I have a newly installed manjaro with this strange behaviour: when I put it in suspend mode and then I close the lid the computer exits from suspend mode. I can see this from the battery level and from the heat coming from the back side.
How I could debug this problem?
This is my inxi -Fxi
Host: pitone Kernel: 6.1.12-1-MANJARO arch: x86_64 bits: 64 compiler: gcc
v: 12.2.1 Desktop: GNOME v: 43.3 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Dell product: Latitude 5330 v: N/A
serial: <superuser required>
Mobo: Dell model: 007WCW v: A00 serial: <superuser required> UEFI: Dell
v: 1.9.0 date: 11/15/2022
ID-1: BAT0 charge: 36.6 Wh (63.1%) condition: 58.0/58.0 Wh (100.0%)
volts: 15.5 min: 15.2 model: SMP DELL Y86WG26 status: discharging
Info: 10-core (2-mt/8-st) model: 12th Gen Intel Core i7-1265U bits: 64
type: MST AMCP arch: Alder Lake rev: 4 cache: L1: 928 KiB L2: 6.5 MiB
L3: 12 MiB
Speed (MHz): avg: 2025 high: 2700 min/max: 400/4800:3600 cores: 1: 1334
2: 2700 3: 2200 4: 2200 5: 1182 6: 2700 7: 752 8: 2700 9: 2700 10: 434
11: 2700 12: 2700 bogomips: 64536
Device-1: Intel Alder Lake-UP3 GT2 [Iris Xe Graphics] vendor: Dell
driver: i915 v: kernel arch: Gen-12.2 bus-ID: 0000:00:02.0
Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 3-6:2
Display: wayland server: X.org v: 1.21.1.7 with: Xwayland v: 22.1.8
compositor: gnome-shell driver: gpu: i915 resolution: 1920x1080~60Hz
API: OpenGL v: 4.6 Mesa 22.3.5 renderer: Mesa Intel Graphics (ADL GT2)
direct-render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 0000:00:1f.3
Sound API: ALSA v: k6.1.12-1-MANJARO running: yes
Sound Server-1: JACK v: 1.9.22 running: no
Sound Server-3: PipeWire v: 0.3.65 running: yes
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 0000:00:14.3
IF: wlp0s20f3 state: up mac: 8c:17:59:c8:2f:1c
IP v4: 172.20.52.73/26 type: dynamic noprefixroute scope: global
IP v6: fe80::bdf3:beed:363:dfd2/64 type: noprefixroute scope: link
IF-ID-1: wg0 state: unknown speed: N/A duplex: N/A mac: N/A
IF-ID-2: wwp0s20f0u1 state: down mac: 76:74:89:89:f5:6f
WAN IP: 81.123.181.13
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 3-10:38
Report: rfkill ID: hci0 rfk-id: 6 state: up address: see --recommends
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 bus-ID: 0000:00:0e.0
Local Storage: total: 238.47 GiB used: 31.92 GiB (13.4%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: PC SN740 NVMe WD 256GB
size: 238.47 GiB temp: 43.9 C
ID-1: / size: 93.1 GiB used: 30.98 GiB (33.3%) fs: ext4 dev: /dev/nvme0n1p8
ID-2: /boot/efi size: 511 MiB used: 316 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p6
ID-1: swap-1 type: partition size: 2 GiB used: 962.2 MiB (47.0%)
dev: /dev/nvme0n1p7
System Temperatures: cpu: 57.0 C mobo: N/A
Processes: 359 Uptime: 5d 19h 33m Memory: 15.32 GiB used: 9.55 GiB (62.4%)
Init: systemd Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 1438 Shell: Zsh
v: 5.9 inxi: 3.3.25
