KDE Plasma Version: 6.2.4
KDE Frameworks Version: 6.8.0
Qt Version: 6.8.1
Kernel Version: 6.11.10-2-MANJARO (64-bit)
Graphics Platform: X11
The F1 to F12 are mapped secondary (from their printing) with:
F1: Mute
F2: decrease volume
F3: increase volume
F4: Mute Mic
F5: decrease brightness
F6: increase brightness
F7: add external monitor?
F8: Flight mode
F9: Print
F10: Snipping Tool
F11: add external monitor version 2?
F12: Favorite
The secondary mapping from F1 to F9 and F12 work as expected.
But I cannot use the secondary mapping of F10 and F11.
They even have no function by default, I cannot use them to add them as a keyboard shortcut for something.
I thought I have used the secondary mapping of F11 before, but I’m not quite sure and I cannot validate it.
Has somebody the same problem? I already tried using FnLock and have set the secondary mapping of the F1 to F12 as primary, nothing helped.
I may be able to help with that…assuming they’re not internal to the laptop.
First we need to figure out what, if anything, is being sent to the computer. I prefer evtest which isn’t installed by default (Ctrl + C or Ctrl + Alt + C to exit evtest).
The keyboard may have more than one interface, so try each one until you get a response.
Once we know what’s being sent, we may be able to remap each key to something that can be bound to a shortcut. There are several input remapping utilities:
At least with the snipping tool, the problem is it sends by default several keys at once, and you guessed it - a windows shortcut. So one have to sniff with something and remap a shortcut accordingly. I do not remember anymore because i did this hoop jumping last year. I can check later at home. I think at least one of the keys sends an alt key combo so some DEs may refuse to remap with alt (because it will be doubled).
My keyboard is a bit different, it shows a scissor on the print screen key above backspace.
And in my shortcuts i see shift-ctrl-print and shift-super-s for the screenshot action - i think one it the default and the other is using this key (for clarity - i press only this key and it sends all 3 other keys to the OS and starts the screenshot tool)
