Hi, great community of Manjaro!
Among other problems with running Manjaro on Lenovo Legion 7 Pro, the one that troubles the most is inability to suspend it.
First of all, I installed optimus-manager with a hope to be able to seamlessly switch between integrated and nvidia graphics cards, but this will wait for some time because I can’r run external displays without nvidia, but that story is for some other topic.
So, I’m running optimus with nvidia as my usual mode. When I try to suspend the notebook (either by closing the lid or clicking suspend), notebook looks like it’s going to sleep, but it wakes up few seconds later with sddm login screen. After login, integrated graphics card is active.
I captured full journalctl from suspend attempt to waking up:
I’m running xorg since I have stability issues with Wayland.
Any help in journalctl log decypher and suggestions would be great.
My system info:
eden@echo:[~]: inxi -Fazy
Kernel: 6.7.7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet avail: acpi_pm
parameters: BOOT_IMAGE=/boot/vmlinuz-6.7-x86_64
root=UUID=a340900a-5d25-4116-ae33-86942b95dca6 rw quiet
cryptdevice=UUID=acc2baf7-f037-4bb7-8dc7-682bea6d1aad:luks-acc2baf7-f037-4bb7-8dc7-682bea6d1aad
root=/dev/mapper/luks-acc2baf7-f037-4bb7-8dc7-682bea6d1aad splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.11 tk: Qt v: 5.15.12 info: frameworks
v: 5.115.0 wm: kwin_x11 vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
Type: Laptop System: LENOVO product: 82WS v: Legion Pro 7 16ARX8H
serial: <superuser required> Chassis: type: 10 v: Legion Pro 7 16ARX8H
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
part-nu: LENOVO_MT_82WS_BU_idea_FM_Legion Pro 7 16ARX8H
uuid: <superuser required> UEFI: LENOVO v: LPCN49WW date: 01/10/2024
ID-1: BAT0 charge: 102.5 Wh (99.0%) condition: 103.5/99.9 Wh (103.6%)
volts: 17.7 min: 15.5 model: SMP L22M4PC1 type: Li-poly serial: <filter>
status: full cycles: 5
Device-1: hidpp_battery_2 model: Logitech Wireless Mouse MX Master 3
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
Info: model: AMD Ryzen 9 7945HX with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 4 gen: 5 level: v4 note: check built: 2022+ process: TSMC n5 (5nm)
family: 0x19 (25) model-id: 0x61 (97) stepping: 2 microcode: 0xA601206
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 16 MiB desc: 16x1024 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 858 high: 3492 min/max: 400/5461 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 400 2: 3254 3: 400
4: 400 5: 3492 6: 400 7: 3446 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400
14: 3481 15: 2994 16: 400 17: 400 18: 400 19: 400 20: 400 21: 400 22: 400
23: 400 24: 400 25: 400 26: 400 27: 400 28: 400 29: 400 30: 400 31: 400
32: 400 bogomips: 159765
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA AD104M [GeForce RTX 4080 Max-Q / Mobile] vendor: Lenovo
driver: nvidia v: 550.54.14 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-02) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 2 speed: 5 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: none off: DP-3 empty: DP-1,
DP-2, HDMI-A-1, eDP-2 bus-ID: 01:00.0 chip-ID: 10de:27e0 class-ID: 0300
Device-2: AMD Raphael vendor: Lenovo driver: amdgpu v: kernel arch: RDNA-2
code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: none bus-ID: 05:00.0
chip-ID: 1002:164e class-ID: 0300 temp: 59.0 C
Device-3: Luxvisions Innotech Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2.4:4
chip-ID: 30c9:00ac class-ID: fe01 serial: <filter>
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.4
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia dri: radeonsi
gpu: amdgpu,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 6400x2160 s-dpi: 96 s-size: 1691x571mm (66.57x22.48")
s-diag: 1785mm (70.27")
Monitor-1: DP-3 mapped: DP-5 note: disabled pos: primary,top-left
model: LG (GoldStar) HDR 4K serial: <filter> built: 2022 res: 3840x2160
hz: 60 dpi: 140 gamma: 1.2 size: 697x392mm (27.44x15.43")
diag: 806mm (31.7") ratio: 16:9 modes: max: 3840x2160 min: 640x480
Monitor-2: eDP-1 mapped: eDP-1-1 pos: bottom-r model: BOE Display 0x0b11
serial: <filter> built: 2022 res: 2560x1600 hz: 240 dpi: 188 gamma: 1.2
size: 345x215mm (13.58x8.46") diag: 407mm (16") ratio: 16:10 modes:
max: 2560x1600 min: 640x480
API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
drv: nvidia device: 1 drv: radeonsi device: 3 drv: swrast surfaceless:
drv: nvidia x11: drv: nvidia inactive: gbm,wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.54.14
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4080 Laptop
GPU/PCIe/SSE2 memory: 11.71 GiB
API: Vulkan v: 1.3.279 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 4080 Laptop GPU driver: nvidia v: 550.54.14
device-ID: 10de:27e0 surfaces: xcb,xlib device: 1 type: integrated-gpu
name: AMD Radeon Graphics (RADV RAPHAEL_MENDOCINO) driver: mesa radv
v: 24.0.2-manjaro1.1 device-ID: 1002:164e surfaces: xcb,xlib
Device-1: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:22bc class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo
driver: snd_rpl_pci_acp6x v: kernel alternate: snd_pci_acp3x,
snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
snd_sof_amd_acp63 pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 05:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 05:00.6
chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.7.7-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
Device-1: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
vendor: Lenovo driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 03:00.0 chip-ID: 14c3:0616 class-ID: 0280
vendor: Lenovo RTL8111/8168/8411 driver: r8168 v: 8.052.01-NAPI
modules: r8169 pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000
bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: down mac: <filter>
IF-ID-1: br-f5e45f322306 state: down mac: <filter>
IF-ID-2: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-3: veth2e2a7fe state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-4: veth5a2f728 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-5: vethabffa45 state: up speed: 10000 Mbps duplex: full mac: <filter>
Info: services: NetworkManager, ntpd, sshd, systemd-timesyncd,
wpa_supplicant
Device-1: Foxconn / Hon Hai Bluetooth Adapter driver: btusb v: 0.8 type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1.1:3
chip-ID: 0489:e0d8 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 4 state: up address: see --recommends
Local Storage: total: 953.87 GiB used: 226.36 GiB (23.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVL21T0HCLR-00BL2
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: EL1QGXA7 temp: 45.9 C
scheme: GPT
ID-1: / raw-size: 953.57 GiB size: 937.53 GiB (98.32%)
used: 226.33 GiB (24.1%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-acc2baf7-f037-4bb7-8dc7-682bea6d1aad
used: 32.4 MiB (10.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 62.1 C mobo: 50.0 C
Fan Speeds (rpm): N/A
GPU: device: nvidia screen: :0.0 temp: 48 C device: amdgpu temp: 59.0 C
Memory: total: 32 GiB note: est. available: 30.54 GiB used: 5.12 GiB (16.8%)
Processes: 551 Power: uptime: 5h 45m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 12.18 GiB services: org_kde_powerdevil,
tool: systemctl
Packages: pm: pacman pkgs: 1475 libs: 385 tools: octopi,pamac,yay
pm: flatpak pkgs: 0 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9
running-in: konsole inxi: 3.3.33
eden@echo:[~]: mhwd --list
> 0000:01:00.0 (0300:10de:27e0) Display controller nVidia Corporation:
NAME VERSION FREEDRIVER TYPE
video-hybrid-amd-nvidia-prime 2023.03.23 false PCI
video-nvidia 2023.03.23 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> 0000:05:00.0 (0300:1002:164e) Display controller ATI Technologies Inc:
> 0000:04:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
network-r8168 2023.09.12 true PCI
