Always starts with the second try, after a forced Power OFF and ON again. Old RT-Kernels didn’t boot at all. This is really mint blowing.
Welcome to Manjaro!
- Please read the information behind this link. It will help you to post necessary information.
- Please press the three dots … below your post and then press the
- If you give us information about your system, we can see what we’re talking about and make better suggestions.
- You can do this by using
inxiin a terminal or in console.
- Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
- Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
- Copy the output from inxi (including the command) and paste it into your post.
- To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
Have you already
for your problem in the forum ? (Wisdom lies in asking → listening → reading
Kernel: 6.3.3-3-rt15-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.3-rt-x86_64
root=UUID=ced79fb3-4485-450f-8dd8-8624a64c9365 rw quiet splash apparmor=1
security=apparmor udev.log_priority=3 amdgpu.ppfeaturemask=0xffffffff
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASRock model: B450 Gaming-ITX/ac serial:
UEFI: American Megatrends v: P5.20 date: 11/01/2022
System RAM: total: 32 GiB available: 31.21 GiB used: 1.92 GiB (6.2%)
Array-1: capacity: 128 GiB slots: 2 modules: 2 EC: None
max-module-size: 64 GiB note: est.
Device-1: DIMM 0 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 16 GiB speed: 3600 MT/s volts: curr: 1.2 min: 1.2 max: 1.2
width (bits): data: 64 total: 64 manufacturer: TeamGroup part-no: UD4-3600
serial:
Device-2: DIMM 0 type: DDR4 detail: synchronous unbuffered (unregistered)
serial:
Info: model: AMD Ryzen 5 5500 socket: AM4 bits: 64 type: MT MCP arch: Zen 3
gen: 4 level: v3 note: check built: 2021-22 process: TSMC n7 (7nm)
family: 0x19 (25) model-id: 0x50 (80) stepping: 0 microcode: 0xA50000D
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 16 MiB
desc: 1x16 MiB
Speed (MHz): avg: 3179 high: 4450 min/max: 1400/5276 boost: enabled
base/boost: 4450/4250 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.3 V ext-clock: 100 MHz cores: 1: 1400 2: 1400 3: 1400 4: 4450
5: 4450 6: 4450 7: 4450 8: 4450 9: 4450 10: 1400 11: 4450 12: 1400
bogomips: 106799
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Sapphire driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
process: GF 14nm built: 2016-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports:
active: DP-1 empty: DVI-D-1,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 1002:67df
class-ID: 0300 temp: 42.0 C
Display: x11 server: X.Org v: 21.1.8 compositors: 1: xfwm v: 4.18.0
2: Picom v: git-b700a driver: X: loaded: amdgpu dri: radeonsi gpu: amdgpu
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.65x15.00")
s-diag: 777mm (30.58")
Monitor-1: DP-1 mapped: DisplayPort-0 model: Dell S2719DGF serial:
built: 2019 res: 2560x1440 dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.23")
diag: 685mm (27") ratio: 16:9 modes: max: 2560x1440 min: 720x400
API: OpenGL v: 4.6 Mesa 23.1.4 renderer: AMD Radeon RX 570 Series
(polaris10 LLVM 15.0.7 DRM 3.52 6.3.3-3-rt15-MANJARO) direct-render: Yes
Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Sapphire driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Device-2: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 0b:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-3: AMD Family 17h/19h HD Audio vendor: ASRock driver: snd_hda_intel
speed: 16 GT/s bus-ID: 0b:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.3.3-3-rt15-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 0.3.76 status: n/a (root, process) tools: pw-cli
Server-4: PulseAudio v: 16.1 status: active (root, process)
with: pulseaudio-alsa type: plugin tools: pacat,pactl,pavucontrol
Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 08:00.0
chip-ID: 8086:24fb class-ID: 0280
IF: wlp8s0 state: down mac:
Device-2: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 09:00.0
IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac:
IP v4: type: dynamic noprefixroute scope: global
broadcast:
IP v6: type: noprefixroute scope: link
WAN IP:
Device-1: Intel Wireless-AC 3168 Bluetooth driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:2 chip-ID: 8087:0aa7
class-ID: e001
Local Storage: total: 931.51 GiB used: 147.04 GiB (15.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: LEGEND 800
lanes: 4 tech: SSD serial: fw-rev: V1122B0 temp: 37.9 C
scheme: GPT
ID-1: / raw-size: 465.41 GiB size: 457.03 GiB (98.20%)
used: 147.01 GiB (32.2%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p5
maj-min: 259:5 label: N/A uuid: ced79fb3-4485-450f-8dd8-8624a64c9365
used: 29.1 MiB (30.3%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: N/A uuid: A29C-F41B
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: N/A label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 465.41 GiB fs: ntfs label: N/A
uuid: C0DA9DACDA9D9EEA
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 597 MiB fs: ntfs label: N/A
uuid: E6A894EEA894BE8D
Device-1: 1-6:2 info: Intel Wireless-AC 3168 Bluetooth type: bluetooth
mode: 1.1 power: 100mA chip-ID: 8087:0aa7 class-ID: e001
Device-2: 1-7:3 info: A4Tech USB Device type: keyboard,mouse,HID
driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 09da:f6eb class-ID: 0300
Device-3: 1-10:4 info: A4Tech USB Device type: keyboard,mouse,HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 09da:fa44 class-ID: 0300
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-6: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
System Temperatures: cpu: 46.2 C mobo: N/A gpu: amdgpu temp: 42.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 137
Processes: 419 Uptime: 2m wakeups: 0 Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1385 libs: 412 tools: pamac pm: flatpak pkgs: 0 Shell: Sudo (sudo)
v: 1.9.14p3 default: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.28
Any news?
linux63-rt is EOL … please update kernel to linux64-rt or lts kernel linux61-rt …
sudo mhwd-kernel -i linux64-rt
or
sudo mhwd-kernel -i linux61-rt
after reboot…remove linux63-rt with sudo mhwd-kernel -r linux63-rt
I wonder: why does it have to be a realtime kernel?
BIOS update is available - Beta 8.01 - 2023/4/18
should be checked as well
Already on RT-6.4 and it did it once per 5 boots, maybe fixed now. Also i remember from the old days that was a button during boot that exposed the boot sequence with letters instead of linux or asrcok logo, what was it?
The problem remains with RT.
I removed splash and quiet from kernel parameters in order to get visuals during boot and the problem magically solved. Something suspicious going on with the AMDGPU driver, the image stucks.
