I have a lenovo laptop (Lenovo IdeaPad S340-14IIL) with an Intel i7-1065G7 CPU, for the last few days it has been using incorrect max frequency settings.
It should be capable of turboing up to 3.9ghz but its maxing out at 1.6ghz
I did a reset by holding down the power button, and that upped reported hardware limit back to 3.9ghz, but cpupower is still reporting that ‘current policy’ allows frequency to be within 400mhz and 1.3ghz.
I am running auto-cpufreq but that should be limiting the max freq to 3ghz via the config file. Its reporting CPU max frequency as 1300mhz via --stats
$ cpupower frequency-info
analyzing CPU 0:
driver: intel_pstate
CPUs which run at the same hardware frequency: 0
CPUs which need to have their frequency coordinated by software: 0
maximum transition latency: Cannot determine or is not supported.
hardware limits: 400 MHz - 3.90 GHz
available cpufreq governors: performance powersave
current policy: frequency should be within 400 MHz and 1.30 GHz.
The governor "performance" may decide which speed to use
within this range.
current CPU frequency: Unable to call hardware
current CPU frequency: 1.50 GHz (asserted by call to kernel)
boost state support:
Supported: yes
Active: yes
$ lscpu
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Address sizes: 39 bits physical, 48 bits virtual
Byte Order: Little Endian
CPU(s): 8
On-line CPU(s) list: 0-7
Vendor ID: GenuineIntel
Model name: Intel(R) Core(TM) i7-1065G7 CPU @ 1.30GHz
CPU family: 6
Model: 126
Thread(s) per core: 2
Core(s) per socket: 4
Socket(s): 1
Stepping: 5
CPU(s) scaling MHz: 33%
CPU max MHz: 3900.0000
CPU min MHz: 400.0000
BogoMIPS: 2996.00
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mc
a cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss
ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc art
arch_perfmon pebs bts rep_good nopl xtopology nonstop_
tsc cpuid aperfmperf tsc_known_freq pni pclmulqdq dtes6
4 monitor ds_cpl vmx est tm2 ssse3 sdbg fma cx16 xtpr p
dcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline
_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefe
tch cpuid_fault epb invpcid_single ssbd ibrs ibpb stibp
ibrs_enhanced tpr_shadow vnmi flexpriority ept vpid ep
t_ad fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpc
id avx512f avx512dq rdseed adx smap avx512ifma clflusho
pt intel_pt avx512cd sha_ni avx512bw avx512vl xsaveopt
xsavec xgetbv1 xsaves split_lock_detect dtherm ida arat
pln pts hwp hwp_notify hwp_act_window hwp_epp hwp_pkg_
req avx512vbmi umip pku ospke avx512_vbmi2 gfni vaes vp
clmulqdq avx512_vnni avx512_bitalg avx512_vpopcntdq rdp
id fsrm md_clear flush_l1d arch_capabilities
Virtualization features:
Virtualization: VT-x
Caches (sum of all):
L1d: 192 KiB (4 instances)
L1i: 128 KiB (4 instances)
L2: 2 MiB (4 instances)
L3: 8 MiB (1 instance)
NUMA:
NUMA node(s): 1
NUMA node0 CPU(s): 0-7
Itlb multihit: KVM: Mitigation: VMX disabled
L1tf: Not affected
Mds: Not affected
Meltdown: Not affected
Mmio stale data: Mitigation; Clear CPU buffers; SMT vulnerable
Retbleed: Mitigation; Enhanced IBRS
Spec store bypass: Mitigation; Speculative Store Bypass disabled via prctl
Spectre v1: Mitigation; usercopy/swapgs barriers and __user pointer
Spectre v2: Mitigation; Enhanced IBRS, IBPB conditional, RSB fillin
g, PBRSB-eIBRS SW sequence
Srbds: Mitigation; Microcode
Tsx async abort: Not affected
