Hello everyone! I am new to Manjaro, it works very well on my Lenovo Ideapad 5 pro 16-ACH6. After full installation I can’t understand why wifi doesn’t work.
This is my output for inxi -Nazy:
0: ideapad_wlan: Wireless LAN
Soft blocked: no
Hard blocked: no
1: ideapad_bluetooth: Bluetooth
Soft blocked: no
Hard blocked: no
2: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
As I understand this means that driver for wifi is installed and works well. Why wifi isn’t working?
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or if you agree)
P.S. In the future, please don’t forget to come back to your question after your issue has been solved and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
P.P.S. @tux-86 I’ve edited your post to be much more clear to a brand new user:
They don’t know what the AUR is
They don’t know how to install packages
They’ll think they need to install drivers like in Windows, whereas on Linux, 99% of all drivers are in the kernel…
Please press the orange pencil in the top right of your post and press raw to see what I changed exactly!
P.P.P.S. Although I’m a moderator on this site, this is not an official warning: just helping you to become a more productive member of this forum.
