I’ve been using latte-dock for a long time, but recently I uninstalled it to reinstall the git version for the ability to use the floating sidebar and docks. However when I run it (both terminal and by the application menu) it doesn’t show up. It’s is running and I’ve tried to end the process and start it again but the same thing. The normal latte and the other latte-git version in the AUR (the one you have to build) yield the same results.
When I run in terminal I get "“An instance is already running!, use --replace to restart Latte”
So I did so - but for some reason the --replace command is not find.
Perhaps I should delete all of Latte’s configuration files but I’m not sure how to this.
An extension to the question I’m wondering how to make the latte-side bar widget work. It did work once but I’m unable to replicate the OnDemand side-bar. I’m running plasma 5.19 and will be (hopefully) running latte-dock git!
I have latte-dock installed.
In Krunner, latte-dock --replace
works fine. Maybe your typing is off…
It’s also a great idea to move/rename the config folder to get a fresh start, then think about re-importing bits as you need them.
I have a constant problem with the layout - every time I kill latte or do a reboot, I get the message
Latte did not close properly in the previous session. The following layout(s) [My Layout - 3] were updated for consistency!!!
It’s a bit sucky, but I like it because it has a nice systray that goes in the bottom right of my screen with the task manager on the right edge of the screen. I don’t even know what the side-bar is, more clutter probably.
My experince with .git version is I have to logout and login then it shows up.
I just installed the git, which removed the current version - works okay. Maybe try going to your ~/.config folder, duplicate the latte folder, then open them up side by side in dolphin and delete the contents of the original.
Starting up Latte should create a default. If that works, then you can do 'killall latte-dock
in krunner, copy your favourite back - and then do ‘latte-dock --replace’ in krunner (those are remembered, so rather than just launch latte-dock, I do the --replace).
Anyway, I’m back with it, I must say it seems buggy with respect to keyboard shortcuts (getting my main menu to bind to meta+z took a couple of attempts) otherwise it’s okay.
If you fancy trying my config it’s here:
Summary
[ActionPlugins][1]
RightButton;NoModifier=org.kde.latte.contextmenu
[Containments][13]
PreloadWeight=26
activityId=
formfactor=2
immutability=1
lastScreen=-1
layoutId=
location=4
plugin=org.kde.plasma.private.systemtray
wallpaperplugin=org.kde.image
[Containments][13][Applets][42]
immutability=1
plugin=org.kde.plasma.diskquota
[Containments][13][Applets][42][Configuration]
PreloadWeight=51
[Containments][13][Applets][43]
immutability=1
plugin=org.kde.plasma.keyboardindicator
[Containments][13][Applets][43][Configuration]
PreloadWeight=36
[Containments][13][Applets][43][Configuration][ConfigDialog]
DialogHeight=480
DialogWidth=640
[Containments][13][Applets][43][Configuration][General]
key=Caps Lock,Num Lock
[Containments][13][Applets][44]
immutability=1
plugin=org.kde.kdeconnect
[Containments][13][Applets][44][Configuration]
PreloadWeight=36
[Containments][13][Applets][45]
immutability=1
plugin=org.kde.plasma.clipboard
[Containments][13][Applets][45][Configuration]
PreloadWeight=26
[Containments][13][Applets][46]
immutability=1
plugin=org.kde.plasma.volumewin7mixer
[Containments][13][Applets][46][Configuration]
PreloadWeight=76
[Containments][13][Applets][46][Configuration][Applet]
showVisualFeedback=false
volumeUpDownSteps=20
[Containments][13][Applets][46][Configuration][ConfigDialog]
DialogHeight=1058
DialogWidth=1920
[Containments][13][Applets][47]
immutability=1
plugin=fokus
[Containments][13][Applets][47][Configuration]
PreloadWeight=76
[Containments][13][Applets][47][Configuration][ConfigDialog]
DialogHeight=503
DialogWidth=1021
[Containments][13][Applets][47][Configuration][General]
timer_start_sfx_enabled=true
timer_start_sfx_filepath=file:///home/ben/Dropbox/DB-Resources/Sounds/210 Small chirp.wav
timer_stop_sfx_filepath=file:///home/ben/Dropbox/DB-Resources/Sounds/reminder3.wav
[Containments][13][Applets][48]
immutability=1
plugin=org.kde.plasma.notifications
[Containments][13][Applets][48][Configuration]
PreloadWeight=76
[Containments][13][Applets][48][Configuration][ConfigDialog]
DialogHeight=540
DialogWidth=720
[Containments][13][Applets][49]
immutability=1
plugin=org.kde.plasma.nightcolorcontrol
[Containments][13][Applets][49][Configuration]
PreloadWeight=26
[Containments][13][Applets][50]
immutability=1
plugin=org.kde.plasma.networkmanagement
[Containments][13][Applets][50][Configuration]
PreloadWeight=76
[Containments][13][Applets][51]
immutability=1
plugin=org.kde.ktp-contactlist
[Containments][13][Applets][51][Configuration]
PreloadWeight=56
[Containments][13][Applets][51][Configuration][ConfigDialog]
DialogHeight=540
DialogWidth=720
[Containments][13][Applets][52]
immutability=1
plugin=org.kde.plasma.printmanager
[Containments][13][Applets][52][Configuration]
PreloadWeight=26
[Containments][13][Applets][54]
immutability=1
plugin=touchpad
[Containments][13][Applets][54][Configuration]
PreloadWeight=26
[Containments][13][Applets][55]
immutability=1
plugin=org.kde.plasma.devicenotifier
[Containments][13][Applets][55][Configuration]
PreloadWeight=76
[Containments][13][Applets][57]
immutability=1
plugin=org.kde.plasma.battery
[Containments][13][Applets][57][Configuration]
PreloadWeight=76
[Containments][13][Applets][57][Shortcuts]
global=Ctrl+Alt+ScrollLock
[Containments][13][Applets][65]
immutability=1
plugin=org.kde.plasma.mediacontroller
[Containments][13][Applets][65][Configuration]
PreloadWeight=60
[Containments][13][ConfigDialog]
DialogHeight=1058
DialogWidth=640
[Containments][13][General]
blockedAutoColorItems=easystroke,dropbox-client-1461,guayadeque,MSM Notifier for Plasma5,org.kde.plasma.notifications,PulseAudio system tray,qBittorrent,Solaar,ulauncher,Discover Notifier_org.kde.DiscoverNotifier,org.kde.plasma.bluetooth,org.kde.plasma.devicenotifier,org.kde.kscreen,org.kde.kdeconnect,org.kde.plasma.keyboardindicator,org.kde.plasma.networkmanagement,org.kde.plasma.printmanager,touchpad,org.kde.plasma.clipboard,org.kde.plasma.diskquota,org.kde.plasma.weather,org.kde.plasma.katesessions,org.kde.plasma.nightcolorcontrol,org.kde.plasma.volume,ClipGrab,dropbox-client-63840,fokus,pamac-qt,dropbox-client-2371,dropbox-client-2446,dropbox-client-2414,mailspring,org.kde.plasma.mediacontroller,CopyQ,dropbox-client-2734,variety,sayonara,Audacious,Yakuake,org.kde.ktp-contactlist,pamac-tray-plasma,Pamac Updates,KDE Daemon,app-00007F220D9CE8F0,dropbox-client-1877,deadbeef,Cantata,dropbox-client-1729,Mailspring1,org.kde.plasma.battery,indicator-solaar,dropbox-client-1779,org.kde.plasma.volumewin7mixer,Joplin1,dropbox-client-1290,flameshot,Stacer,Onboard,FeatherNotes,dropbox-client-35477,KTimer,dropbox-client-1303,dropbox-client-1422,dropbox-client-1267,dropbox-client-63611,org.kde.plasma.mediacontroller_plus
extraItems=org.kde.plasma.devicenotifier,org.kde.plasma.nightcolorcontrol,org.kde.plasma.notifications,org.kde.plasma.clipboard,CopyQ,dropbox-client-2120,easystroke,PulseAudio system tray,ulauncher,indicator-solaar,Discover Notifier_org.kde.DiscoverNotifier,dropbox-client-5425,dropbox-client-2349,org.kde.plasma.diskquota,fokus,org.kde.plasma.mediacontroller,dropbox-client-2451,KDE Daemon,dropbox-client-2396,Solaar,dropbox-client-1517,dropbox-client-1461,Mailspring1,dropbox-client-1484,dropbox-client-63840,dropbox-client-2371,dropbox-client-2446,dropbox-client-2414,org.kde.plasma.networkmanagement,org.kde.ktp-contactlist,org.kde.plasma.keyboardindicator,org.kde.plasma.battery,org.kde.kdeconnect,org.kde.plasma.volumewin7mixer,org.kde.plasma.printmanager,touchpad
hiddenItems=dropbox-client-2120,PulseAudio system tray,org.kde.plasma.clipboard,dropbox-client-5425,dropbox-client-2349,dropbox-client-2451,dropbox-client-2396,Solaar,dropbox-client-1517,dropbox-client-1461,dropbox-client-1484,dropbox-client-63840,dropbox-client-2371,dropbox-client-2446,dropbox-client-2414,org.kde.ktp-contactlist,CopyQ,org.kde.plasma.networkmanagement,ulauncher,org.kde.plasma.battery
iconSize=3
knownItems=org.kde.kdeconnect,org.kde.plasma.printmanager,org.kde.plasma.devicenotifier,org.kde.plasma.bluetooth,org.kde.plasma.nightcolorcontrol,org.kde.plasma.battery,org.kde.plasma.volume,org.kde.plasma.keyboardindicator,org.kde.plasma.notifications,org.kde.plasma.networkmanagement,org.kde.plasma.clipboard,org.kde.plasma.mediacontroller,org.kde.plasma.volumewin7mixer,org.kde.ktp-contactlist,org.kde.plasma.mediacontroller_plus
pin=true
shownItems=org.kde.plasma.volumewin7mixer
[Containments][14]
activityId=
byPassWM=false
dockWindowBehavior=true
enableKWinEdges=true
formfactor=2
immutability=1
isPreferredForShortcuts=false
lastScreen=10
layoutId=
location=4
onPrimary=true
plugin=org.kde.latte.containment
raiseOnActivityChange=true
raiseOnDesktopChange=false
settingsComplexity=4
timerHide=700
timerShow=200
viewType=0
visibility=3
[Containments][14][Applets][58]
immutability=1
plugin=org.kde.plasma.systemtray
[Containments][14][Applets][58][Configuration]
PreloadWeight=81
SystrayContainmentId=13
[Containments][14][Applets][59]
immutability=1
plugin=org.kde.latte.sidebarbutton
[Containments][14][Applets][59][Configuration]
PreloadWeight=26
[Containments][14][Applets][60]
immutability=1
plugin=org.kde.plasma.advancedradio
[Containments][14][Applets][60][Configuration]
PreloadWeight=100
[Containments][14][Applets][60][Configuration][Appearance]
fontColor=#000000
icon=de.haeckerfelix.Shortwave-symbolic
[Containments][14][Applets][60][Configuration][ConfigDialog]
DialogHeight=577
DialogWidth=832
[Containments][14][Applets][60][Configuration][General]
servers=[{“status”:0,“active”:true,“hostname”:“http://bbcmedia.ic.llnwd.net/stream/bbcmedia_radio2_mf_p",“name”:"BBC Radio 2”},{“status”:0,“active”:true,“hostname”:“http://bbcmedia.ic.llnwd.net/stream/bbcmedia_radio1_mf_p",“name”:"BBC Radio 1”},{“status”:0,“active”:true,“hostname”:“http://bbcmedia.ic.llnwd.net/stream/bbcmedia_radio4fm_mf_p",“name”:"BBC Radio 4”},{“status”:0,“active”:true,“hostname”:“http://bbcmedia.ic.llnwd.net/stream/bbcmedia_radio4extra_mf_p",“name”:"BBC Radio 4 Extra”},{“status”:0,“active”:true,“hostname”:“http://149.255.59.164:8009”,“name”:“British Comedy Radio”},{“status”:0,“active”:true,“hostname”:“http://149.255.59.164:8009/;",“name”:"ROK Radio - British Comedy 2”},{“status”:0,“active”:true,“hostname”:“http://ecast.myautodj.com:1130/stream",“name”:"Mix FM (Birmingham, UK)”},{“status”:0,“active”:true,“hostname”:“https://22533.live.streamtheworld.com:443/JACK_DAB_HIAAC.aac",“name”:"Union Jack AAC+ (320kbps)”},{“status”:0,“active”:true,“hostname”:“http://stream-tx3.radioparadise.com/aac-128",“name”:“PARADISE”},{“status”:0,“active”:true,“hostname”:“http://air.radiorecord.ru:8102/rock_320”,“name”:"Record Rock”},{“status”:0,“active”:true,“hostname”:“http://ic7.101.ru:8000/c1_4",“name”:"Hard Rock”},{“status”:0,“active”:true,“hostname”:“https://opml.radiotime.com/Tune.ashx?id=s297919&formats=mp3,aac,wma,ogg&partnerId=xwhZkVKi&filter=s:popular",“name”:"Smooth Jazz”},{“status”:0,“active”:true,“hostname”:“https://opml.radiotime.com/Tune.ashx?id=s14805&formats=mp3,aac,wma,ogg&partnerId=xwhZkVKi",“name”:"COOLfahrenheit 93.0 (Easy Listening)”},{“status”:0,“active”:true,“hostname”:“http://89.16.185.174:8003/stream",“name”:"Linn Radio”},{“status”:0,“active”:true,“hostname”:“http://89.16.185.174:8000/stream",“name”:"Linn Jazz”},{“status”:0,“active”:true,“hostname”:“http://89.16.185.174:8004/stream",“name”:"Linn Classical”},{“status”:0,“active”:false,“hostname”:“http://89.16.185.174:8004/stream",“name”:"Linn Classical”},{“status”:0,“active”:true,“hostname”:“http://radio.virginradio.co.uk/stream",“name”:"Virgin Radio UK”},{“status”:0,“active”:true,“hostname”:“http://media-the.musicradio.com/RadioXLondonMP3",“name”:"Radio X London (MP3)”},{“status”:0,“active”:true,“hostname”:“http://ecast.myautodj.com:1130/stream",“name”:"Mix FM (Birmingham, UK)”},{“status”:0,“active”:true,“hostname”:“http://radio.canstream.co.uk:8075/live.mp3",“name”:"Jazz London Radio”},{“status”:0,“active”:true,“hostname”:“http://music.ghrmidlands.com:8000/live.mp3",“name”:"Greatest Hits Radio Midlands UK”},{“status”:0,“active”:true,“hostname”:“http://a.files.bbci.co.uk/media/live/manifesto/audio/simulcast/hls/nonuk/sbr_low/llnw/bbc_world_service.m3u8",“name”:"BBC World Service”}]
version=1.7
[Containments][14][Applets][60][Shortcuts]
global=Tools
[Containments][14][Applets][61]
immutability=1
plugin=org.kde.plasma.kickoff
[Containments][14][Applets][61][Configuration]
PreloadWeight=100
[Containments][14][Applets][61][Configuration][ConfigDialog]
DialogHeight=480
DialogWidth=640
[Containments][14][Applets][61][Configuration][General]
favoritesPortedToKAstats=true
systemApplications=systemsettings.desktop,org.kde.kinfocenter.desktop
[Containments][14][Applets][61][Shortcuts]
global=Meta+Z
[Containments][14][Applets][62]
immutability=1
plugin=org.kde.plasma.eventcalendar
[Containments][14][Applets][62][Configuration]
PreloadWeight=81
[Containments][14][Applets][62][Configuration][Agenda]
agendaDaySpacing=0
agendaEventSpacing=17
agendaFontSize=12
agendaInProgressColor=#95846700
agendaWeatherIconHeight=20
twoColumns=false
[Containments][14][Applets][62][Configuration][Calendar]
monthCellRadius=0.1
monthCurrentCustomTitleFormat=MMMM ddd dd yyyy
monthEventBadgeType=bottomBar
monthHeightSingleColumn=360
[Containments][14][Applets][62][Configuration][ConfigDialog]
DialogHeight=876
DialogWidth=1263
[Containments][14][Applets][62][Configuration][Events]
enabledCalendarPlugins=holidaysevents.so,astronomicalevents.so
[Containments][14][Applets][62][Configuration][General]
bottomRowHeight=300
clockFontFamily=Arial Black [TMC ]
clockLine2HeightRatio=0.31
clockTimeFormat1=’’| ddd <>dd<> MMM yyyy |’ ’ h:mm ap’
clockTimeFormat2=d MMMM yyyy
rightColumnWidth=300
showBackground=false
showOutlines=false
timerSfxFilepath=file:///usr/share/sounds/freedesktop/stereo/complete.oga
topRowHeight=125
v71Migration=true
v72Migration=true
[Containments][14][Applets][62][Configuration][Google Calendar]
accessToken=ya29.a0AfH6SMBF7avz1iEKoXeR84pyDMXMzp-9RL-tBmyndC2W6d7Z7M1YaajrpLh3N25a7VMyfx0Zd8o9KKDk-oDKni3tLBQhMDc70LcX07057qWt5iirx0lZ94arpX4lKBUN5Cu22bz8OPhqb4cjNFrYxz9lF1tyw2BhJ2Bynl-opDmh
accessTokenExpiresAt=3880148104
accessTokenType=Bearer
calendarIdList=ben2talk@gmail.com,addressbook#contacts@group.v.calendar.google.com,family10075762188398543217@group.calendar.google.com,en-gb.th#holiday@group.v.calendar.google.com,mailto.rattanaporn@gmail.com
calendarList=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
refreshToken=1//0g1p-fr4RAC2JCgYIARAAGBASNwF-L9IrD-C0q4I15tKyrblkIKYBKxTH4KMz-njXVKZgZn0_yaD1XRjzhMqpLw7nEUI7zEBfzyQ
sessionClientId=391436299960-k0s16nm589meovhoblpcquqgbbrena17.apps.googleusercontent.com
sessionClientSecret=Gdr_7lKIQuGBD4Up3MOiw-7i
tasklistIdList=MDgyNjc5MTg0MjU0NTk1NTU3OTc6MDow
tasklistList=W3sia2luZCI6InRhc2tzI3Rhc2tMaXN0IiwiaWQiOiJNRGd5TmpjNU1UZzBNalUwTlRrMU5UVTNPVGM2TURvdyIsImV0YWciOiJcIk1Ua3dPRFEwTmpreE5nXCIiLCJ0aXRsZSI6IkJlbjJ0YWxrJ3MgbGlzdCIsInVwZGF0ZWQiOiIyMDE5LTA2LTE5VDIxOjU5OjM1LjYzMFoiLCJzZWxmTGluayI6Imh0dHBzOi8vd3d3Lmdvb2dsZWFwaXMuY29tL3Rhc2tzL3YxL3VzZXJzL0BtZS9saXN0cy9NRGd5TmpjNU1UZzBNalUwTlRrMU5UVTNPVGM2TURvdyJ9XQ==
[Containments][14][Applets][62][Configuration][Tooltip]
selectedTimeZones=Local,Europe/London
[Containments][14][Applets][62][Configuration][Weather]
meteogramGridColor=#0359564d
meteogramIconColor=#6419190c
openWeatherMapCityId=1609350
[Containments][14][ConfigDialog]
DialogHeight=980
DialogWidth=480
[Containments][14][Configuration]
PreloadWeight=26
[Containments][14][General]
advanced=false
alignment=2
alignmentUpgraded=true
appletOrder=59;60;58;61;62
closeActiveWindowEnabled=true
durationTime=x1
hideScreenGapForMaximized=true
iconSize=22
inConfigureAppletsMode=true
lengthExtMargin=1
lockedZoomApplets=58;62
maxLength=38
offset=2
panelPosition=Right
panelSize=100
panelTransparency=56
screenEdgeMargin=2
scrollAction=ScrollActivities
shadowColor=000000
shadowColorType=User
shadowOpacity=45
shadowSize=65
shadowsUpgraded=true
showGlow=false
splitterPosition=2
splitterPosition2=3
tasksUpgraded=true
thickMargin=5
zoomLevel=16
[Containments][14][Indicator]
customType=org.kde.latte.dashtopanel
enabled=true
enabledForApplets=true
padding=0.07999999821186066
type=org.kde.latte.default
[Containments][14][Indicator][org.kde.latte.dashtopanel][General]
lengthPadding=0.04
lineThickness=0.2
maxBackgroundOpacity=0.5
[Containments][14][Indicator][org.kde.latte.default][General]
extraDotOnActive=true
glowEnabled=true
glowOpacity=1
lengthPadding=0
minimizedTaskColoredDifferently=true
[Containments][15]
activityId=
byPassWM=false
enableKWinEdges=false
formfactor=3
immutability=1
lastScreen=-1
layoutId=
location=6
onPrimary=true
raiseOnActivityChange=false
timerHide=700
timerShow=200
viewType=0
visibility=2
[Containments][15][Applets][63]
immutability=1
plugin=org.kde.plasma.minimizeall
[Containments][15][Applets][63][Configuration]
PreloadWeight=76
[Containments][15][Applets][63][Configuration][ConfigDialog]
DialogHeight=480
DialogWidth=640
[Containments][15][Applets][63][Shortcuts]
global=Ctrl+Alt+Down
[Containments][15][Applets][64]
immutability=1
plugin=org.kde.latte.plasmoid
[Containments][15][Applets][64][Configuration]
PreloadWeight=26
[Containments][15][Applets][64][Configuration][General]
autoScrollTasksEnabled=false
hoverAction=PreviewWindows
infoBadgeProminentColorEnabled=true
isInLatteDock=true
leftClickAction=CycleThroughTasks
manualScrollTasksType=Disabled
middleClickAction=Close
scrollTasksEnabled=true
showOnlyCurrentActivity=false
showWindowActions=true
[Containments][15][ConfigDialog]
DialogHeight=1026
DialogWidth=480
[Containments][15][Configuration]
PreloadWeight=26
[Containments][15][General]
activeWindowFilter=FromAllScreens
advanced=false
alignment=10
appletOrder=64;63
backgroundOnlyOnMaximized=true
dragActiveWindowEnabled=true
durationTime=x1
hoverAction=PreviewAndHighlightWindows
iconSize=16
launchersGroup=Global
maxLength=51
modifierClickAction=ToggleMinimized
offset=24
panelSize=5
panelTransparency=49
proportionIconSize=3.4000000000000004
screenEdgeMargin=2
shadowColor=000000
shadowOpacity=75
shadowSize=40
shadows=All
showGlow=false
solidBackgroundForMaximized=true
splitterPosition=0
splitterPosition2=2
tasksUpgraded=true
thickMargin=8
zoomLevel=0
[Containments][15][Indicator]
enabled=true
[Containments][15][Indicator][org.kde.latte.dashtopanel][General]
enabledForApplets=false
lengthPadding=0.07
lineThickness=0.2
style=Dashes
[Containments][15][Indicator][org.kde.latte.default][General]
glowApplyTo=OnActive
glowEnabled=true
glowOpacity=0.5
lengthPadding=0
[LayoutSettings]
activities=b0510cba-5bc3-44a5-96bc-9063f4852ca5
backgroundStyle=0
color=blue
customBackground=
customTextColor=
disableBordersForMaximizedWindows=false
icon=
lastUsedActivity=b0510cba-5bc3-44a5-96bc-9063f4852ca5
launchers=
preferredForShortcutsTouched=false
showInMenu=false
version=2
