Hi there,
So, I’ve trawled the forum posts, and while there seem to be a number of Lenovo touchpad issues, mine appears unique. I installed Manjaro 6.12.44-3 on my Lenovo IdeaPad 5 2-in-1 14IRU9 at the start of 2015 and had no issues with the touchpad.
Since August 2025, however, my touchpad will, after a period of use, become less responsive. The bottom left + centre become completely unresponsive (the areas I use it the most), while the right side, and a bit of the top left will work fine. I wondered if this could be a hardware issue, but I bought the laptop at the start of 2015. Further, when I restart my system, the whole touchpad becomes responsive again, which seems to suggest a driver/system issue. It’s just strange that the touchpad “degrades” after a period of time, and this period can be anywhere from 10 minutes to 2 hours.
I’ve tried installing a different kernel (6.16.4-2), which has marginally improved things. Now, if I wait a bit when the touchpad becomes unresponsive, it can return to normal (but not always). Another post suggested I clean the touchscreen, which I did, and it seemed to improve things for a short period, before reverting back to my terrible normal (unresponsive touchpad).
I’m truly stumped as to what is happening, and am curious if anyone else has had issues like this, how they diagnosed the problem, and what fixes they implemented?
Some system info might be very helpful in this case.
Please provide the output of:
inxi --filter --verbosity=8 --color=0
or the short form:
inxi -zv8c0
Kernel: 6.16.4-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.16-x86_64
root=UUID=7174dd12-8aea-4cd2-8635-b45fe7d75f12 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.17.0
Type: Convertible System: LENOVO product: 83DT v: IdeaPad 5 2-in-1 14IRU9
serial: <superuser required> Chassis: type: 31 v: IdeaPad 5 2-in-1 14IRU9
Mobo: LENOVO model: LNVNB161216 v: SDK0T76463 WIN
serial: <superuser required> part-nu: LENOVO_MT_83DT_BU_idea_FM_IdeaPad 5
2-in-1 14IRU9 uuid: <superuser required> UEFI: LENOVO v: P0CN17WW
date: 03/27/2024
ID-1: BAT0 charge: 42 Wh (77.5%) condition: 54.2/57 Wh (95.1%) power: 6.6 W
volts: 12.2 min: 11.31 model: Sunwoda L23D3PE1 type: Li-ion serial: <filter>
charging: status: discharging cycles: 71
System RAM: total: 16 GiB available: 15.31 GiB used: 1.67 GiB (10.9%)
Array-1: capacity: 16 GiB slots: 8 modules: 8 EC: None
max-module-size: 2 GiB note: est.
Device-1: Controller0-ChannelA type: LPDDR5 detail: synchronous
size: 2 GiB speed: spec: 6400 MT/s actual: 5200 MT/s volts: curr: 0.5
width (bits): data: 16 total: 16 manufacturer: Samsung
part-no: K3KL8L80CM-MGCT serial: N/A
Device-2: Controller0-ChannelB type: LPDDR5 detail: synchronous
Device-3: Controller0-ChannelC type: LPDDR5 detail: synchronous
Device-4: Controller0-ChannelD type: LPDDR5 detail: synchronous
Device-5: Controller1-ChannelA type: LPDDR5 detail: synchronous
Device-6: Controller1-ChannelB type: LPDDR5 detail: synchronous
Device-7: Controller1-ChannelC type: LPDDR5 detail: synchronous
Device-8: Controller1-ChannelD type: LPDDR5 detail: synchronous
Info: model: Intel Core 5 120U bits: 64 type: MST AMCP arch: Raptor Lake
level: v3 note: check built: 2022+ process: Intel 7 (10nm) family: 6
model-id: 0xBA (186) stepping: 3 microcode: 0x4129
Topology: cpus: 1x dies: 1 clusters: 4 cores: 10 threads: 12 mt: 2 tpc: 2
st: 8 smt: enabled cache: L1: 928 KiB desc: d-8x32 KiB, 2x48 KiB; i-2x32
KiB, 8x64 KiB L2: 6.5 MiB desc: 2x1.2 MiB, 2x2 MiB L3: 12 MiB
desc: 1x12 MiB
Speed (MHz): avg: 800 min/max: 400/5000:3800 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 59904
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdtscp rep_good sdbg sep serialize sha_ni smap smep smx split_lock_detect
ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
xtopology xtpr
conditional; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: Intel Raptor Lake-U [Intel Graphics] vendor: Lenovo driver: i915
v: kernel alternate: xe arch: Xe process: Intel 7 (10nm) built: 2022+ ports:
active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:a7ac class-ID: 0300
Device-2: IMC Networks Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:3 chip-ID: 13d3:54b6
Display: x11 server: X.Org v: 21.1.18 with: Xwayland v: 24.1.8
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x317mm (20.00x12.48")
s-diag: 599mm (23.57") monitors: <missing: xrandr>
Monitor-1: eDP-1 model: BOE Display 0x0b5d built: 2022 res: 1920x1200
dpi: 161 gamma: 1.2 chroma: red: x: 0.596 y: 0.369 green: x: 0.349 y: 0.576
blue: x: 0.157 y: 0.125 white: x: 0.314 y: 0.329
size: 302x188mm (11.89x7.4") diag: 356mm (14") ratio: 16:10
modes: 1920x1200
device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.2.1-arch1.4
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (RPL-U)
device-ID: 8086:a7ac memory: 14.95 GiB unified: yes
API: Vulkan v: 1.4.321 layers: N/A device: 0 type: integrated-gpu
name: Intel Graphics (RPL-U) driver: mesa intel v: 25.2.1-arch1.4
device-ID: 8086:a7ac surfaces: N/A
Device-1: Intel Raptor Lake-P/U/H cAVS vendor: Lenovo
driver: sof-audio-pci-intel-tgl alternate: snd_hda_intel, snd_soc_avs,
snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:51ca class-ID: 0401
API: ALSA v: k6.16.4-2-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.4.7 status: active with: 1: pipewire-pulse
Device-1: Intel Raptor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:51f1 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0026
class-ID: e001
Local Storage: total: 476.94 GiB used: 70.83 GiB (14.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFS512GEJ4X112N
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 51040C31 temp: 20.9 C
scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
used: 70.82 GiB (15.1%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 7174dd12-8aea-4cd2-8635-b45fe7d75f12
used: 8.3 MiB (2.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 7BC7-77B1
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-5:2 info: LighTuning ETU905A88-E type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 100mA chip-ID: 1c7a:0583 class-ID: ff00 serial: <filter>
Device-2: 3-6:3 info: IMC Networks Integrated Camera type: video
lanes: 1 mode: 2.0 power: 500mA chip-ID: 13d3:54b6 class-ID: 0e02
serial: <filter>
Device-3: 3-10:4 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0026 class-ID: e001
System Temperatures: cpu: 28.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1481 libs: 354 tools: pamac pm: flatpak pkgs: 0
1: https://mirrors.manjaro.org/repo/stable/$repo/$arch
2: https://mirror.fcix.net/manjaro/stable/$repo/$arch
3: https://muug.ca/mirror/manjaro/stable/$repo/$arch
4: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
5: https://manjaro.syxpi.fr/manjaro/stable/$repo/$arch
6: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
7: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
8: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 283
1: cpu: 14.7% command: plasmashell pid: 912 mem: 306.9 MiB (1.9%)
2: cpu: 12.1% command: konsole pid: 2000 mem: 129.6 MiB (0.8%)
3: cpu: 9.8% command: kwin_x11 pid: 879 mem: 174.2 MiB (1.1%)
4: cpu: 9.2% command: Xorg pid: 684 mem: 80.3 MiB (0.5%)
5: cpu: 5.5% command: zsh pid: 2033 mem: 9.95 MiB (0.0%)
Memory top: 5 of 283
1: mem: 306.9 MiB (1.9%) command: plasmashell pid: 912 cpu: 14.7%
2: mem: 192.6 MiB (1.2%) command: nextcloud pid: 1147 cpu: 3.5%
3: mem: 174.2 MiB (1.1%) command: kwin_x11 pid: 879 cpu: 9.8%
4: mem: 129.6 MiB (0.8%) command: konsole pid: 2000 cpu: 12.1%
5: mem: 113.0 MiB (0.7%) command: kded6 pid: 878 cpu: 1.1%
Processes: 283 Power: uptime: 0m states: freeze,mem,disk suspend: s2idle
avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 6.11 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: clang: 20.1.8 gcc: 15.2.1 Shell: Zsh v: 5.9 default: Bash
v: 5.3.3 running-in: konsole inxi: 3.3.39
Mod edit: added 3 backticks (```) before and after the terminal output so that it properly displays as code
The first thing I would suggest is for you to check if the problem which is occurring in a Plasma X11 session also happens in a Plasma Wayland session.
You can change your Plasma session from X11 to Wayland by selecting the session type at the login screen (Wayland is now KDE’s default for Plasma).
If you have set up autologin to skip the password screen, you can change to a Wayland session by opening System Settings → Colors & Themes → Login Screen (SDDM) → Behavior.
Some swap space might improve things. It’s possible your physical RAM starts to fill up after a time; depending on what applications you have filling it at any given time, and how much you push available resources.
Of course, there might potentially be a number of things contributing to your issue.
Does this also happen in Wayland?
I’ve swapped over to Plasma Wayland, but the issue popped up after a bit of browsing. I’ll create some swap space, but I have a suspicion that isn’t the issue, as I run things pretty light (Onlyoffice doc + slides, Vivaldi with a dozen tabs at most, and Xournal++ with a pdf open). However, I wouldn’t be surprised if Vivaldi somehow tanked my 16gb of ram, haha. Will get back to you all in a bit.
No luck, unfortunately. Touchpad is as erratic as ever
