Hello everybody,
I got a new Lenovo Laptop and set it up with Manjaro and Gnome desktop. Everything works fine so far but my camera. Neither in Teams not in Gnome’s camera app I get anything to see - only black.
I have no clue what might be wrong - here is what I investigated based on other threads:
[gatt@ChillTortoise ~]$ v4l2-ctl --list-devices
Integrated Camera: Integrated C (usb-0000:00:14.0-4):
/dev/video0
/dev/video1
/dev/video2
/dev/video3
/dev/media0
/dev/media1
Also I tried:
[gatt@ChillTortoise ~]$ lsmod | grep uv
uvcvideo 180224 1
videobuf2_vmalloc 20480 18 uvcvideo
uvc 12288 1 uvcvideo
videobuf2_v4l2 40960 1 uvcvideo
videobuf2_common 94208 4 videobuf2_vmalloc,videobuf2_v4l2,uvcvideo,videobuf2_memops
videodev 393216 3 videobuf2_v4l2,uvcvideo
mc 90112 5 videodev,snd_usb_audio,videobuf2_v4l2,uvcvideo,videobuf2_common
drm_gpuvm 45056 1 xe
drm_exec 12288 2 drm_gpuvm,xe
and here is the inxi output for my new laptop
[gatt@ChillTortoise ~]$ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=13961bbc-0359-4bca-8dfc-9204ebc8aa8a rw quiet
cryptdevice=UUID=8614b4b3-7447-44d2-baf7-d9e532e14cdc:luks-8614b4b3-7447-44d2-baf7-d9e532e14cdc
root=/dev/mapper/luks-8614b4b3-7447-44d2-baf7-d9e532e14cdc splash
apparmor=1 security=apparmor
resume=/dev/mapper/luks-eea7f0a9-4246-40bf-bd97-9d25e0bb2ee2
udev.log_priority=3
Desktop: GNOME v: 47.2 tk: GTK v: 3.24.43 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 47.0 Distro: Manjaro base: Arch Linux
Type: Laptop System: LENOVO product: 21HH003AGE v: ThinkPad T16 Gen 2
Mobo: LENOVO model: 21HH003AGE v: SDK0T76530 WIN
serial: <superuser required> part-nu: LENOVO_MT_21HH_BU_Think_FM_ThinkPad
T16 Gen 2 uuid: <superuser required> UEFI: LENOVO v: N3QET44W (1.44 )
date: 03/13/2024
ID-1: BAT0 charge: 52.9 Wh (99.8%) condition: 53.0/52.5 Wh (101.0%)
volts: 17.6 min: 15.5 model: Sunwoda 5B10W51870 type: Li-poly
serial: <filter> status: full cycles: 9
Device-1: hid-f4:73:35:90:eb:46-battery model: Keyboard K380 serial: N/A
charge: N/A status: discharging
Device-2: hidpp_battery_1 model: Logitech MX Master 3S serial: <filter>
charge: 15% rechargeable: yes status: discharging
System RAM: total: 16 GiB available: 15.29 GiB used: 12.34 GiB (80.7%)
Array-1: capacity: 32 GiB slots: 2 modules: 1 EC: None
Device-1: Controller0-ChannelA type: DDR5 detail: synchronous size: 16 GiB
speed: spec: 5600 MT/s actual: 5200 MT/s volts: curr: 1 width (bits):
data: 64 total: 64 manufacturer: SK Hynix part-no: HMCG78AGBSA092N
serial: N/A
Device-2: Controller1-ChannelA/B-DIMM0 type: no module installed
Info: model: 13th Gen Intel Core i7-1355U bits: 64 type: MST AMCP
arch: Raptor Lake level: v3 note: check built: 2022+ process: Intel 7 (10nm)
family: 6 model-id: 0xBA (186) stepping: 3 microcode: 0x4123
Topology: cpus: 1x dies: 1 clusters: 4 cores: 10 threads: 12 mt: 2 tpc: 2
st: 8 smt: enabled cache: L1: 928 KiB desc: d-8x32 KiB, 2x48 KiB; i-2x32
KiB, 8x64 KiB L2: 6.5 MiB desc: 2x1.2 MiB, 2x2 MiB L3: 12 MiB
desc: 1x12 MiB
Speed (MHz): avg: 609 min/max: 400/5000:3700 scaling: driver: intel_pstate
governor: powersave cores: 1: 609 2: 609 3: 609 4: 609 5: 609 6: 609 7: 609
8: 609 9: 609 10: 609 11: 609 12: 609 bogomips: 62688
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pclmulqdq pdcm pdpe1gb pebs
pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp rep_good
sdbg sep serialize sha_ni smap smep smx split_lock_detect ss ssbd sse sse2
tsc_deadline_timer tsc_known_freq umip user_shstk vaes vme vmx vnmi
vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec xsaveopt xsaves
xtopology xtpr
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: Intel Raptor Lake-P [UHD Graphics] vendor: Lenovo driver: i915
v: kernel alternate: xe arch: Xe process: Intel 10nm built: 2020-21 ports:
active: DP-5,DP-7,eDP-1 empty: DP-1, DP-2, DP-3, DP-4, DP-6, HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:a721 class-ID: 0300
Device-2: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:3 chip-ID: 04f2:b7c0
Display: wayland server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: DP-5 model: ASUS VG289 serial: <filter> built: 2022
res: 3840x2160 dpi: 157 gamma: 1.2 size: 621x341mm (24.45x13.43")
diag: 708mm (27.9") ratio: 16:9 modes: max: 3840x2160 min: 640x480
Monitor-2: DP-7 model: ASUS VG289 serial: <filter> built: 2023
Monitor-3: eDP-1 model: AU Optronics 0x8b9b built: 2021 res: 1920x1200
dpi: 142 gamma: 1.2 size: 344x215mm (13.54x8.46") diag: 406mm (16")
ratio: 16:10 modes: 1920x1200
drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.8-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (RPL-U)
device-ID: 8086:a721 memory: 7.46 GiB unified: yes display-ID: :0.0
Info: Tools: api: eglinfo,glxinfo x11: xprop
Device-1: Intel Raptor Lake-P/U/H cAVS vendor: Lenovo
driver: sof-audio-pci-intel-tgl alternate: snd_hda_intel, snd_soc_avs,
snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:51ca class-ID: 0403
Device-2: GN Netcom Jabra Link 380 driver: jabra,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-6.1.3.4.1:20
chip-ID: 0b0e:24c9 class-ID: 0300 serial: <filter>
Device-3: Lenovo ThinkPad USB-C Dock Audio
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-6.2:15 chip-ID: 17ef:30b0 class-ID: 0300
serial: <filter>
API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
Device-1: Intel Raptor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:51f1 class-ID: 0280
IF: wlp0s20f3 state: down mac: <filter>
Device-2: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:0dc6 class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-3: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
rev: 3.2 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-3.1:5
chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp0s13f0u3u1 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:21 chip-ID: 8087:0033
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Device-1: luks-8614b4b3-7447-44d2-baf7-d9e532e14cdc maj-min: 254:0
type: LUKS dm: dm-0 size: 459.83 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 459.83 GiB
Device-2: luks-eea7f0a9-4246-40bf-bd97-9d25e0bb2ee2 maj-min: 254:1
type: LUKS dm: dm-1 size: 16.81 GiB
Components:
p-1: nvme0n1p3 maj-min: 259:3 size: 16.82 GiB
Local Storage: total: 476.94 GiB used: 64.64 GiB (13.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFS512GEJ9X164N
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 51770C30 temp: 33.9 C
scheme: GPT
ID-1: / raw-size: 459.83 GiB size: 451.54 GiB (98.20%)
used: 61.84 GiB (13.7%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-8614b4b3-7447-44d2-baf7-d9e532e14cdc label: N/A
uuid: 13961bbc-0359-4bca-8dfc-9204ebc8aa8a
used: 448 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: E746-7F67
ID-1: swap-1 type: partition size: 16.81 GiB used: 2.8 GiB (16.6%)
priority: -2 dev: /dev/dm-1 maj-min: 254:1
mapped: luks-eea7f0a9-4246-40bf-bd97-9d25e0bb2ee2 label: swap
uuid: e210d676-8a12-47cc-a223-cca67ec6519c
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: super-speed hub ports: 3 rev: 3.1
Hub-3: 2-3:2 info: Lenovo USB3.1 Hub ports: 4 rev: 3.2
speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: 17ef:30ab
Device-1: 2-3.1:5 info: Realtek RTL8153 Gigabit Ethernet Adapter
type: Network driver: r8152 interfaces: 1 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 112mA
Hub-4: 2-3.3:4 info: Lenovo USB3.1 Hub ports: 4 rev: 3.2
speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: 17ef:30ad
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-3:2 info: Shenzhen Goodix USB2.0 MISC type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 100mA chip-ID: 27c6:6594 class-ID: ef00 serial: <filter>
Device-2: 3-4:3 info: Chicony Integrated Camera type: video
driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 04f2:b7c0 class-ID: fe01 serial: <filter>
Hub-6: 3-6:13 info: Lenovo USB2.0 Hub ports: 3 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 17ef:30af
Hub-7: 3-6.1:14 info: Lenovo USB2.0 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 17ef:30ac
Hub-8: 3-6.1.3:17 info: Lenovo USB2.0 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 17ef:30ae
Device-1: 3-6.1.3.2:18 info: Logitech Logi Bolt Receiver
type: keyboard,mouse,HID driver: hid-generic,hid-multitouch,usbhid
interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 98mA chip-ID: 046d:c548 class-ID: 0300
Hub-9: 3-6.1.3.4:19 info: Cambridge Silicon Radio Mpow HC5 Headset in
charging mode - USB Hub ports: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 0a12:4010 class-ID: 0900
Device-1: 3-6.1.3.4.1:20 info: GN Netcom Jabra Link 380 type: audio,HID
driver: jabra,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 0b0e:24c9
Device-2: 3-6.2:15 info: Lenovo ThinkPad USB-C Dock Audio type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 30mA
chip-ID: 17ef:30b0 class-ID: 0300 serial: <filter>
Device-3: 3-6.3:16 info: Lenovo 40AY type: billboard driver: N/A
chip-ID: 17ef:30a9 class-ID: 1100 serial: <filter>
Device-4: 3-8:4 info: Alcor Micro AU9540 Smartcard Reader type: smart card
mode: 1.1 power: 50mA chip-ID: 058f:9540 class-ID: 0b00
Device-5: 3-10:21 info: Intel AX211 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0033 class-ID: e001
Hub-10: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
System Temperatures: cpu: 46.0 C mobo: N/A
Fan Speeds (rpm): fan-1: 1884
Processes: 418 Power: uptime: 1d 20h 34m states: freeze,mem,disk
suspend: s2idle wakeups: 7 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 6.1 GiB services: gsd-power,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Packages: 1193 pm: pacman pkgs: 1186 libs: 344 tools: gnome-software,pamac
pm: flatpak pkgs: 0 pm: snap pkgs: 7 Compilers: gcc: 14.2.1 Shell: Bash
v: 5.2.37 running-in: gnome-terminal inxi: 3.3.37
Thanks for any help…
Thorsten
Mod edit:- Spelling; assuming you meant Gnome.
