Hi!! after the latest Stable Update in May 3 my Musescore app no longer works. What I found is that it must be a mismatch with the QT version but that is as far as I can go with my knowledge…
Kernel: 6.18.26-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.18-x86_64
root=UUID=f6f97edf-b164-427d-8811-2162b12875eb rw rootflags=subvol=@
quiet splash resume=UUID=23e5f220-1a34-4115-bbb9-af7efb41d0be
udev.log_priority=3
Desktop: KDE Plasma v: 6.6.4 tk: Qt v: N/A info: frameworks v: 6.25.0
wm: kwin_wayland vt: 1 dm: N/A Distro: Manjaro base: Arch Linux
Type: Desktop System: Gigabyte product: A320M-S2H V2 v: N/A
serial: <superuser required>
Mobo: Gigabyte model: A320M-S2H V2-CF serial: <superuser required>
uuid: <superuser required> Firmware: UEFI vendor: American Megatrends LLC.
v: F57d date: 09/02/2024
System RAM: total: 16 GiB available: 13.57 GiB used: 4.2 GiB (31.0%)
Device-1: Channel-A DIMM 0 type: no module installed
(unregistered) size: 8 GiB speed: 2666 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Kingston
part-no: 9905702-120.A00G serial: <filter>
Device-3: Channel-B DIMM 0 type: no module installed
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: N/A
part-no: CB8GU2666.C8PT serial: <filter>
Info: model: AMD Ryzen 5 3400G with Radeon Vega Graphics bits: 64
type: MT MCP arch: Zen/Zen+ note: check gen: 1 level: v3 note: check
built: 2019 process: GF 12nm family: 0x17 (23) model-id: 0x18 (24)
stepping: 1 microcode: 0x8108109
Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB
desc: 4x512 KiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1400 min/max: 1400/3700 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1400 2: 1400 3: 1400
4: 1400 5: 1400 6: 1400 7: 1400 8: 1400 bogomips: 59202
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb lahf_lm lbrv
lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor
svm_lock syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif
vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Device-1: Advanced Micro Devices [AMD/ATI] Picasso/Raven 2 [Radeon Vega
Series / Radeon Mobile Series] vendor: Gigabyte driver: amdgpu v: kernel
arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3
speed: 8 GT/s lanes: 16 ports: active: HDMI-A-1 empty: DP-1,DVI-D-1
bus-ID: 09:00.0 chip-ID: 1002:15d8 class-ID: 0300 temp: 34.0 C
Device-2: Logitech BRIO Ultra HD Webcam
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo type: USB rev: 3.1
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-3:2 chip-ID: 046d:085e
class-ID: 0300 serial: <filter>
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: 0
Monitor-1: HDMI-A-1 model: Philips PHL 243V5 serial: <filter> built: 2020
res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 94 gamma: 1.2 chroma: red:
x: 0.643 y: 0.337 green: x: 0.310 y: 0.620 blue: x: 0.157 y: 0.059 white:
x: 0.314 y: 0.329 size: 521x293mm (20.51x11.54") diag: 598mm (23.5")
ratio: 16:9 modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x720,
1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 26.0.6-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 11 Graphics
(radeonsi raven ACO DRM 3.64 6.18.26-1-MANJARO) device-ID: 1002:15d8
memory: 1.95 GiB unified: yes display-ID: :0.0
API: Vulkan v: 1.4.341 layers: 2 device: 0 type: integrated-gpu name: AMD
Radeon Vega 11 Graphics (RADV RAVEN) driver: mesa radv v: 26.0.6-arch1.1
device-ID: 1002:15d8 surfaces: N/A
Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP
Audio driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 09:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: iCON iKey Board 4 V1.03 driver: snd-usb-audio type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:3 chip-ID: 1d03:0066
class-ID: 0103 serial: <filter>
Device-3: M-Audio M-Track Plus driver: snd-usb-audio type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:2 chip-ID: 0763:4009
class-ID: fe01
Device-4: Logitech BRIO Ultra HD Webcam
API: ALSA v: k6.18.26-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.6.4 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
lanes: 1 port: f000 bus-ID: 08:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp8s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 2.24 TiB used: 388.8 GiB (17.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD Green 2.5 480GB size: 447.13 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 8100
scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD5000AAKS-00V1A0 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s tech: N/A serial: <filter> fw-rev: 1D05
scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD10EZEX-21WN4A0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
fw-rev: 1A01 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 vendor: Western Digital
model: WDS480G3G0A-00BJG0 size: 447.13 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 09BA
scheme: GPT
ID-1: / raw-size: 438.04 GiB size: 438.04 GiB (100.00%)
used: 46.85 GiB (10.7%) fs: btrfs dev: /dev/sdd2 maj-min: 8:50 label: N/A
uuid: f6f97edf-b164-427d-8811-2162b12875eb
used: 664 KiB (0.2%) fs: vfat dev: /dev/sdd1 maj-min: 8:49 label: N/A
uuid: 03B3-1CB3
ID-3: /home raw-size: 438.04 GiB size: 438.04 GiB (100.00%)
ID-4: /run/media/pato/Archivos raw-size: 465.76 GiB
size: 465.65 GiB (99.98%) used: 341.95 GiB (73.4%) fs: vfat dev: /dev/sdb1
maj-min: 8:17 label: Archivos uuid: 7157-7655
ID-5: /var/cache raw-size: 438.04 GiB size: 438.04 GiB (100.00%)
ID-6: /var/log raw-size: 438.04 GiB size: 438.04 GiB (100.00%)
dev: /dev/sdd3 maj-min: 8:51 label: swap
uuid: 23e5f220-1a34-4115-bbb9-af7efb41d0be
ID-1: /dev/sda1 maj-min: 8:1 size: 498 MiB fs: vfat label: N/A
uuid: 9772-EA31
ID-2: /dev/sda2 maj-min: 8:2 size: 4 GiB fs: vfat label: N/A
uuid: 9772-EAC4
ID-3: /dev/sda3 maj-min: 8:3 size: 438.64 GiB fs: ext4 label: N/A
uuid: be09253b-6de3-4d84-b863-9e266b8cf99e
ID-4: /dev/sda4 maj-min: 8:4 size: 4 GiB fs: swap label: N/A
uuid: 9251383f-3f1e-4092-ba13-ffe56bd7dbc3
ID-5: /dev/sdc1 maj-min: 8:33 size: 931.51 GiB fs: vfat label: Proyectos
uuid: E600-D7A6
Device-1: 1-5:2 info: Logitech Mouse type: mouse
chip-ID: 046d:c077 class-ID: 0301
Device-2: 1-6:3 info: iCON iKey Board 4 V1.03 type: audio
driver: snd-usb-audio interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 1d03:0066 class-ID: 0103
serial: <filter>
Device-1: 3-2:2 info: M-Audio M-Track Plus type: audio
driver: snd-usb-audio interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 0763:4009 class-ID: fe01
Device-1: 4-3:2 info: Logitech BRIO Ultra HD Webcam type: video,audio,HID
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo interfaces: 6 rev: 3.1
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 896mA
chip-ID: 046d:085e class-ID: 0300 serial: <filter>
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-6: 6-0:1 info: super-speed hub ports: 1 rev: 3.1
System Temperatures: cpu: 33.4 C mobo: 19.0 C gpu: amdgpu temp: 33.0 C
Fan Speeds (rpm): N/A
Packages: 1553 pm: pacman pkgs: 1541 libs: 396 tools: pamac pm: flatpak
pkgs: 12
1: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
2: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
3: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
4: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
5: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
6: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
7: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
8: https://mirror.fcix.net/manjaro/stable/$repo/$arch
9: https://mirror.23m.com/manjaro/stable/$repo/$arch
10: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch
11: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
12: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
13: https://mirror.init7.net/manjaro/stable/$repo/$arch
14: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
15: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
16: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
17: https://manjaro.mirrors.uk2.net/stable/$repo/$arch
18: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
19: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
20: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
21: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
22: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
23: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
24: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
25: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
26: https://mirror.dimensiondata.com/mirrors/manjaro.org/stable/$repo/$arch
27: https://mirror.xeonbd.com/manjaro/stable/$repo/$arch
28: https://muug.ca/mirror/manjaro/stable/$repo/$arch
29: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
30: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
31: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
32: https://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
33: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
34: https://manjaro.ynh.ovh/stable/$repo/$arch
35: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
36: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
37: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
38: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
39: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
40: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
41: https://mirrors.manjaro.org/repo/stable/$repo/$arch
42: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
43: https://mirrors2.manjaro.org/stable/$repo/$arch
44: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
45: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
46: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
47: https://mirror.easyname.at/manjaro/stable/$repo/$arch
48: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 376
1: cpu: 100% command: ps pid: 13967 mem: 4.12 MiB (0.0%)
2: cpu: 22.1% command: firefox pid: 1633 mem: 123.0 MiB (0.8%)
3: cpu: 11.9% command: firefox pid: 1393 mem: 777.7 MiB (5.5%)
4: cpu: 6.8% command: kwin_wayland pid: 662 mem: 329.8 MiB (2.3%)
5: cpu: 5.9% command: firefox pid: 12716 mem: 333.0 MiB (2.3%)
Memory top: 5 of 376
1: mem: 777.7 MiB (5.5%) command: firefox pid: 1393 cpu: 11.9%
2: mem: 684.6 MiB (4.9%) command: firefox pid: 5022 cpu: 3.6%
3: mem: 635.3 MiB (4.5%) command: firefox pid: 1895 cpu: 3.7%
4: mem: 582.4 MiB (4.1%) command: firefox pid: 1938 cpu: 0.5%
5: mem: 502.0 MiB (3.6%) command: firefox pid: 1993 cpu: 0.7%
Processes: 376 Power: uptime: 1h 39m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 5.36 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 260 default: graphical
tool: systemctl
Compilers: gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.40
Running MuseScore from Terminal gives me…
qt.qml.typeregistration: Invalid QML element name "IconCode"; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name "MusicalSymbolCodes"; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name "ContainerType"; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name "NavigationEvent"; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name "MUAccessible"; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name "CompareType"; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name "SelectionMode"; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name "ToolBarItemType"; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name "PopupPosition"; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name "DockToolBarAlignment"; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name "Location"; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name "CloudVisibility"; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name "SaveToCloudResponse"; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name "DirectionTypes"; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name "SlurTieTypes"; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name "NoteHead"; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name "Beam"; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name "Hairpin"; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name "OrnamentTypes"; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name "Dynamic"; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name "Glissando"; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name "CommonTypes"; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name "BarlineTypes"; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name "MarkerTypes"; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name "KeySignatureTypes"; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name "AccidentalTypes"; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name "FretDiagramTypes"; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name "LineTypes"; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name "TextTypes"; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name "ArticulationTypes"; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name "AmbitusTypes"; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name "ChordSymbolTypes"; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name "BendTypes"; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name "TremoloBarTypes"; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name "TremoloTypes"; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name "VoiceTypes"; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name "LayoutPanelItemType"; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name "ShadowNotePopupContent"; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name "PanelMode"; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name "StandardButton"; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name "SaveLocationType"; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name "GenerateAudioTimePeriodType"; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name "MigrationType"; value type names should begin with a lowercase letter
10:08:53.415 | INFO | main_thread | GlobalModule::onPreInit | log path: /home/pato/.local/share/MuseScore/MuseScore4/logs/MuseScore_260504_100853.log
10:08:53.415 | INFO | main_thread | GlobalModule::onPreInit | === Started MuseScore Studio 4.6.5, build: ===
10:08:53.426 | INFO | main_thread | LanguagesService::effectiveLanguageCode | System languages: QVariant(QStringList, QList("es-Latn-AR", "es-AR", "es-Latn", "es"))
10:08:53.427 | INFO | main_thread | MultiInstancesProvider::init | our instance id is: 6de6aeaf08ca401f847268ba8b028ad8
10:08:53.427 | INFO | main_thread | IpcChannel::setupConnection | starting ipc server
10:08:53.427 | INFO | main_thread | IpcSocket::connect | success connected to ipc server
10:08:53.427 | INFO | 140514686924480 | IpcServer::listen | ipc server: client with id "6de6aeaf08ca401f847268ba8b028ad8" has connected
10:08:53.441 | WARN | main_thread | DiagnosticsModule::onInit | crash handling disabled
10:08:53.441 | INFO | main_thread | audio::IAudioDriver> makeLinuxAudioDriver | Using audio driver: ALSA
10:08:53.462 | INFO | main_thread | AlsaAudioDriver::open | Connected to default with bufferSize 1024, sampleRate 44100, channels: 2
10:08:53.462 | INFO | main_thread | MuseSamplerResolver::init | MuseSampler library not found: /home/pato/.local/share/MuseSampler/lib/libMuseSamplerCoreLib.so
10:08:53.462 | INFO | 140514632500928 | AudioEngine::setAudioChannelsCount | Audio channels: 2
10:08:53.462 | INFO | 140514632500928 | AudioEngine::setSampleRate | Sample rate: 44100
10:08:53.462 | INFO | 140514632500928 | AudioEngine::setReadBufferSize | Read buffer size: 1024
10:08:53.462 | WARN | main_thread | Qt | QIODevice::read (QFile, "/home/pato/.local/share/MuseScore/MuseScore4/midi_mappings.xml"): device not open
10:08:53.468 | INFO | main_thread | AbstractCloudService::readTokens | Could not find the tokens file: /home/pato/.local/share/MuseScore/MuseScore4/musescorecom_cred.dat
10:08:53.468 | INFO | main_thread | AbstractCloudService::readTokens | Could not find the tokens file: /home/pato/.local/share/MuseScore/MuseScore4/audiocom_cred.dat
10:08:53.751 | ERROR | main_thread | ExtensionsConfiguration::manifestConfigs | failed read config data, err: [406] Ocurrió un error cuando leía desde el archivo, file: /home/pato/.local/share/MuseScore/MuseScore4/plugins/plugins.json
10:08:53.752 | WARN | main_thread | Qt | QIODevice::read (QFile, "/home/pato/.local/share/MuseScore/MuseScore4/shortcuts.xml"): device not open
10:08:53.802 | INFO | main_thread | GuiApp::perform | Using graphics api: "opengl"
10:08:53.802 | INFO | main_thread | GuiApp::perform | Gui platform: "xcb"
10:08:53.802 | INFO | main_thread | GuiApp::perform | Detecting problems with graphics api
10:08:54.090 | WARN | 140513977149120 | Qt | Member implicitWidth of the object QQuickItem_QML_426 overrides a member of the base object. Consider renaming it or adding final or override specifier
10:08:54.141 | WARN | 140513977149120 | Qt | Member enabled of the object QQuickPinchArea overrides a member of the base object. Consider renaming it or adding final or override specifier
10:08:54.232 | WARN | main_thread | Qt | QQmlApplicationEngine failed to load component
10:08:54.232 | ERROR | main_thread | GuiApp::perform | error: qrc:/qml/platform/linux/Main.qml:57:5: Type WindowContent unavailable
10:08:54.232 | ERROR | main_thread | GuiApp::perform | error: qrc:/qml/WindowContent.qml:101:9: Type NotationPage unavailable
10:08:54.232 | ERROR | main_thread | GuiApp::perform | error: qrc:/qml/NotationPage/NotationPage.qml:296:13: Type LayoutPanel unavailable
10:08:54.232 | ERROR | main_thread | GuiApp::perform | error: qrc:/qml/MuseScore/InstrumentsScene/LayoutPanel.qml:208:13: Invalid property assignment: "__currentRowItem" is a read-only property
10:08:54.232 | WARN | main_thread | Qt | qrc:/qml/platform/linux/Main.qml:57:5: Type WindowContent unavailable
10:08:54.232 | WARN | main_thread | Qt | qrc:/qml/WindowContent.qml:101:9: Type NotationPage unavailable
10:08:54.232 | WARN | main_thread | Qt | qrc:/qml/NotationPage/NotationPage.qml:296:13: Type LayoutPanel unavailable
10:08:54.232 | WARN | main_thread | Qt | qrc:/qml/MuseScore/InstrumentsScene/LayoutPanel.qml:208:13: Invalid property assignment: "__currentRowItem" is a read-only property
10:08:54.232 | WARN | main_thread | Qt | QObject::connect(QQuickWindow, QApplication): invalid nullptr parameter
10:08:54.232 | INFO | main_thread | AudioOutputDeviceController::init | Available output devices changed, checking connection...
10:08:54.233 | ERROR | main_thread | GuiApp::perform | failed Qml load
10:08:54.242 | INFO | main_thread | Profiler |
Main thread. Top 150 by sum time (total count: 32)
Function Call time Call count Sum time
FretDiagram::readHarmonyToDiagramFile 54.739 ms 1 54.739 ms
InstrumentsRepository::load 22.006 ms 1 22.006 ms
XmlStreamReader::setData 0.008 ms 1251 9.415 ms
SoundFontController::loadSoundFonts 2.914 ms 1 2.914 ms
ExtPluginsLoader::loadManifestList 1.513 ms 1 1.513 ms
ShortcutsRegister::reload 1.179 ms 1 1.179 ms
ShortcutsRegister::readFromFile 0.494 ms 2 0.988 ms
LanguagesService::init 0.661 ms 1 0.661 ms
LanguagesService::setCurrentLanguage 0.485 ms 1 0.485 ms
SymNames::loadNameToSymIdHash 0.465 ms 1 0.465 ms
ExtensionsLoader::loadManifestList 0.463 ms 1 0.463 ms
InstrumentsRepository::loadStringTuningsPresets 0.387 ms 1 0.387 ms
NotationActionController::init 0.296 ms 1 0.296 ms
AbstractCloudService::init 0.133 ms 2 0.266 ms
UiActionsRegister::updateShortcutsAll 0.258 ms 1 0.258 ms
AbstractCloudService::readTokens 0.073 ms 2 0.146 ms
LanguagesService::loadLanguages 0.134 ms 1 0.134 ms
ShortcutsRegister::makeUnique 0.134 ms 1 0.134 ms
UiActionsRegister::updateCheckedAll 0.105 ms 1 0.105 ms
RegisterAudioPluginsScenario::init 0.029 ms 1 0.029 ms
KnownAudioPluginsRegister::load 0.025 ms 1 0.025 ms
ShortcutsRegister::expandStandardKeys 0.011 ms 2 0.022 ms
UiActionsRegister::updateEnabledAll 0.022 ms 1 0.022 ms
UiActionsRegister::updateEnabled 0.008 ms 1 0.008 ms
UiContextResolver::currentUiContext 0.003 ms 2 0.005 ms
Workspace::rawData 0.001 ms 4 0.003 ms
InstrumentsRepository::loadMuseInstruments 0.003 ms 1 0.003 ms
UiConfiguration::readThemes 0.002 ms 1 0.002 ms
SlurTieLayout::avoidCollisions 0.000 ms 6 0.001 ms
RecentFilesController::init 0.001 ms 1 0.001 ms
ProjectAutoSaver::update 0.001 ms 1 0.001 ms
UiActionsRegister::updateChecked 0.001 ms 1 0.001 ms
Other threads. Top 150 by sum time (total count: 2)
SynthResolver::resolveAvailableResources 0.558 ms 1 0.558 ms
MuseSoundsRepository::th_requestSounds 0.000 ms 0 0.000 ms
10:08:54.242 | INFO | main_thread | GuiApp::finish | activeThreadCount: 1
10:08:54.762 | INFO | 140514640893632 | {anonymous}::alsaThread | exit
10:08:54.814 | INFO | main_thread | main | Goodbye!! code: -1
Thanks in advance!
