I have recently acquired a Lenovo Legion 5 Pro notebook with AMD Ryzen and Nvidia 3050ti. After installing Manjaro I have an issue with adjusting brightness. I simply cannot adjust it. I know that this topic was already covered in several other threads. Since yesterday I have visited a lot of websites and didn’t find the solution.
I have followed tips from these websites:
https://bbs.archlinux.org/viewtopic.php?pid=1928876#p1928876
https://bbs.archlinux.org/viewtopic.php?pid=1940158#p1940158
These command doesn’t do anything
xbacklight -dec 10
Some outputs:
$ inxi -Fazy
Kernel: 5.15.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
root=UUID=cd5aafe9-277d-4a1a-ae56-b62ceb679dbc rw rootflags=subvol=@
reboot=acpi quiet apparmor=1 security=apparmor udev.log_priority=3
nvidia.NVreg_RegistryDwords=EnableBrightnessControl=1 acpi_osi=Linux
amdgpu.backlight=0 acpi_backlight=vendor video.use_native_backlight=1
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 82JS v: Legion 5 Pro 16ACH6
serial: <superuser required> Chassis: type: 10 v: Legion 5 Pro 16ACH6
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN
serial: <superuser required> UEFI: LENOVO v: HHCN20WW date: 10/01/2021
ID-1: BAT0 charge: 30.5 Wh (37.1%) condition: 82.3/80.0 Wh (102.9%)
volts: 15.7 min: 15.4 model: Sunwoda L20D4PC1 type: Li-poly serial: <filter>
status: Charging cycles: 3
Info: 6-Core model: AMD Ryzen 5 5600H with Radeon Graphics bits: 64
type: MT MCP arch: Zen 3 family: 19 (25) model-id: 50 (80) stepping: 0
microcode: A50000C cache: L1: 384 KiB L2: 3 MiB L3: 16 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 79080
Speed: 2340 MHz min/max: 1200/3300 MHz boost: enabled Core speeds (MHz):
1: 3393 2: 2834 3: 2394 4: 2437 5: 3355 6: 3556 7: 3032 8: 2966 9: 2732
10: 3102 11: 3076 12: 2517
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
STIBP: always-on, RSB filling
Device-1: NVIDIA GA107BM [GeForce RTX 3050 Ti Mobile] vendor: Lenovo
driver: nvidia v: 495.44 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:25e0 class-ID: 0300
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver:
Screen-1: 0 s-res: 2560x1600 s-dpi: 191 s-size: 340x221mm (13.4x8.7")
s-diag: 406mm (16")
Monitor-1: DP-4 res: 2560x1600 hz: 60 dpi: 188 size: 345x215mm (13.6x8.5")
diag: 407mm (16")
OpenGL: renderer: NVIDIA GeForce RTX 3050 Ti Laptop GPU/PCIe/SSE2
v: 4.6.0 NVIDIA 495.44 direct render: Yes
Device-1: NVIDIA driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 10de:2291 class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x
bus-ID: 06:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.2-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
vendor: Lenovo driver: r8169 v: kernel port: 2000 bus-ID: 03:00.0
Device-2: Realtek vendor: Lenovo driver: rtw89_pci v: N/A modules: rtw89pci
port: 1000 bus-ID: 04:00.0 chip-ID: 10ec:8852 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 3-4:2 chip-ID: 0bda:4852 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 1.38 TiB used: 16.48 GiB (1.2%)
ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: Samsung model: MZALQ512HBLU-00BL2
lanes: 4 type: SSD serial: <filter> rev: 5L2QFXM7 temp: 34.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
rev: 2B2QEXM7 temp: 33.9 C scheme: GPT
ID-1: / raw-size: 128 GiB size: 128 GiB (100.00%) used: 16.48 GiB (12.9%)
fs: btrfs dev: /dev/nvme1n1p1 maj-min: 259:1
used: 568 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p2 maj-min: 259:2
ID-3: /home raw-size: 128 GiB size: 128 GiB (100.00%)
used: 16.48 GiB (12.9%) fs: btrfs dev: /dev/nvme1n1p1 maj-min: 259:1
ID-4: /var/log raw-size: 128 GiB size: 128 GiB (100.00%)
Message: No sensor data found. Is lm-sensors configured?
Processes: 340 Uptime: 4m wakeups: 1 Memory: 15.54 GiB
used: 2.17 GiB (14.0%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1287 lib: 335 flatpak: 0
Shell: Zsh v: 5.8 default: Bash v: 5.1.8 running-in: yakuake inxi: 3.3.09
$ mhwd --listinstalled
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2021.11.04 false PCI
$ ls /sys/class/backlight/
ideapad nvidia_0
$ cat /usr/share/X11/xorg.conf.d/10-amdgpu-nvidia-drm-outputclass.conf
Section "ServerLayout"
Identifier "layout"
Option "AllowNVIDIAGPUScreens"
EndSection
Section "OutputClass"
Identifier "AMDgpu"
MatchDriver "amdgpu"
Driver "amdgpu"
EndSection
Identifier "nvidia"
MatchDriver "nvidia-drm"
Driver "nvidia"
Option "AllowEmptyInitialConfiguration"
ModulePath "/usr/lib/nvidia/xorg"
ModulePath "/usr/lib/xorg/modules"
Option "RegistryDwords" "EnableBrightnessControl=1"
EndSection
