I have a problem with latte dock that when i try to switch to advanced mode (on the git version) it instead just reboots latte dock.
There’s some oddly specific times it happens, I’m not sure if it’s important but I will include them. My normal dock is on the bottom and clicking new dock creates one on the left side. I can sometimes click the advanced mode in the position but then it won’t move the top. If i move it to the top then try to enable advanced mode it does as described. I want a floating dock/panel on the top and for that I need the advanced mode.
System Imformation
Kernel: 5.7.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
parameters: root=UUID=9ec2e85d-3d12-49e5-9df8-f5a7476ed01d rw quiet
udev.log_priority=3 initrd=boot\initramfs-5.7-x86_64.img
Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0 info: latte-dock wm: kwin_x11
dm: SDDM Distro: Manjaro Linux
Type: Convertible System: LENOVO product: 80X8 v: Lenovo YOGA 520-14IKB
serial: <filter> Chassis: type: 31 v: Lenovo YOGA 520-14IKB
serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40700 WIN serial: <filter>
UEFI: LENOVO v: 4QCN51WW(V2.15) date: 11/19/2019
ID-1: BAT1 charge: 28.6 Wh condition: 33.1/35.0 Wh (95%) volts: 8.0/7.5
model: SIMPLO PABAS0241231 type: Li-ion serial: <filter>
status: Discharging
Topology: Dual Core model: Intel Pentium 4415U bits: 64 type: MT MCP
arch: Amber Lake family: 6 model-id: 8E (142) stepping: 9 microcode: C6
L2 cache: 2048 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 18406
Speed: 900 MHz min/max: 400/2300 MHz Core speeds (MHz): 1: 900 2: 900
3: 900 4: 900
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes,
SMT vulnerable
Type: srbds status: Vulnerable: No microcode
Device-1: Intel vendor: Lenovo driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:5906
Device-2: Realtek EasyCamera type: USB driver: uvcvideo bus ID: 1-5:2
chip ID: 0bda:58ea serial: <filter>
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: intel
unloaded: modesetting alternate: fbdev,vesa display ID: :0 screens: 1
s-diag: 582mm (22.9")
OpenGL: renderer: Mesa Intel HD Graphics 610 (KBL GT1)
v: 4.6 Mesa 20.1.5 direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus ID: 00:1f.3
chip ID: 8086:9d71
Sound Server: ALSA v: k5.7.15-1-MANJARO
Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Lenovo driver: ath10k_pci v: kernel port: 3040 bus ID: 02:00.0
chip ID: 168c:0042
Device-2: Qualcomm Atheros type: USB driver: btusb bus ID: 1-7:4
chip ID: 0cf3:e500
Local Storage: total: 119.24 GiB used: 19.92 GiB (16.7%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLW128HEGR-000L2
size: 119.24 GiB block size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 4L1QCXB7 scheme: GPT
ID-1: / raw size: 43.95 GiB size: 43.01 GiB (97.86%)
used: 19.27 GiB (44.8%) fs: ext4 dev: /dev/nvme0n1p5
System Temperatures: cpu: 38.5 C mobo: N/A
Processes: 197 Uptime: 23m Memory: 3.71 GiB used: 1.44 GiB (38.8%)
Init: systemd v: 245 Compilers: gcc: 10.1.0 Packages: pacman: 1073
lib: 291 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
Not sure if you needed it all so I just ran the critical stuff
[ 0.000000] [Firmware Bug]: TPM Final Events table missing or invalid
[ 0.108624] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[ 0.108624] #3
[ 0.110885] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.487862] [Firmware Bug]: No valid trip found
[ 0.487899] [Firmware Bug]: No valid trip found
[ 1.142073] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 2.262687] systemd-journald[218]: File /var/log/journal/e0be76a9dcc54418810a760202e77a09/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 2.848338] i2c_hid i2c-ELAN0650:01: supply vdd not found, using dummy regulator
[ 2.848358] i2c_hid i2c-ELAN0650:01: supply vddl not found, using dummy regulator
[ 2.891824] i2c_hid i2c-WCOM50DE:00: supply vdd not found, using dummy regulator
[ 2.891845] i2c_hid i2c-WCOM50DE:00: supply vddl not found, using dummy regulator
[ 2.965422] i2c_hid i2c-NPCE0388:00: supply vdd not found, using dummy regulator
[ 2.965438] i2c_hid i2c-NPCE0388:00: supply vddl not found, using dummy regulator
[ 4.066911] uvcvideo 1-5:1.0: Entity type for entity Extension 4 was not initialized!
[ 4.066914] uvcvideo 1-5:1.0: Entity type for entity Processing 2 was not initialized!
[ 4.066917] uvcvideo 1-5:1.0: Entity type for entity Camera 1 was not initialized!
[ 5.239373] kauditd_printk_skb: 20 callbacks suppressed
[ 6.552522] systemd-journald[218]: File /var/log/journal/e0be76a9dcc54418810a760202e77a09/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
[ 10.656349] kauditd_printk_skb: 10 callbacks suppressed
