Latest update caused several issues
HI after the latest update i am getting all sorts of issues
Kaffeine runs for a while then seg faults out
[000079cb8002f540] main decoder error: buffer deadlock prevented
[000079cb6826bba0] vaapi_filters filter: yadif algorithm not available, falling back to x algorithm
[000079cb8002f540] avcodec decoder: Using Mesa Gallium driver 24.1.1-manjaro1.1 for HAWAII (radeonsi, , LLVM 17.0.6, DRM 2.50, 6.9.5-1-MANJARO) for hardware decoding
Segmentation fault (core dumped)
Firefox i can no longer full screen it just crashes out with the report screen showing
on YouTube it is even worse if you need more let me know
with the SpaceX ITF5 up coming i need this system working faultlessly it has been great prior to the last update i am a former Arch user
Run it from a terminal and post the error logs.
Same as above. Run firefox in a terminal and post the error logs.
Some users claim YouTube has been intentionally doing this with Firefox. Could be due to detecting an ad blocker.
We’ll need more information about your system to help you. inxi -Fazy is a good start.
Huh? Not for me.
Hi Yoel Thanks for replying i will get that sorted and post them out for a couple of days now soon as i get back i will sort it.
Hi Re the Firefox crash this is the report i get from the firefox crash reporter
on trying to go full screen
AdapterDeviceID: 0x67b0
AdapterDriverVendor: mesa/radeonsi
AdapterDriverVersion: 24.1.1.0
AdapterVendorID: 0x1002
Add-ons: %7Bd10d0bf8-f5b5-c8b4-a8b2-2b9879e08c5d%7D:4.3,langpack-en-GB%40firefox.mozilla.org:127.0.2
AvailablePageFile: 0
AvailablePhysicalMemory: 945606656
AvailableSwapMemory: 0
AvailableVirtualMemory: 4549390336
BackgroundTaskMode: 0
BuildID: 20240618215959
ContentSandboxCapabilities: 119
ContentSandboxCapable: 1
ContentSandboxLevel: 4
CrashTime: 1720535542
DOMFissionEnabled: 1
DOMIPCEnabled: 1
DesktopEnvironment: kde
EMCheckCompatibility: true
EventLoopNestingLevel: 1
GpuSandboxLevel: 0
GraphicsCriticalError: |[0]CP+[GFX1-]: Couldn’t sanitize GL_RENDERER “HAWAII (radeonsi, , LLVM 17.0.
GraphicsNumActiveRenderers: 2
GraphicsNumRenderers: 3
HeadlessMode: 0
InstallTime: 1719829275
IsWayland: 0
LastStartupWasCrash: 0
LinuxUnderMemoryPressure: 0
Notes: Manjaro LinuxFP(D00-L1000-W0000000-T01) WR? WR+ EGL? EGL- GL Context? GL Context+ WebGL? WebG
ProductID: {ec8030f7-c20a-464f-9b0e-13a3a9e97384}
ProductName: Firefox
RDDProcessStatus: Running
ReleaseChannel: release
SafeMode: 0
SecondsSinceLastCrash: 12180
StartupCacheValid: 1
StartupCrash: 0
StartupTime: 1720530964
SubmittedFrom: Client
TelemetryClientId: de19bf3c-ab7d-47b6-9451-a0e54059265c
TelemetryEnvironment: {“build”:{“applicationId”:”{ec8030f7-c20a-464f-9b0e-13a3a9e97384}","applicatio
TelemetryServerURL:
TelemetrySessionId: b9f07842-609a-4ba6-908e-b4b2365210cb
Throttleable: 1
TotalPageFile: 8291160064
TotalPhysicalMemory: 8291160064
URL:
UptimeTS: 4578.6326459
UtilityProcessStatus: Running
Vendor: Mozilla
Version: 127.0.1
useragent_locale: en-GB
This report also contains technical information about the state of the application when it crashed.
I now believe it is a youtube firefox issue if i run Chromium or Falkon it is perfect both of those browsers annoy me to bits
This is from starting firefox in a terminal
ATTENTION: default value of option mesa_glthread overridden by environment.
[GFX1-]: Couldn’t sanitize GL_RENDERER “HAWAII (radeonsi, , LLVM 17.0.6, DRM 2.50, 6.9.5-1-MANJARO)”
ExceptionHandler::GenerateDump cloned child ExceptionHandler::WaitForContinueSignal waiting for continue signal…
15519
ExceptionHandler::SendContinueSignalToChild sent continue signal to child
Exiting due to channel error.
It is impossible to suggest anything without more info.
inxi -Fazy | curl -F'file=@-' https://0x0.st
Then provide the url inside a code fence like this
[code]
https://0x0.st/
[/code]
Rare species - you are - Arch Linux users usually stay with Arch.
But as Arch Linux user, you know everything worth knowing about your system - right?
Could be a corrupted profile - start firefox with a new profile
firefox --ProfileManager
Those days a re .long gone i use to e very system savy i had huge hardware failure and needed up and running again PDQ Manjaro was a spot on fit i like Arch but at the moment the install is just humm nuff said
Right then
the info you asked for hope it helps
System: Kernel: 6.9.5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1 clocksource: tsc avail: hpet,acpi_pm parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64 root=UUID=db1a2dfe-954f-443a-91c1-4d1d09d652ef rw quiet splash udev.log_priority=3 Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.3.0 wm: kwin_x11 vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux Machine: Type: Desktop System: Gigabyte product: N/A v: N/A serial: <superuser required> Chassis: type: 3 serial: <superuser required> Mobo: Gigabyte model: 990FXA-UD3 serial: <superuser required> uuid: <superuser required> BIOS: American Megatrends v: F2 date: 07/15/2013 Battery: Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter> charge: 55% (should be ignored) rechargeable: yes status: discharging CPU: Info: model: AMD FX-8370E bits: 64 type: MCP arch: Piledriver level: v2 built: 2012-13 process: GF 32nm family: 0x15 (21) model-id: 2 stepping: 0 microcode: 0x6000852 Topology: cpus: 1x cores: 8 smt: <unsupported> cache: L1: 384 KiB desc: d-8x16 KiB; i-4x64 KiB L2: 8 MiB desc: 4x2 MiB L3: 8 MiB desc: 1x8 MiB Speed (MHz): avg: 1416 high: 1484 min/max: 1400/3300 boost: enabled scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1484 2: 1425 3: 1406 4: 1405 5: 1400 6: 1406 7: 1400 8: 1406 bogomips: 53059 Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm Vulnerabilities: Type: gather_data_sampling status: Not affected Type: itlb_multihit status: Not affected Type: l1tf status: Not affected Type: mds status: Not affected Type: meltdown status: Not affected Type: mmio_stale_data status: Not affected Type: reg_file_data_sampling status: Not affected Type: retbleed mitigation: untrained return thunk; SMT disabled Type: spec_rstack_overflow status: Not affected Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer sanitization Type: spectre_v2 mitigation: Retpolines; IBPB: conditional; STIBP: disabled; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected Type: srbds status: Not affected Type: tsx_async_abort status: Not affected Graphics: Device-1: AMD Hawaii XT / Grenada [Radeon R9 290X/390X] vendor: PC Partner / Sapphire driver: radeon v: kernel alternate: amdgpu arch: GCN-2 code: Sea Islands process: GF/TSMC 16-28nm built: 2013-17 pcie: gen: 2 speed: 5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: DP-1,HDMI-A-1 empty: DVI-D-1,DVI-D-2 bus-ID: 01:00.0 chip-ID: 1002:67b0 class-ID: 0300 temp: 53.0 C Device-2: Conexant Systems CX23880/1/2/3 PCI Video and Audio Decoder vendor: Hauppauge works Nova-T DVB-T Model 909 driver: cx8800 v: 1.0.0 bus-ID: 04:06.0 chip-ID: 14f1:8800 class-ID: 0400 Device-3: Generalplus 2K HD Camera driver: snd-usb-audio,uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-2:3 chip-ID: 1b3f:1167 class-ID: 0102 Device-4: Realtek RTL2838 DVB-T driver: N/A type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:3 chip-ID: 0bda:2838 class-ID: 0000 serial: <filter> Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0 compositor: kwin_x11 driver: X: loaded: radeon unloaded: modesetting alternate: fbdev,vesa dri: radeonsi gpu: radeon display-ID: :0 screens: 1 Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.00x11.22") s-diag: 1055mm (41.54") monitors: <missing: xrandr> Monitor-1: DP-1 model: BenQ GL2250H serial: <filter> built: 2017 res: 1920x1080 dpi: 102 gamma: 1.2 size: 477x268mm (18.78x10.55") diag: 547mm (21.5") ratio: 16:9 modes: max: 1920x1080 min: 720x400 Monitor-2: HDMI-A-1 model: BenQ GL2250H serial: <filter> built: 2017 res: 1920x1080 dpi: 102 gamma: 1.2 size: 477x268mm (18.78x10.55") diag: 547mm (21.5") ratio: 16:9 modes: max: 1920x1080 min: 720x400 API: EGL v: 1.5 hw: drv: amd radeonsi platforms: device: 0 drv: radeonsi device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11: drv: radeonsi inactive: wayland API: OpenGL v: 4.5 vendor: amd mesa v: 24.1.1-manjaro1.1 glx-v: 1.4 direct-render: yes renderer: HAWAII (radeonsi LLVM 17.0.6 DRM 2.50 6.9.5-1-MANJARO) device-ID: 1002:67b0 memory: 3.91 GiB unified: no API: Vulkan Message: No Vulkan data available. Audio: Device-1: AMD SBx00 Azalia vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 00:14.2 chip-ID: 1002:4383 class-ID: 0403 Device-2: AMD Hawaii HDMI Audio [Radeon R9 290/290X / 390/390X] vendor: PC Partner / Sapphire driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 1002:aac8 class-ID: 0403 Device-3: Conexant Systems CX23880/1/2/3 PCI Video and Audio Decoder vendor: Hauppauge works Nova-T DVB-T Model 909 driver: cx8800 v: 1.0.0 bus-ID: 04:06.0 chip-ID: 14f1:8800 class-ID: 0400 Device-4: Conexant Systems CX23880/1/2/3 PCI Video and Audio Decoder [MPEG Port] vendor: Hauppauge works Nova-T DVB-T Model 909 driver: cx88-mpeg driver manager alternate: cx8802 bus-ID: 04:06.2 chip-ID: 14f1:8802 class-ID: 0480 Device-5: Conexant Systems CX23880/1/2/3 PCI Video and Audio Decoder [IR Port] vendor: Hauppauge works Nova-T DVB-T Model 909 driver: N/A bus-ID: 04:06.4 chip-ID: 14f1:8804 class-ID: 0480 Device-6: Intel USB PnP Sound Device driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1:2 chip-ID: 8086:0808 class-ID: 0300 Device-7: Generalplus 2K HD Camera driver: snd-usb-audio,uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-2:3 chip-ID: 1b3f:1167 class-ID: 0102 API: ALSA v: k6.9.5-1-MANJARO status: kernel-api with: aoss type: oss-emulator tools: alsactl,alsamixer,amixer Server-1: JACK v: 1.9.22 status: off tools: N/A Server-2: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse status: active 2: wireplumber status: active 3: pipewire-alsa type: plugin tools: pactl,pw-cat,pw-cli,wpctl Network: Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet vendor: Gigabyte driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: b000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200 IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter> Info: services: NetworkManager Drives: Local Storage: total: 1.82 TiB used: 360.21 GiB (19.3%) SMART Message: Unable to run smartctl. Root privileges required. ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 2TB size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 3B6Q scheme: MBR Partition: ID-1: / raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 360.21 GiB (19.7%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 Swap: Alert: No swap data was found. Sensors: System Temperatures: cpu: 46.0 C mobo: 38.0 C gpu: radeon temp: 53.0 C Fan Speeds (rpm): cpu: 0 fan-1: 3770 fan-3: 0 fan-4: 0 fan-5: 0 Power: 12v: N/A 5v: N/A 3.3v: N/A vbat: 2.98 Info: Memory: total: 8 GiB available: 7.72 GiB used: 2.81 GiB (36.4%) Processes: 254 Power: uptime: 14m states: freeze,mem,disk suspend: deep avail: s2idle wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 3.07 GiB services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical tool: systemctl Packages: pm: pacman pkgs: 1568 libs: 396 tools: pamac pm: flatpak pkgs: 0 Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: Bash v: 5.2.26 running-in: xterm inxi: 3.3.35
No one can read that.
Can you?
this looks much better and much more like what you saw, no? :grinning:
`System:
    udev.log_priority=3
    class-ID: 0102
    class-ID: 0480
    class-ID: 0102
    tool: systemctl
    inxi: 3.3.35`
You have 8 GB of RAM and no Swap.
This may not be the cause of a problem here - but it is bound to become one rather sooner than later.
Create a swap file.
Swap file created and on see what difference it makes thanks for your help by the way
(Note: I can’t post direct links here. Please search for the mentioned resources.)
Since the last update (2024-07-01), I also experienced Firefox crashes when visiting WebGL-dependent pages like Google Maps. The issue was related to the old radeon driver. I solved it by switching to amdgpu, as described in the AMDGPU Arch Wiki page.
Plz mark you code
like this. with the </> button.
the info that was shown was to use [ /] to mark code
any how Kaffeine has major memory issues when running digital TV it consumes memory like it is a bottomles pit
Hi folks Still getting this kaffeine segfaulting
started from a terminal i get this
< kaffeine
16-07-24 15:29:44.311 [Warning ] QCommandLineParser: already having an option named “h”
16-07-24 15:29:44.311 [Warning ] QCommandLineParser: already having an option named “help-all”
16-07-24 15:29:44.311 [Warning ] QCommandLineParser: already having an option named “v”
16-07-24 15:29:44.743 [Info ] kaffeine.dvb: Using built-in dvb device manager
16-07-24 15:29:45.048 [Info ] kaffeine.dev: Found dvb device P14f1880200709002: Conexant CX22702 DVB-T
16-07-24 15:29:45.191 [Warning ] kf.service.services: KServiceTypeTrader: serviceType “ThumbCreator” not found
16-07-24 15:29:45.192 [Warning ] kf.service.services: KServiceTypeTrader: serviceType “ThumbCreator” not found
16-07-24 15:29:45.507 [Warning ] kf.service.services: KServiceTypeTrader: serviceType “ThumbCreator” not found
[00007f274002f9f0] main decoder error: buffer deadlock prevented
[00007f274002f9f0] avcodec decoder: Using Mesa Gallium driver 24.1.3-manjaro1.1 for HAWAII (radeonsi, , LLVM 18.1.8, DRM 2.50, 6.6.39-1-MANJARO) for hardware decoding
VLC was updated today i had thought that may have been the issue
I am at a loss right now
Any more hints ideas
Thanks all .
