LED Microphone Mute issues with different Kernel versions
On my LENOVO T14s (AMD) Gen 1. the LED (F4) indicating the Microphone Mutehas been working properla. With some update it did not light any longer and somebody adviced me that this may be based on the Kernel. With the actual UPdate 09.08.2021) I noticed this difference:
  • OLD: Kernel Version: 5.10.53-1-MANJARO (64-bit) → LED permanently OFF
  • NEW: Kernel Version: 5.10.56-1-MANJARO (64-bit) → LED permanantly ON
The microphone itself including muting / UNmuting is working properly, it’s only an issue with the LED.
I can’t any longer reply to this:
But this is to confirm, that the Microphone Mute LED works fine since Kernel 5.15.38-1-MANJARO (linux515)
Thanks to everybody, who has been working on this!
Have you tried any other kernels yet? 5.4 and 5.14 would be high on my list…
:crossed_fingers:
Thank you @Fabby,
Not yet and as I’m using Manjaro since very few months, I’ve no idea, how to to this; actually I’m searching a tutorial
If you’re new, go to your launcher and type or look for kernel. That should brighten your day!
:sun_with_face:
Thanks again @Fabby,
started kernel earleir, this shows the installed versions, allows to remove some. But I don’t see an option to choose a different one. I’m thinking about the boot options
Have a look over at the wiki and if you get stuck there, let us know which exact item you’re stuck at.
https://wiki.manjaro.org/index.php/Manjaro_Kernels
:crossed_fingers:
Thank you @Fabby,
mhwd-kernel --listinstalled
Currently running: 5.10.56-1-MANJARO (linux510)
   * linux510
   * linux54
During boot, I went to options and chose the 5.4 version. Then startup is delayed by start-jobs for three USB-devices, that are not mounted actually as they are used for Backups only. Back to Kernel 5.10, there is no issue like that.
Did you forget to test 5.14 Stable?
:grin:
Thank you @Fabby, no, this …
… was on purpose: On my system 5.14 is experimental (ref. screenshot) and I feel not experienced enough, to try that.
Any idea about the issue with 5.10? The USB-drives are defined in /etc/fstab:
#//USB-Drives
UUID=7f13008d-50e6-4eec-9503-efd757892494  /media/myBook8_A ext4   auto,nofail,rw,async,users    0 0
UUID=1e05302f-ee5e-4a82-9c45-fa05d2146162  /media/myBook8_B ext4   auto,nofail,rw,async,users    0 0
UUID=4bb7051f-0059-4b3d-918e-8d5a97c56a0e  /media/HDD2go    ext4   auto,nofail,rw,async,users   0 0
Probiere mahl 5.13!
In that case, try 5.13 first then…
:wink:
Not without both:
  1. An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
    Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
  2. a sudo lsblk
:scream:
Thanks, here we go …
$ inxi --admin --verbosity=7 --filter --no-host --width
  Kernel: 5.10.56-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=3fb81935-3c2a-4b83-ae67-7b8f75e23839 rw text apparmor=1
  security=apparmor resume=UUID=338139c5-0361-42c0-9573-dbd00f711a01
  udev.log_priority=3 noplymouth acpi_backlight=none
  Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: LENOVO product: 20UH001QGE v: ThinkPad T14s Gen 1
  serial: <filter> Chassis: type: 10 serial: <filter>
  Mobo: LENOVO model: 20UH001QGE serial: <filter> UEFI: LENOVO
  v: R1CET60W(1.29 ) date: 11/30/2020
  ID-1: BAT0 charge: 45.9 Wh (87.1%) condition: 52.7/57.0 Wh (92.4%)
  volts: 12.9 min: 11.5 model: SMP 5B10W139 type: Li-poly serial: <filter>
  status: Charging cycles: 205
  RAM: total: 30.65 GiB used: 2.88 GiB (9.4%)
  Info: 8-Core model: AMD Ryzen 7 PRO 4750U with Radeon Graphics bits: 64
  type: MT MCP arch: Zen 2 family: 17 (23) model-id: 60 (96) stepping: 1
  microcode: 8600106 cache: L2: 4 MiB bogomips: 54324
  Speed: 2101 MHz min/max: 1400/1700 MHz boost: enabled Core speeds (MHz):
  1: 2101 2: 1931 3: 1662 4: 1910 5: 1487 6: 1459 7: 1469 8: 1450 9: 1746
  10: 1664 11: 1617 12: 1618 13: 1598 14: 1692 15: 1397 16: 1532
  fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs irperf lahf_lm
  lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
  nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
  pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
  popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
  skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
  svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload vgif
  vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
  xsaves
  Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
  Device-1: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel bus-ID: 06:00.0
  chip-ID: 1002:1636 class-ID: 0300
  Device-2: IMC Networks Integrated Camera type: USB driver: uvcvideo
  bus-ID: 2-2:2 chip-ID: 13d3:5405 class-ID: fe01 serial: <filter>
  loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
  display-ID: :0 screens: 1
  s-diag: 582mm (22.9")
  Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 158 size: 309x173mm (12.2x6.8")
  diag: 354mm (13.9")
  OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.10.56-1-MANJARO LLVM 12.0.1)
  v: 4.6 Mesa 21.1.6 direct render: Yes
  Device-1: AMD vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 06:00.1
  chip-ID: 1002:1637 class-ID: 0403
  Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo
  driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x bus-ID: 06:00.5
  chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
  v: kernel bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Sound Server-1: ALSA v: k5.10.56-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.33 running: no
  vendor: Lenovo driver: r8169 v: kernel port: 2400 bus-ID: 02:00.0
  IF: enp2s0f0 state: down mac: <filter>
  Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: 2000
  bus-ID: 03:00.0 chip-ID: 8086:2723 class-ID: 0280
  Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 6-4:3
  Local Storage: total: 2.05 TiB used: 987.11 GiB (47.1%)
  model: SSD 970 EVO Plus 2TB size: 1.82 TiB block-size: physical: 512 B
  rev: 2B2QEXM7 temp: 48.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 type: USB vendor: SanDisk model: USB 3.2Gen1
  size: 232.88 GiB block-size: physical: 512 B logical: 512 B type: N/A
  serial: <filter> rev: 1.00 scheme: MBR
  ID-1: / raw-size: 32 GiB size: 31.25 GiB (97.65%) used: 27.28 GiB (87.3%)
  fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3 label: Manjaro
  uuid: 3fb81935-3c2a-4b83-ae67-7b8f75e23839
  used: 17.5 MiB (3.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  label: UEFI-ESP uuid: F8E8-132F
  ID-3: /home raw-size: 32 GiB size: 31.25 GiB (97.65%) used: 9.69 GiB (31.0%)
  fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4 label: home
  uuid: 36be0edf-49c4-4ee0-96a3-4da6bc64a86c
  ID-4: /home/<filter>/VirtualBoxVMs raw-size: 300 GiB
  size: 294.29 GiB (98.10%) used: 122.5 GiB (41.6%) fs: ext4
  dev: /dev/nvme0n1p5 maj-min: 259:5 label: Virtual
  uuid: c29b5da5-b959-4989-87ed-6db493b9c3a0
  ID-5: /mnt/Daten raw-size: 1.21 TiB size: 1.19 TiB (98.35%)
  used: 786.51 GiB (64.8%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
  label: Daten uuid: 249b9b5a-332c-4176-8a2e-9cef91138ce6
  ID-6: /run/media/myname/ventoy raw-size: 228.84 GiB
  size: 228.84 GiB (100.00%) used: 41.12 GiB (18.0%) fs: exfat dev: /dev/sda1
  maj-min: 8:1 label: ventoy uuid: 896D-52F3
  ID-1: swap-1 type: partition size: 64 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/nvme0n1p2 maj-min: 259:2 label: Swap
  uuid: 338139c5-0361-42c0-9573-dbd00f711a01
  ID-1: /dev/nvme0n1p6 maj-min: 259:6 size: 200 GiB fs: ext4 label: TimeShift
  uuid: ee73659c-5cf3-46d2-a7c8-29db485d1b85
  ID-2: /dev/sda2 maj-min: 8:2 size: 32 MiB fs: vfat label: VTOYEFI
  uuid: 909C-8E10
  ID-3: /dev/sda3 maj-min: 8:3 size: 4 GiB fs: ext4 label: TestDaten
  uuid: 5f88b7c6-5417-4f7f-884b-40a5f588b9b0
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Device-1: 2-2:2 info: IMC Networks Integrated Camera type: Video
  driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s power: 500mA
  Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
  Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Device-1: 4-3:2 info: Alcor Micro AU9540 Smartcard Reader type: Smart Card
  driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 50mA
  chip-ID: 058f:9540 class-ID: 0b00
  Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
  Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Device-1: 6-3:2 info: Synaptics Prometheus MIS Touch Fingerprint Reader
  type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s
  power: 100mA chip-ID: 06cb:00bd class-ID: ff00 serial: <filter>
  Device-2: 6-4:3 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
  class-ID: e001
  Hub-7: 7-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
  Device-1: 7-2:2 info: SanDisk Ultra type: Mass Storage driver: usb-storage
  interfaces: 1 rev: 3.2 speed: 5 Gb/s power: 896mA chip-ID: 0781:5581
  class-ID: 0806 serial: <filter>
  System Temperatures: cpu: 65.9 C mobo: 0.0 C gpu: amdgpu temp: 46.0 C
  Fan Speeds (RPM): cpu: 2800
  Processes: 343 Uptime: 30m wakeups: 1 Init: systemd v: 248 tool: systemctl
  Compilers: gcc: 11.1.0 Packages: pacman: 1506 lib: 395 Shell: Bash v: 5.1.8
  running-in: konsole inxi: 3.3.06
and the second part:
$ sudo lsblk
NAME        MAJ:MIN RM   SIZE RO TYPE MOUNTPOINTS
sda           8:0    1 232,9G  0 disk
├─sda1        8:1    1 228,8G  0 part /run/media/myname/ventoy
├─sda2        8:2    1    32M  0 part
└─sda3        8:3    1     4G  0 part
nvme0n1     259:0    0   1,8T  0 disk
├─nvme0n1p1 259:1    0   512M  0 part /boot/efi
├─nvme0n1p2 259:2    0    64G  0 part [SWAP]
├─nvme0n1p3 259:3    0    32G  0 part /
├─nvme0n1p4 259:4    0    32G  0 part /home
├─nvme0n1p5 259:5    0   300G  0 part /home/myname/VirtualBoxVMs
├─nvme0n1p6 259:6    0   200G  0 part
└─nvme0n1p7 259:7    0   1,2T  0 part /mnt/Daten
Try 5.13 first and if that doesn’t solve the problem, try 5.14 RC3.
Note: Don’t delete 5.10; just add 5.13 and 5.14 and try them out by going to the advanced options of grub and see if the problem goes away automagically
If it doesn’t, remove them again…
:crossed_fingers:
This system has a setting in ALSA for the LED - ‘Mute-LED Mode’
I would expect it to take the first available option by default (On) unless it is set to a specific option by user
This command should change the LED setting to show when sound is muted
amixer --card=2 sset 'Mute-LED Mode' 'Follow Master'
The terminal response should confirm the new setting:
HW probe of Lenovo ThinkPad T14s Gen 1 … #67d6c15711: amixer
Simple mixer control 'Mute-LED Mode',0
  Capabilities: enum
  Items: 'On' 'Off' 'Follow Master'
  Item0: 'On'
But this on Lenovo forum suggests there may be a bug in firmware
English Community-Lenovo Community
Done this, the response is a bit different:
$ amixer --card=2 sset 'Mute-LED Mode' 'Follow Master'
  Capabilities: enum
  Item0: 'Follow Master'
The LED behaviour is as before:
  • Kernel Version: 5.10.53-1-MANJARO (64-bit) → LED permanently OFF
  • Kernel Version: 5.10.56-1-MANJARO (64-bit) → LED permanantly ON
  • Kernel Version: 5.10.59-1-MANJARO (64-bit) → LED permanantly ON
Done that, no changes for the LED:
  • Kernel Version: 5.13.11-1-MANJARO (64-bit) → LED permanantly ON
I do not dare to use version 5.14 as it is experimental …
I have edited my previous post because the URL to the hardware probe was for an T14s model with an Intel CPU not a AMD Ryzen
I could not find a match for your model number and must have copied the URL from the wrong tab
But I have noticed many of the other T14s models have 4 options for the LED
Simple mixer control 'Mic Mute-LED Mode',0
  Capabilities: enum
  Items: 'On' 'Off' 'Follow Capture' 'Follow Mute'
  Item0: 'Follow Mute'
I suspect your ALSA option ‘Follow Master’ would only indicate if audio playback is muted
try this command to see if LED changes when audio playback is muted [off] or unmuted [on]
amixer -c2 'Master' toggle
Sorry, this provides an error:
$ amixer -c2 'Master' toggle
amixer: Unknown command 'Master'...
I missed the key part of the command :man_facepalming:
amixer -c2 sset 'Master' toggle
If the LED is not following the control on the card it might be following the default PulseAudio level control
amixer sset 'Master' toggle
Thank you @nikgnomic
$ amixer -c2 sset 'Master' toggle
toggles the F1-LED, indicating the speaker’s muting. The F1-LED is working correct for each process to mute / unmute the speakers (F1, System control, etc.)
Try these commands one at a time to see if there are any errors
amixer -c2 sset 'Mic Mute-LED Mode' 'Follow Capture'
amixer -c2 sset 'Capture' nocap
amixer -c2 sset 'Capture' cap
If the Mic Mute LED was working for you on kernel v5.4 you should roll back to that kernel
