Hi everyone!
So as the title says WIFI doesn’t work. I did the following instructions but it didn’t work for me:
sudo pacman -Syyu
sudo pacman -S dkms linux59-headers
(59 since my kernel version output of uname -r
is 5.9.16-1-MANJARO)
pamac build rtl8821ce-dkms-git
I tried many things and none worked, when I do lspci
it shows my network adapter so I doubt its a hardware problem since it worked with Windows (the OS i had hours ago).
Thanks!
Did you reboot after installing rtl8821ce-dkms-git?
Post the results of
journalctl -b | grep 8821ce
Mar 06 00:49:08 manjaro kernel: rtw_8821ce 0000:02:00.0: Firmware version 24.8.0, H2C version 12
Mar 06 00:49:08 manjaro kernel: 8821ce: loading out-of-tree module taints kernel.
Mar 06 00:49:08 manjaro kernel: 8821ce: module verification failed: signature and/or required key missing - tainting kernel
Mar 06 00:49:08 manjaro NetworkManager[474]: [1614988148.2691] rfkill2: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:1c.5/0000:02:00.0/ieee80211/phy0/rfkill2) (driver rtw_8821ce)
Mar 06 00:49:08 manjaro kernel: rtw_8821ce 0000:02:00.0 wlp2s0: renamed from wlan0
Mar 06 00:49:08 manjaro kernel: rtw_8821ce 0000:02:00.0: start vif b0:fc:36:51:68:25 on port 0
Mar 06 00:49:08 manjaro kernel: rtw_8821ce 0000:02:00.0: stop vif b0:fc:36:51:68:25 on port 0
Mar 06 00:49:09 manjaro kernel: rtw_8821ce 0000:02:00.0: start vif be:06:4e:6a:e2:de on port 0
Mar 06 00:56:00 manjaro kernel: rtw_8821ce 0000:02:00.0: stop vif be:06:4e:6a:e2:de on port 0
Mar 06 00:56:01 manjaro kernel: rtw_8821ce 0000:02:00.0: start vif ee:0d:74:ec:fc:ab on port 0
Mar 06 01:02:57 manjaro kernel: rtw_8821ce 0000:02:00.0: stop vif ee:0d:74:ec:fc:ab on port 0
Mar 06 01:02:58 manjaro kernel: rtw_8821ce 0000:02:00.0: start vif be:7e:14:ae:35:ea on port 0
Mar 06 01:09:54 manjaro kernel: rtw_8821ce 0000:02:00.0: stop vif be:7e:14:ae:35:ea on port 0
Mar 06 01:09:55 manjaro kernel: rtw_8821ce 0000:02:00.0: start vif fe:58:60:9d:9b:37 on port 0
Mar 06 01:16:51 manjaro kernel: rtw_8821ce 0000:02:00.0: stop vif fe:58:60:9d:9b:37 on port 0
Mar 06 01:16:52 manjaro kernel: rtw_8821ce 0000:02:00.0: start vif 9e:b7:41:2f:4c:ae on port 0
Mar 06 01:23:48 manjaro kernel: rtw_8821ce 0000:02:00.0: stop vif 9e:b7:41:2f:4c:ae on port 0
Mar 06 01:23:49 manjaro kernel: rtw_8821ce 0000:02:00.0: start vif 62:c6:c2:4d:3c:8c on port 0
Mar 06 01:29:50 manjaro kernel: rtw_8821ce 0000:02:00.0: stop vif 62:c6:c2:4d:3c:8c on port 0
Mar 06 01:29:50 manjaro kernel: rtw_8821ce 0000:02:00.0: start vif b0:fc:36:51:68:25 on port 0
Mar 06 01:37:27 manjaro kernel: rtw_8821ce 0000:02:00.0: stop vif b0:fc:36:51:68:25 on port 0
Mar 06 01:37:27 manjaro kernel: rtw_8821ce 0000:02:00.0: start vif b0:fc:36:51:68:25 on port 0
Mar 06 01:37:28 manjaro kernel: rtw_8821ce 0000:02:00.0: stop vif b0:fc:36:51:68:25 on port 0
Mar 06 01:37:28 manjaro kernel: rtw_8821ce 0000:02:00.0: start vif 3a:be:0b:70:a6:1f on port 0
