 GiB (100.00%)
    used: 35.82 GiB (39.0%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
    label: N/A uuid: 2f33c2ad-8df3-46c6-836b-0a9b10b9efe5
    used: 63.1 MiB (65.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: N/A uuid: 4E7C-E484
  ID-3: /home raw-size: 91.94 GiB size: 91.94 GiB (100.00%)
  ID-4: /var/cache raw-size: 91.94 GiB size: 91.94 GiB (100.00%)
  ID-5: /var/log raw-size: 91.94 GiB size: 91.94 GiB (100.00%)
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 115.39 GiB fs: ntfs
    label: Operating System uuid: 4A62A23862A22921
  ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 957 MiB fs: ntfs label: N/A
    uuid: 5814CFF214CFD0E4
  ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 24.51 GiB fs: ntfs label: Data
    uuid: 2298AFEF98AFC021
  ID-5: /dev/sda1 maj-min: 8:1 size: 465.76 GiB fs: ntfs label: Personal HDD
    uuid: BEB4C9A4B4C9600F
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-5:2 info: Chicony Integrated Camera type: video
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 04f2:b624 class-ID: 0e02
    serial: <filter>
  Device-2: 1-9:3 info: USB OPTICAL MOUSE type: mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1
    chip-ID: 30fa:0400 class-ID: 0301
  Device-3: 1-10:4 info: Realtek Bluetooth Radio type: bluetooth
    driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 0bda:c02f class-ID: e001 serial: <filter>
  Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
  System Temperatures: cpu: 49.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: 1258 pm: pacman pkgs: 1242 libs: 325 tools: pamac pm: flatpak
    pkgs: 16
    1: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    2: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
Processes:
  CPU top: 5 of 218
  1: cpu: 14.2% command: firefox pid: 1209 mem: 477.6 MiB (4.0%)
  2: cpu: 9.4% command: konsole pid: 1863 mem: 174.3 MiB (1.4%)
  3: cpu: 5.5% command: firefox pid: 1486 mem: 331.9 MiB (2.8%)
  4: cpu: 5.3% command: firefox pid: 1451 mem: 248.4 MiB (2.1%)
  5: cpu: 5.2% command: [irq/9-acpi] pid: 58 mem: 0.00 MiB (0.0%)
  Memory top: 5 of 218
  1: mem: 477.6 MiB (4.0%) command: firefox pid: 1209 cpu: 14.2%
  2: mem: 331.9 MiB (2.8%) command: firefox pid: 1486 cpu: 5.5%
  3: mem: 275.7 MiB (2.3%) command: plasmashell pid: 830 cpu: 2.9%
  4: mem: 248.4 MiB (2.1%) command: firefox pid: 1451 cpu: 5.3%
  5: mem: 246.8 MiB (2.0%) command: firefox pid: 1597 cpu: 3.1%
  Processes: 218 Power: uptime: 2m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 4.58 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: clang: 20.1.8 gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: konsole
    inxi: 3.3.39
Welcome to the Manjaro community @Slate
Update Announcements
System Information
inxi --filter --verbosity=8
inxi -zv8
Required reading
Resources
Thanks for the warm welcome.
Unfortunately i cant post the return of the command because it has links. Even when i remove them it still says it has links.
You can if you format it correctly - my previous reply did have a link to: How to Post Command Output as Preformatted Test
Paste the inxi output into a reply, highlight all of the text, and click the </> button at the top of the edit box. That will format your output as code.
Alternatively, paste the output into a reply, and type 3 backticks (```) on blank lines before and after the inxi output.
Thanks alot! i just edited the post and added the info.
