Since the last two update of chromium when trying to bookmark a page if you then choose “edit” to bring up the dialog to select another folder the browser will hang (screen shudders like an infinite loop behavior and process must be killed)
Seems to not be chromium specific but the engine as those using google chrome/brave have been noticing the same although not with vivaldi. I updated, it started happening and then I noticed that just since yesterday there was another chromium update so was hoping that this issue was noticed and a fix was released. So I updated with that but the issue remains. From what I can tell it’s not just that dialog but related to the bookmark manager code in general.
Version 121.0.6167.184 (Official Build) Arch Linux (64-bit)
- https://www.reddit.com/r/linuxmint/comments/1aiuxta/chrome_brave_browser_freezes_when_saving_bookmarks/
- https://askubuntu.com/questions/1502874/google-chrome-edit-bookmark-dialog-hangs-the-browser-on-ubuntu-20-04
- Chromium
in the meantime how (using pamac or pacman) can I downgrade to 120.0.6099.216-1 (as was done at the link above).
