Hey all! My Lenovo IdeaPad 330 is having wifi problems. Connecting works fine and after connecting it works without issues for a random amount of time, after which transfer just stops. The connection stays active, and the wifi tray app blinks between a few hundreds of bytes per second and nothing at all. Reconnecting or turning wifi off and on resets the situation. May be completely unrelated, but the tray app also freezes for a few seconds whenever I try to do something in this state.
I remember seeing a bunch of issues around the web related to this Aetheros chip the laptop is using, they mostly talked about changing back to older firmware version, I tried that, didn’t solve my issue.
Below is the system info:
System: Kernel: 5.14.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: LENOVO product: 81DE v: Lenovo ideapad 330-15IKB serial: <filter>
Chassis: type: 10 v: Lenovo ideapad 330-15IKB serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <filter> UEFI: LENOVO v: 8TCN58WW
date: 06/18/2020
Battery: ID-1: BAT0 charge: 24.1 Wh (94.5%) condition: 25.5/35.0 Wh (73.0%) volts: 8.4 min: 7.6
model: LGC L16L2PB3 type: Li-poly serial: <filter> status: Charging
Memory: RAM: total: 7.68 GiB used: 3.66 GiB (47.6%)
CPU: Info: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Kaby Lake
note: check rev: A cache: L2: 6 MiB bogomips: 28808
Speed: 800 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 1633
5: 1106 6: 2801 7: 3299 8: 2262
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art avx avx2
bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de
ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc
nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti
pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Graphics: Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:5917 class-ID: 0300
Device-2: IMC Networks EasyCamera type: USB driver: uvcvideo bus-ID: 1-8:8
chip-ID: 13d3:5a02 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: modesetting
alternate: fbdev,vesa resolution: 1: 1600x900~60Hz 2: 1600x900~60Hz s-dpi: 96
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.2.3
direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
Device-2: Razer USA Kraken 7.1 Chroma type: USB
driver: razerkraken,snd-usb-audio,usbhid bus-ID: 1-3:4 chip-ID: 1532:0504
class-ID: 0300
Sound Server-1: ALSA v: k5.14.10-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo
driver: r8168 v: 8.049.02-NAPI port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp1s0 state: down mac: <filter>
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter vendor: Lenovo
driver: ath10k_pci v: kernel bus-ID: 02:00.0 chip-ID: 168c:0042 class-ID: 0280
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
Bluetooth: Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-7:7
chip-ID: 0cf3:e500 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 7 state: down bt-service: enabled,running rfk-block:
hardware: no software: yes address: see --recommends
Logical: Message: No logical block device data found.
RAID: Message: No RAID data found.
Drives: Local Storage: total: 238.47 GiB used: 174.47 GiB (73.2%)
ID-1: /dev/sda vendor: SK Hynix model: HFS256G3BTND-N210A size: 238.47 GiB
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 1P10 scheme: GPT
Partition: ID-1: / size: 233.43 GiB used: 174.47 GiB (74.7%) fs: ext4 dev: /dev/sda2 label: N/A
uuid: 0ef36afe-dcb4-4314-aac3-d8defcace511
ID-2: /boot/efi size: 299.4 MiB used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1
label: N/A uuid: 4726-5F2C
Swap: ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) priority: -2 file: /swapfile
Unmounted: Message: No unmounted partitions found.
USB: Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0 speed: 480 Mb/s
Device-1: 1-1:2 info: [Maxxter] USB GAMING MOUSE type: Mouse,Keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s power: 100mA
chip-ID: 18f8:1286 class-ID: 0301
Hub-2: 1-2:3 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s power: 100mA
Device-1: 1-2.2:5 info: HUION 420 type: Mouse,HID driver: uclogic,usbhid interfaces: 3
rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 256c:006e class-ID: 0300
Device-2: 1-2.4:9 info: Razer USA BlackWidow Ultimate 2013 type: Keyboard,Mouse
driver: razerkbd,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 1532:011a class-ID: 0300
Device-3: 1-3:4 info: Razer USA Kraken 7.1 Chroma type: Audio,HID
driver: razerkraken,snd-usb-audio,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s
power: 200mA chip-ID: 1532:0504 class-ID: 0300
Device-4: 1-7:7 info: Qualcomm Atheros type: Bluetooth driver: btusb interfaces: 2
rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 0cf3:e500 class-ID: e001
Device-5: 1-8:8 info: IMC Networks EasyCamera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 13d3:5a02 class-ID: 0e02
serial: <filter>
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
Hub-4: 2-2:2 info: Genesys Logic hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 05e3:0616 class-ID: 0900
Sensors: System Temperatures: cpu: 37.0 C mobo: N/A
Info: Processes: 267 Uptime: 1h 59m wakeups: 13 Init: systemd v: 249 Compilers: gcc: 11.1.0
clang: 12.0.1 Packages: 1661 pacman: 1641 flatpak: 13 snap: 7 Shell: Bash v: 5.1.8
running-in: konsole inxi: 3.3.08
