Launch RTMP stream on startup
I’m trying to setup some Pi’s to run an RTMP stream at work on multiple TVs throughout campus.
I’ve setup a systemd .service and .timer to run a script at launch that references a RTMP stream, but VLC doesn’t allow for running as root. I’ve tried mplayer, but the service reports:
● stream.service - "Runs stream"
     Loaded: loaded (/etc/systemd/system/stream.service; static)
     Active: active (running) since Mon 2022-12-19 13:44:29 MST; 13min ago
TriggeredBy: ● stream.timer
   Main PID: 852 (stream.sh)
      Tasks: 2 (limit: 1818)
        CPU: 58.111s
     CGroup: /system.slice/stream.service
             ├─852 /bin/bash /home/pi/Documents/stream.sh
             └─853 mplayer -fs rtmp://192.168.133.22/screen/rtmp
Dec 19 13:57:28 RDACPI stream.sh[853]: VO: [fbdev] 1920x1080 => 1920x1080 BGR 16-bit  [fs]
Dec 19 13:57:28 RDACPI stream.sh[853]: Can't put VSCREENINFO: Invalid argument
Dec 19 13:57:28 RDACPI stream.sh[853]: FATAL: Cannot initialize video driver.
Dec 19 13:57:28 RDACPI stream.sh[853]: Too many buffered pts
Dec 19 13:57:30 RDACPI stream.sh[853]: Movie-Aspect is 1.78:1 - prescaling to correct movie aspect.
Dec 19 13:57:30 RDACPI stream.sh[853]: [swscaler @ 0xffff91b17af8]No accelerated colorspace conversion found from yuv420p to rgb565le.
Dec 19 13:57:30 RDACPI stream.sh[853]: VO: [fbdev] 1920x1080 => 1920x1080 BGR 16-bit  [fs]
Dec 19 13:57:30 RDACPI stream.sh[853]: Can't put VSCREENINFO: Invalid argument
Dec 19 13:57:30 RDACPI stream.sh[853]: FATAL: Cannot initialize video driver.
Dec 19 13:57:30 RDACPI stream.sh[853]: Too many buffered pts
It would be safe to assume there’s an issue with the video driver, but running the target script which is just mplayer rtmp://(ip of stream) turns out fine.
I’m running it on a Pi 4 Model B, but here’s a quick neofetch just if someone had questions about the environment
██████████████████  ████████   pi@RDACPI
██████████████████  ████████   OS: Manjaro ARM Linux aarch64
██████████████████  ████████   Host: Raspberry Pi 4 Model B Rev 1.2
████████            ████████   Kernel: 5.15.82-1-MANJARO-ARM-RPI
████████  ████████  ████████   Uptime: 22 mins
████████  ████████  ████████   Packages: 673 (pacman)
████████  ████████  ████████   Shell: bash 5.1.16
████████  ████████  ████████   Resolution: 1920x1080
████████  ████████  ████████   DE: Xfce 4.16
████████  ████████  ████████   WM: Xfwm4
████████  ████████  ████████   WM Theme: Default
████████  ████████  ████████   Theme: Matcha-dark-sea [GTK2], Adwaita [GTK3]
████████  ████████  ████████   Icons: Papirus-Dark-Maia [GTK2], Adwaita [GTK3]
                               Terminal: xfce4-terminal
                               Terminal Font: Monospace 12
                               CPU: BCM2835 (4) @ 1.500GHz
Why do you want to run as root?
Please post your systemd unit file (. service).
I guess it runs too early.
Didn’t have any desire to run it in root, just forgot about the autostart folder.
Got it working by creating a .desktop file in /home/pi/.config/autostart that read
[Desktop Entry]
Type=Application
Exec=cvlc -f rtmp://(ip of stream)
Thanks for your help!
