Hello, i noticed that i was having some kernel errors (specifically related with tp-smapi-dkms and acpi-call-dkms) i couldn’t solve them so i decided to install again the OS, and now i have realized that this errors just come right out of the box, im using the gnome version. i hope you can help me to solve this
Cita
l> gtegetege@lgtegetege Linux 5.8.11-1-MANJARO x86_64 20.1.1 Mikah
~ >>> sudo journalctl -p 3 -xb
[sudo] password for lgtegetege:
– Logs begin at Thu 2020-10-22 17:01:35 CDT, end at Thu 2020-10-22 17:24:40 CDT. –
Oct 22 17:01:35 lgtegetege kernel: ACPI Error: Needed [Integer/String/Buffer], found [Package] 0000000003c681ad (20200528/exresop-469)
Oct 22 17:01:35 lgtegetege kernel: ACPI Error: AE_AML_OPERAND_TYPE, While resolving operands for [ToHexString] (20200528/dswexec-431)
Oct 22 17:01:35 lgtegetege kernel: ACPI Error: Aborting method \ADBG due to previous error (AE_AML_OPERAND_TYPE) (20200528/psparse-529)
Oct 22 17:01:35 lgtegetege kernel: ACPI Error: Aborting method _SB.HIDD._DSM due to previous error (AE_AML_OPERAND_TYPE) (20200528/psparse-529)
Oct 22 17:01:35 lgtegetege kernel: i801_smbus 0000:00:1f.4: Transaction timeout
Oct 22 17:01:35 lgtegetege kernel: i801_smbus 0000:00:1f.4: Failed terminating the transaction
Oct 22 17:01:35 lgtegetege kernel: i801_smbus 0000:00:1f.4: SMBus is busy, can’t use it!
Oct 22 17:01:37 lgtegetege kernel: sof-audio-pci 0000:00:1f.3: error: request firmware intel/sof/sof-cml.ri failed err: -2
Oct 22 17:01:37 lgtegetege kernel: sof-audio-pci 0000:00:1f.3: error: failed to load DSP firmware -2
Oct 22 17:01:37 lgtegetege kernel: sof-audio-pci 0000:00:1f.3: error: sof_probe_work failed err: -2
Oct 22 17:01:38 lgtegetege wpa_supplicant[1281]: nl80211: kernel reports: Attribute failed policy validation
Oct 22 17:01:38 lgtegetege wpa_supplicant[1281]: Failed to create interface p2p-dev-wlp0s20f3: -22 (Invalid argument)
Oct 22 17:01:38 lgtegetege wpa_supplicant[1281]: nl80211: Failed to create a P2P Device interface p2p-dev-wlp0s20f3
Oct 22 17:02:38 lgtegetege gdm-password][1568]: gkr-pam: unable to locate daemon control file
Oct 22 17:02:40 lgtegetege bluetoothd[900]: src/profile.c:ext_start_servers() RFCOMM server failed for Headset Voice gateway: rfcomm_bind: Address already in use (98)
Oct 22 17:02:40 lgtegetege bluetoothd[900]: src/profile.c:ext_start_servers() RFCOMM server failed for Headset unit: rfcomm_bind: Address already in use (98)
Oct 22 17:02:44 lgtegetege bluetoothd[900]: src/profile.c:ext_start_servers() RFCOMM server failed for Headset Voice gateway: rfcomm_bind: Address already in use (98)
Oct 22 17:02:44 lgtegetege bluetoothd[900]: src/profile.c:ext_start_servers() RFCOMM server failed for Headset unit: rfcomm_bind: Address already in use (98)
