Lenovo 100 USB-C Dock – No HDMI Output on Manjaro GNOME (Wayland/Xorg)
1. System Information
  • Laptop: ThinkPad E14 Gen 6 (AMD)
  • Kernel: 6.12.20-2-MANJARO
  • Desktop Environment: GNOME 48 (Wayland, also tested on Xorg)
  • Graphics: AMD Radeon 680M (Rembrandt) – amdgpu driver
  • Docking Station: Lenovo 100 USB-C Travel Dock (4X91H97874)
  • Connection: USB-C → HDMI (via dock)
2. Issue Description
I am trying to use a Lenovo 100 USB-C Travel Dock to connect an external monitor via HDMI, but my system does not detect the display at all. Other dock functions (keyboard and mouse connected via USB-A) work correctly, but no video output is recognized.
inxi -zv8
  Kernel: 6.12.20-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    clocksource: hpet avail: acpi_pm
    root=UUID=c3bb4485-62f7-48af-b88b-0dce0541fcb9 rw quiet splash
    udev.log_priority=3
  Desktop: GNOME v: 48.0 tk: GTK v: 3.24.49 wm: gnome-shell
    base: Arch Linux
  Type: Laptop System: LENOVO product: 21M4S1G900 v: ThinkPad E14 Gen 6
  Mobo: LENOVO model: 21M4S1G900 v: ThinkPad serial: <superuser required>
    part-nu: LENOVO_MT_21M4_BU_Think_FM_ThinkPad E14 Gen 6
    uuid: <superuser required> UEFI: LENOVO v: R2KET30W (1.13 )
    date: 02/07/2025
  ID-1: BAT0 charge: 48.0 Wh (78.8%) condition: 60.9/57.0 Wh (106.8%)
    volts: 12.1 min: 11.3 model: COSMX LNV-5B11M75269�� type: Li-poly
    serial: <filter> status: not charging cycles: 4
  System RAM: total: 32 GiB available: 30.12 GiB used: 3.1 GiB (10.3%)
  Device-1: Channel-A DIMM 0 type: DDR5 detail: synchronous unbuffered
    (unregistered) size: 16 GiB speed: 4800 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64
    manufacturer: Micron Technology part-no: MTC8C1084S1SC56BD1
    serial: <filter>
  Device-2: Channel-B DIMM 0 type: DDR5 detail: synchronous unbuffered
    manufacturer: Ramaxel Technology part-no: RMSB3410HA88IBF-5600
    serial: <filter>
  Info: model: AMD Ryzen 5 7535HS with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 3+ gen: 3 level: v3 note: check built: 2022 process: TSMC n6 (7nm)
    family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404107
    desc: 6x512 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1108 min/max: 400/4603 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 1108 2: 1108 3: 1108
    4: 1108 5: 1108 6: 1108 7: 1108 8: 1108 9: 1108 10: 1108 11: 1108 12: 1108
    bogomips: 79075
    xsaves xtopology
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Rembrandt [Radeon 680M]
    vendor: Lenovo driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
    process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s
    lanes: 16 ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6,
    HDMI-A-1, Writeback-1 bus-ID: 04:00.0 chip-ID: 1002:1681 class-ID: 0300
    temp: 39.0 C
  Device-2: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2 chip-ID: 5986:1198
  Display: x11 server: X.org v: 1.21.1.16 with: Xwayland v: 24.1.6
    compositor: gnome-shell driver: X: loaded: amdgpu
    gpu: amdgpu display-ID: :0 note: <missing: xdpyinfo/xrandr>
  Monitor-1: eDP-1 model: BOE Display 0x0a35 built: 2021 res: 1920x1200
    dpi: 161 gamma: 1.2 chroma: red: x: 0.596 y: 0.369 green: x: 0.349 y: 0.576
    blue: x: 0.157 y: 0.125 white: x: 0.314 y: 0.329
    size: 302x189mm (11.89x7.44") diag: 356mm (14") ratio: 16:10
    modes: 1920x1200, 1920x1080, 1600x1200, 1680x1050, 1280x1024, 1440x900,
    1280x800, 1280x720, 1024x768, 800x600, 640x480
    device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.2-arch1.2
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon 660M (radeonsi rembrandt
    LLVM 19.1.7 DRM 3.61 6.12.20-2-MANJARO) device-ID: 1002:1681
    memory: 1000 MiB unified: no
  Info: Tools: api: eglinfo,glxinfo x11: xprop
  Device-1: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High Definition
    Audio vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 04:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
    vendor: Lenovo driver: snd_pci_acp6x v: kernel alternate: snd_pci_acp3x,
    snd_rn_pci_acp3x, snd_pci_acp5x, snd_acp_pci, snd_rpl_pci_acp6x,
    snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
    snd_sof_amd_vangogh, snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
    vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.12.20-2-MANJARO status: kernel-api tools: N/A
  Server-2: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
    status: active 2: wireplumber status: active
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp1s0 state: down mac: <filter>
  Device-2: Realtek RTL8852BE PCIe 802.11ax Wireless Network vendor: Lenovo
    driver: rtw89_8852be v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:b852 class-ID: 0280
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:2 chip-ID: 0bda:4853
  Local Storage: total: 476.94 GiB used: 77.57 GiB (16.3%)
    model: MZAL8512HDLU-00BLL size: 476.94 GiB block-size: physical: 512 B
    fw-rev: 7L2QKXD7 temp: 28.9 C scheme: GPT
  ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
    used: 77.56 GiB (16.6%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: c3bb4485-62f7-48af-b88b-0dce0541fcb9
    used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: B834-A8A3
  ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
    file: /swapfile
  Device-1: 1-4:2 info: Realtek Bluetooth Radio type: bluetooth
    driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 0bda:4853 class-ID: e001 serial: <filter>
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 3 rev: 2.0
  Device-1: 3-3:2 info: Elan Micro ELAN:ARM-M4 type: <vendor specific>
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 100mA chip-ID: 04f3:0c8c class-ID: 0000
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Device-1: 5-1:2 info: Bison Integrated Camera type: video driver: uvcvideo
    interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 5986:1198 class-ID: fe01 serial: <filter>
  Hub-6: 6-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
  Hub-7: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-8: 8-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-9: 9-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-10: 9-1:2 info: VIA Labs USB2.0 Hub ports: 5 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2817
  Device-1: 9-1.1:3 info: Lenovo USB-A Unified Pairing Receiver
    type: keyboard,mouse driver: hid-generic,usbhid interfaces: 4 rev: 2.0
    chip-ID: 17ef:6116 class-ID: 0301
  Device-2: 9-1.3:4 info: Lenovo Billboard Device type: keyboard,billboard
    lanes: 1 mode: 1.1 chip-ID: 17ef:10c0 class-ID: 1100 serial: <filter>
  Device-3: 9-1.4:5 info: Apple Aluminium Keyboard (ANSI)
    type: keyboard,mouse driver: apple,usbhid interfaces: 2 rev: 2.0
    chip-ID: 05ac:024f class-ID: 0301
  Device-4: 9-1.5:6 info: VIA Labs USB Billboard Device type: billboard
    driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 chip-ID: 2109:8817 class-ID: 1100 serial: <filter>
  Hub-11: 10-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-12: 10-1:2 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0817
  System Temperatures: cpu: 41.0 C mobo: 33.5 C gpu: amdgpu temp: 40.0 C
  Fan Speeds (rpm): fan-1: 0 fan-2: 0
  Packages: pm: pacman pkgs: 1114 libs: 339 tools: gnome-software,pamac
  CPU top: 5 of 345
  1: cpu: 11.4% command: localsearch-extractor-3 pid: 11790
    mem: 38.1 MiB (0.1%)
  2: cpu: 6.6% command: firefox pid: 6097 mem: 704.5 MiB (2.2%)
  3: cpu: 3.1% command: gnome-shell pid: 5405 mem: 406.5 MiB (1.3%)
  4: cpu: 1.9% command: firefox pid: 6339 mem: 324.4 MiB (1.0%)
  5: cpu: 1.6% command: Xorg pid: 5293 mem: 215.6 MiB (0.6%)
  Memory top: 5 of 345
  1: mem: 704.5 MiB (2.2%) command: firefox pid: 6097 cpu: 6.6%
  2: mem: 406.5 MiB (1.3%) command: gnome-shell pid: 5405 cpu: 3.1%
  3: mem: 324.4 MiB (1.0%) command: firefox pid: 6339 cpu: 1.9%
  4: mem: 316.6 MiB (1.0%) command: firefox pid: 6279 cpu: 0.9%
  5: mem: 300.4 MiB (0.9%) command: firefox pid: 10722 cpu: 0.1%
  Processes: 345 Power: uptime: 1h 24m states: freeze,mem,disk suspend: s2idle
    image: 12.03 GiB services: gsd-power, power-profiles-daemon, upowerd
  Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Zsh v: 5.9
    running-in: gnome-terminal inxi: 3.3.37
Thank you for taking the time to provide an informative Support request in accordance with forum guidelines. It’s quite refreshing.
I’m sure someone will help when they are able.
In the meantime, some further information that will likely be useful.
Required reading
Resources
Update: got myself another USB Hub - Canyon Docking DS-7 7in1 USB-C Wireless and it works for me
