I installed texlive-basic from pacman in order to compile .tex latex files into pdf using pdflatex. Here is the output from the command pdflatex first.tex
This is pdfTeX, Version 3.141592653-2.6-1.40.27 (TeX Live 2026/dev/Arch Linux) (preloaded format=pdflatex)
restricted \write18 enabled.
kpathsea: Running mktexfmt pdflatex.fmt
mktexfmt: mktexfmt is using the following fmtutil.cnf files (in precedence order):
mktexfmt: /etc/texmf/web2c/fmtutil.cnf
mktexfmt: mktexfmt is using the following fmtutil.cnf file for writing changes:
mktexfmt: /home/ishaang/.texlive/texmf-config/web2c/fmtutil.cnf
mktexfmt [INFO]: writing formats under /home/ishaang/.texlive/texmf-var/web2c
mktexfmt [INFO]: Did not find entry for byfmt=pdflatex skipped
mktexfmt [INFO]: not selected formats: 8
mktexfmt [INFO]: total formats: 8
mktexfmt [INFO]: exiting with status 0
I can't find the format file `pdflatex.fmt'!
It cannot find pdflatex.fmt, and neither can I, anywhere on my computer. I have tried running both fmtutil-user --all and fmtutil-sys --all with no success. (although there was a little popup about switching to user only format files when I used fmtutil-user for the first time, which might be related to the issue)
The output form kpsewhich pdflatex.fmt is blank.
This seems to be like a path issue. I also tried reinstalling but to no success.
There is also a billion other people having the same issue online and none of their solutions seems to work for me. Pls help
I have almost all texlive packages installed and I have no issues. Searching the file I found what is in the image. Try intalling that package to see if that solves your problem.
