Lenovo Legion fresh installation some problems
Hello, I have a lenovo legion 7i slim, my sound card does not give sound to the outside. I am using manjaro latest version. can you help me?
my computer Legion S7 16IAH7
aplay -l
**** List of PLAYBACK Hardware Devices ****
card 1: sofhdadsp [sof-hda-dsp], device 0: HDA Analog (*) []
  Subdevices: 0/1
  Subdevice #0: subdevice #0
card 1: sofhdadsp [sof-hda-dsp], device 3: HDMI1 (*) []
  Subdevices: 1/1
card 1: sofhdadsp [sof-hda-dsp], device 4: HDMI2 (*) []
  Subdevices: 1/1
card 1: sofhdadsp [sof-hda-dsp], device 5: HDMI3 (*) []
  Subdevices: 1/1
card 1: sofhdadsp [sof-hda-dsp], device 31: HDA Analog Deep Buffer (*) []
  Subdevices: 1/1
inxi -A
  Device-1: Intel Alder Lake PCH-P High Definition Audio
    driver: sof-audio-pci-intel-tgl
  API: ALSA v: k6.1.30-1-MANJARO status: kernel-api
  Server-1: PulseAudio v: 16.1 status: active
lspci -v | grep -A7 -i audio
00:1f.3 Multimedia audio controller: Intel Corporation Alder Lake PCH-P High Definition Audio Controller (rev 01)
	Subsystem: Lenovo Device 388e
	Flags: bus master, fast devsel, latency 64, IRQ 209, IOMMU group 15
	Memory at 612d188000 (64-bit, non-prefetchable) [size=16K]
	Memory at 612d000000 (64-bit, non-prefetchable) [size=1M]
	Capabilities: <access denied>
	Kernel driver in use: sof-audio-pci-intel-tgl
	Kernel modules: snd_hda_intel, snd_sof_pci_intel_tgl
00:1f.4 SMBus: Intel Corporation Alder Lake PCH-P SMBus Host Controller (rev 01)
	Subsystem: Lenovo Device 381e
	Flags: medium devsel, IRQ 16, IOMMU group 15
	Memory at 612d194000 (64-bit, non-prefetchable) [size=256]
	I/O ports at efa0 [size=32]
Also I see the following error in dmesg how do I know if everything is ok with my computer?
dmesg-1
[    1.339523] blacklist: Problem blacklisting hash (-13)
[    1.339525] blacklist: Problem blacklisting hash (-13)
[    1.339526] blacklist: Problem blacklisting hash (-13)
[    1.339527] blacklist: Problem blacklisting hash (-13)
[    1.339528] blacklist: Problem blacklisting hash (-13)
[    1.339529] blacklist: Problem blacklisting hash (-13)
[    1.339530] blacklist: Problem blacklisting hash (-13)
[    1.339531] blacklist: Problem blacklisting hash (-13)
[    1.339532] blacklist: Problem blacklisting hash (-13)
[    1.339533] blacklist: Problem blacklisting hash (-13)
[    1.339534] blacklist: Problem blacklisting hash (-13)
[    1.339535] blacklist: Problem blacklisting hash (-13)
[    1.339536] blacklist: Problem blacklisting hash (-13)
[    1.339537] blacklist: Problem blacklisting hash (-13)
[    1.339538] blacklist: Problem blacklisting hash (-13)
[    1.339539] blacklist: Problem blacklisting hash (-13)
[    1.339540] blacklist: Problem blacklisting hash (-13)
[    1.339541] blacklist: Problem blacklisting hash (-13)
[    1.339542] blacklist: Problem blacklisting hash (-13)
[    1.339543] blacklist: Problem blacklisting hash (-13)
[    1.339544] blacklist: Problem blacklisting hash (-13)
dmesg-2
[    0.228357] ACPI BIOS Error (bug): AE_AML_BUFFER_LIMIT, Field [FRD0] at bit offset/length 0/32 exceeds size of target Buffer (16 bits) (20220331/dsopcode-198)
[    0.228364] ACPI BIOS Error (bug): AE_AML_BUFFER_LIMIT, Field [FRD1] at bit offset/length 16/32 exceeds size of target Buffer (16 bits) (20220331/dsopcode-198)
[    0.275413] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.I2C0.TPD0], AE_NOT_FOUND (20220331/dswload2-162)
[    0.275417] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20220331/psobject-220)
[    0.275418] ACPI: Skipping parse of AML opcode: Scope (0x0010)
[    0.285153] ACPI: 21 ACPI AML tables successfully acquired and loaded
[    0.285611] ACPI Error: AE_TYPE, Opcode is not deferred [FRD0] (BufferField) (20220331/nsinit-411)
[    0.285612] ACPI Error: AE_TYPE, Could not execute arguments for [FRD0] (BufferField) (20220331/nsinit-419)
[    0.285613] ACPI Error: AE_TYPE, Opcode is not deferred [FRD1] (BufferField) (20220331/nsinit-411)
[    0.285614] ACPI Error: AE_TYPE, Could not execute arguments for [FRD1] (BufferField) (20220331/nsinit-419)
dmesg-3
[    8.609082] RIP: 0010:intel_pps_vdd_on_unlocked+0x2ac/0x2c0 [i915]
[    8.609353] Code: 4c 8b 67 50 4d 85 e4 75 03 4c 8b 27 e8 5d aa cc d7 48 c7 c1 78 b5 5a c1 4c 89 e2 48 c7 c7 fd ee 5b c1 48 89 c6 e8 b4 af 58 d7 <0f> 0b e9 e7 fd ff ff e8 d8 0f 13 d8 0f 1f 84 00 00 00 00 00 66 0f
[    8.609357] RSP: 0018:ffffab5003ed75c0 EFLAGS: 00010286
[    8.609363] RAX: 0000000000000000 RBX: ffff8b9ca1cf0170 RCX: 0000000000000027
[    8.609366] RDX: ffff8b9fff721668 RSI: 0000000000000001 RDI: ffff8b9fff721660
[    8.609369] RBP: ffff8b9ca3d30000 R08: 0000000000000000 R09: ffffab5003ed7438
[    8.609372] R10: 0000000000000003 R11: ffff8ba00fba8fe8 R12: ffff8b9c830356c0
[    8.609374] R13: 0000000000000005 R14: ffff8b9ca3d31c20 R15: 0000000000000000
[    8.609377] FS:  00007fab3ee69080(0000) GS:ffff8b9fff700000(0000) knlGS:0000000000000000
[    8.609381] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[    8.609384] CR2: 0000561285d98530 CR3: 000000010604e002 CR4: 0000000000f70ee0
[    8.609387] PKRU: 55555554
[    8.609390] Call Trace:
[    8.609395]  <TASK>
[    8.609399]  ? __intel_display_power_get_domain.part.0+0x52/0x70 [i915 6427af4eba0d34f83e5043c37ff2f60d96fdf93f]
[    8.609700]  ? intel_display_power_get+0x52/0x60 [i915 6427af4eba0d34f83e5043c37ff2f60d96fdf93f]
[    8.609992]  intel_dp_aux_xfer+0x127/0x7a0 [i915 6427af4eba0d34f83e5043c37ff2f60d96fdf93f]
[    8.610256]  ? enqueue_hrtimer+0x2f/0x80
[    8.610268]  ? schedule_hrtimeout_range_clock+0xe3/0x120
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
Try switching to PipeWire audio instead of PulseAudio. remove package manjaro-pulse and install manjaro-pipewire
