After upgrade my PineBook Pro to Manjaro 23.02 XFCE the left USB stopped working
Hi there!
I do not have much experience with Manjaro (I’m Debian/Ubuntu user), but interested in Manjaro and Arch.
Yesterday I followed Aragorn suggestion and updated my system:
I had a similar problem about a month ago after updating my PineBook Pro. No matter what I did, the USB Type-C port simply wouldn’t work, however, oddly enough I discovered that after shutdown the PineBook Pro and then use the barrel charger for a full charge, the USB Type-C suddenly worked and have been working since then.
I know that it sounds really weird and it might not work on your case, but that is what I did, so I think it is worth the try. Just remember to NEVER try to use the barrel port and USB Type-C simultaneously for charging as it could fry your motherboard.
Hello! New PBP Manjaro ARM user here. I’m coming from X86 Debian and am a bit lost. I have the non-functional USB 3.0 port on the left of PBB issue. What is a safe stable kernel I can install and how do I do it? I’m unfamiliar with Pac-Man and dos/don’ts of Manjaro. Thanks in advance!
