Lenovo IdeaPad 5 Pro - Display Resolution Issues
The default resolution for my laptop is: 2880px x1800px. In order to make the display large enough to see, I made the following adjestment in Settings:
Window Scaling - 2
However, in some applications including GIMP, and Audacious interface elements such as the Menu Bar and text is still too small. How can I resolve this issue please?
Merry Christmas and thanks in advance :slight_smile:
Welcome to Manjaro! :smiling_face_with_three_hearts:
  1. Please read the information behind this link. It will help you to post necessary information.
  1. Please press the 3 dots … below your post and then press the :pencil2:
  • If you give us information about your system, we can see what we’re talking about and make better suggestions.
  • You can do this by using inxi in a terminal or in console.
sudo inxi --verbosity=8 --filter --width
  • Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
  • Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
  1. Copy the output from inxi (including the command) and paste it into your post.
  • To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
  1. Or we can try to play hide and seek :wink:
    Have you already :mag: for your problem in the forum ? (Wisdom lies in asking → listening → reading :wink: )
Google ist dein Freund und übersetzt dir das.
Google est votre ami et le traduira pour vous.
At least on the x11 version of xfce, there is something wrong with this setting and it does not work as expected. Maybe the display scaling setting works better with wayland, but not with x11. Contrary to the logic however, the dpi setting for fonts also controls gui elements in 99,9% of the apps. Revert display and go to appearance and font settings, below is the dpi -default is 96. Make it 120 and test, then test 144 etc. Be careful not to make too big steps cause elements of the window will be outside the screen and it may be hard to revert (that is why reset display zoom first).
Many thanks. 144 works well for me.
Thank you. I will be sure to post this information in future.
