Hey there,
I’m on a Lenovo Legion laptop with an AMD CPU and NVIDIA GPU, running nvidia drivers version 515 and Kernel 5.18.
$ inxi -Fxz
Kernel: 5.18.12-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
Desktop: Xfce v: 4.16.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 82JQ v: Legion 5 Pro 16ACH6H
serial: <superuser required>
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
UEFI: LENOVO v: GKCN50WW date: 11/24/2021
ID-1: BAT0 charge: 82.4 Wh (100.0%) condition: 82.4/80.0 Wh (103.0%)
volts: 17.5 min: 15.4 model: Sunwoda L20D4PC1 status: full
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 3
charge: 100% (should be ignored) status: discharging
Info: 8-core model: AMD Ryzen 7 5800H with Radeon Graphics bits: 64
type: MT MCP arch: Zen 3 rev: 0 cache: L1: 512 KiB L2: 4 MiB L3: 16 MiB
Speed (MHz): avg: 1816 high: 3073 min/max: 1200/4462 boost: enabled
cores: 1: 2114 2: 1197 3: 3073 4: 1356 5: 2325 6: 2434 7: 1780 8: 1537
9: 1837 10: 2023 11: 1479 12: 1396 13: 1396 14: 1395 15: 2285 16: 1430
bogomips: 102241
Device-1: NVIDIA GA104M [GeForce RTX 3070 Mobile / Max-Q] vendor: Lenovo
driver: nvidia v: 515.57 arch: Ampere bus-ID: 01:00.0
Display: x11 server: X.Org v: 21.1.4 driver: X: loaded: nvidia
gpu: nvidia resolution: 2560x1600
OpenGL: renderer: NVIDIA GeForce RTX 3070 Laptop GPU/PCIe/SSE2
v: 4.6.0 NVIDIA 515.57 direct render: Yes
Device-1: NVIDIA GA104 High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 01:00.1
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo
driver: N/A bus-ID: 05:00.5
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 05:00.6
Sound Server-1: ALSA v: k5.18.12-3-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.55 running: yes
vendor: Lenovo driver: r8169 v: kernel port: 1000 bus-ID: 03:00.0
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 04:00.0
IF: wlp4s0 state: up mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 3-4:2
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 953.87 GiB used: 423.27 GiB (44.4%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB1T0HBLR-000L2
size: 953.87 GiB temp: 44.9 C
ID-1: / size: 937.53 GiB used: 423.27 GiB (45.1%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 312 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p1
ID-1: swap-1 type: file size: 16 GiB used: 0 KiB (0.0%) file: /swapfile
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 40 C
Processes: 354 Uptime: 32m Memory: 15.48 GiB used: 2.55 GiB (16.5%)
Init: systemd Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: 1293
Shell: Bash v: 5.1.16 inxi: 3.3.19
The Fn + brightness keys display the slider when pressed, but do not actually change the brightness. The volume and other Fn keys do work, however. Manually changing the brightness with xrandr --output DP-4 --brightness does work, but manually editing /sys/class/backlight/nvidia_0/brightness does not. I’ve gone through numerous threads here but none seem to provide a solution to my problem. I did encounter a thread in the NVIDIA forums (“Laptop backlight control regression with 465.24.02”) but it appears to be very inconsistent with which versions of the driver work and which do not, with various users claiming the issue was fixed in different versions of the nvidia driver. So I’m kind of at a loss here, any help would be greatly appreciated!
Olli
5 August 2022 12:11
3
please post the output of
ls /sys/class/backlight/
Vortic:~ $ ls /sys/class/backlight/
nvidia_0
I stumbled accross this one but it did not work for me. I installed acpilight and added my user to the video group, but it is still not working, not even after reboot.
And the acpi daemon is enabled and active?
systemctl status acpid
Olli
5 August 2022 12:19
7
add this to /etc/default/grub:
GRUB_CMDLINE_LINUX_DEFAULT="quiet acpi_osi=Linux acpi_backlight=vendor"
don’t forget to update grub
sudo update-grub
sudo mkinitcpio -P
It was not, I started it but the brightness control is still not working:
Vortic:~ $ systemctl status acpid
● acpid.service - ACPI event daemon
Loaded: loaded (/usr/lib/systemd/system/acpid.service; enabled; preset: disabled)
Active: active (running) since Fri 2022-08-05 15:18:09 EEST; 1min 7s ago
Docs: man:acpid(8)
Main PID: 2747 (acpid)
Tasks: 1 (limit: 19002)
Memory: 344.0K
CPU: 239ms
CGroup: /system.slice/acpid.service
└─2747 /usr/bin/acpid --foreground --netlink
Aug 05 15:18:09 vortic systemd[1]: Started ACPI event daemon.
Aug 05 15:18:09 vortic acpid[2747]: starting up with netlink and the input layer
Aug 05 15:18:09 vortic acpid[2747]: 1 rule loaded
Aug 05 15:18:09 vortic acpid[2747]: waiting for events: event logging is off
I added it:
Vortic:~ $ cat /etc/default/grub
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_TIMEOUT_STYLE=hidden
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX="reboot=acpi"
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash video.use_native_backlight=1 usbcore.autosuspend = -1 idle = nomwait resume=UUID=b682322c-7788-4d26-b501-4103a30fa493 resume_offset=104855552 amdgpu.backlight=0 acpi_osi=Linux acpi_backlight=vendor"
Updated grub and rebooted, still not working through.
Olli:
It changed
ideapad nvidia_0
Olli
5 August 2022 12:39
12
please delete
from your grub file, update grub as described above and reboot. after rebooting please post the output of
again
Removed it:
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash usbcore.autosuspend = -1 idle = nomwait resume=UUID=b682322c-7788-4d26-b501-4103a30fa493 resume_offset=104855552 amdgpu.backlight=0 acpi_osi=Linux acpi_backlight=vendor"
Updated grub, rebooted:
ideapad nvidia_0
Neither of these options seem to be working for me.
Just that one option, no other acpi kernel boot parameter … Also, as always, i recommend updating the BIOS to the latest provided by the manufacturer.
This package provides BIOS Update and is supported onLegion 5 Pro-16ACH6H, Legion 5-15ACH6H, Lenovo Legion 5 17ACH6H, Legion 7-16ACHg6 and running the following Operating Systems: Windows 10 (64-bit) and Windows 11 (64-bit)
is GKCN54WW 02 Jun 2022
Downgrade to linux-lts 5.15 kernel and nvidia-dkms 495.46.
add acpi_backlight=native and nvidia.NVreg_RegistryDwords=EnableBrightnessControl=1 to kernel parameters.
I have the same device running archlinux, after the driver from nvidia 510.xx, the brightness adjustment in discrete mode is broken, so I can only roll back the driver to 495.46, which is not compatible with the new kernel, so must also Use lts kernel to downgrade kernel version
Tried with the following:
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash usbcore.autosuspend = -1 idle = nomwait resume=UUID=b682322c-7788-4d26-b501-4103a30fa493 resume_offset=104855552 amdgpu.backlight=0 acpi_backlight=video"## Use geteltorito.pl on an Arch Linux ##
geteltorito -o {output-image-name.img {Bootable-CD.iso}
geteltorito -o x230.img g2uj28us.iso
Still not working, though.
Olli
6 August 2022 12:44
19
put the “reboot=acpi” to the GRUB_CMD_LINUX_DEFAULT Section !!! it’s a different and only the default-section secures that it is loaded from the first moment.
Unfortunately, I already have a bunch of stuff installed on the laptop and downgrading drivers and kernel like that will surely break something. I don’t believe downgrading is a viable permanent solution to any problem, really, especially core software components.
