I just bought a mini PC to plug to my Large TV screen (something around 55")
I want to use Manjaro for that PC
Most Display Setting Resolution doesn’t work and the only one that is working, 3840 x 2160, make it difficult to read from a few feet away from the TV.
If I choose other resolution 1920 x something, it blink and comes back to the Display Setting Tools.
The PC is using some Intel Video Card
https://www.amazon.ca/dp/B0879KKTCB?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
I just tried Linux Mint and almost all Display Setting resolution choice where working well.
I guess if Mint can do it, there is may be a way for me to make it work with Manjaro ?
I am using KDE Plasma
Let’s start with the prerequisite system information, shall we?
I’m sure someone will help when they are able.
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Can you describe your setup and issue faced?
You have a monitor of what resolution?
And what connection did you use? HDMI? DP? Version?
What version is your display cable?
And what do you want to achieve?
I’ve been using KDE on large displays for years–a 43" LG on the desktop, a 75" Roku TV in the living room.
Try adjusting the zoom level, not the resolution.
In KDE, System Settings, Display Configuration (or right-click anywhare on the desktop, choose Display Configuration) then adjust the Zoom Level.
YMMV, of course, but I’m perfectly happy with 3840x2160 at 100% zoom on either display, but in some apps I adjust this to 120% to 130% zoom within the application.
HTH.
PS: The additional info Scotty requests is pretty standard. Unless someone has whatever unspecified mini PC you’re using, we don’t know what’s in it. inxi
tells us that.
Is itwhat you wanted ?
inxi -zv8
Kernel: 6.12.20-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=210058f7-6362-4e2d-ba1f-1ceb703021f5 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.3.3 tk: Qt v: N/A info: frameworks v: 6.12.0
Type: Mini-pc System: AZW product: MINI S v: N/A
serial: <superuser required>
Mobo: AZW model: MINI S serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: MINISF001
date: 02/18/2025
Device-1: hidpp_battery_0 model: Logitech Wireless Touch Keyboard K400 Plus
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
System RAM: total: 16 GiB available: 15.4 GiB used: 2.97 GiB (19.3%)
Array-1: capacity: 32 GiB slots: 1 modules: 1 EC: None
Device-1: Controller0-ChannelA-DIMM0 type: DDR4 detail: synchronous
size: 16 GiB speed: 3200 MT/s volts: note: check curr: 1 min: 1 max: 1
width (bits): data: 64 total: 64 manufacturer: N/A part-no: N/A
serial: <filter>
Info: model: Intel N100 bits: 64 type: MCP arch: Alder Lake level: v3
note: check built: 2021+ process: Intel 7 (10nm ESF) family: 6
model-id: 0xBE (190) stepping: 0 microcode: 0x1C
Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 smt: <unsupported> cache:
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 1x2 MiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 722 min/max: 700/3400 scaling: driver: intel_pstate
governor: powersave cores: 1: 722 2: 722 3: 722 4: 722 bogomips: 6452
bts cat_l2 cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid
f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt
ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx monitor movbe
movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid
rdrand rdseed rdt_a rdtscp rep_good sdbg sep serialize sha_ni smap smep
split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip
user_shstk vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: BHI_DIS_S
Device-1: Intel Alder Lake-N [UHD Graphics] driver: i915 v: kernel
alternate: xe arch: Xe process: Intel 10nm built: 2020-21 ports:
active: HDMI-A-2 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:46d1
class-ID: 0300
Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1015x571mm (39.96x22.48")
s-diag: 1165mm (45.85")
Monitor-1: HDMI-A-2 mapped: HDMI-2 model: LG (GoldStar) TV SSCR2
serial: <filter> built: 2021 res: mode: 3840x2160 hz: 60 scale: 100% (1)
dpi: 61 gamma: 1.2 chroma: red: x: 0.639 y: 0.329 green: x: 0.298 y: 0.600
blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
size: 1600x900mm (62.99x35.43") diag: 1836mm (72.3") ratio: 16:9
modes: 3840x2160, 4096x2160, 2560x1440, 1920x1080, 1280x1024, 1152x864,
1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
EDID-Warnings: 1: parse_edid: unhandled CEA mode 97 2: parse_edid:
unhandled CEA mode 96 3: parse_edid: unhandled CEA mode 118 4: parse_edid:
unhandled CEA mode 117 5: parse_edid: unhandled CEA mode 102 6: parse_edid:
unhandled CEA mode 101 7: parse_edid: unhandled CEA mode 91 8: parse_edid:
unhandled CEA mode 90 9: parse_edid: unhandled CEA mode 93 10: parse_edid:
unhandled CEA mode 94 11: parse_edid: unhandled CEA mode 95 12: parse_edid:
unhandled CEA mode 98 13: parse_edid: unhandled CEA mode 99 14: parse_edid:
unhandled CEA mode 100
device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.0.2-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL-N)
device-ID: 8086:46d1 memory: 7.52 GiB unified: yes
API: Vulkan v: 1.4.309 layers: N/A device: 0 type: integrated-gpu
name: Intel Graphics (ADL-N) driver: N/A device-ID: 8086:46d1
surfaces: xcb,xlib
x11: xdpyinfo, xprop, xrandr
Device-1: Intel Alder Lake-N PCH High Definition Audio driver: snd_hda_intel
v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:54c8 class-ID: 0403
API: ALSA v: k6.12.20-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
Device-1: Intel CNVi: Wi-Fi driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:54f0 class-ID: 0280
IF: wlo1 state: down mac: <filter>
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000
bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:3 chip-ID: 8087:0026
class-ID: e001
Local Storage: total: 476.94 GiB used: 12.35 GiB (2.6%)
ID-1: /dev/sda maj-min: 8:0 model: 512GB SSD size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 275 scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
used: 12.35 GiB (2.6%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 210058f7-6362-4e2d-ba1f-1ceb703021f5
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 0782-6C5A
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-2:2 info: Logitech Unifying Receiver type: keyboard,mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
chip-ID: 046d:c52b class-ID: 0300
Device-2: 3-10:3 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0026 class-ID: e001
System Temperatures: cpu: 40.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1218 libs: 352 tools: pamac pm: flatpak pkgs: 0
1: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
2: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
3: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
4: https://mirrors.xtom.de/manjaro/stable/$repo/$arch
5: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
6: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
7: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
8: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
9: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
10: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
11: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
12: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
13: https://manjaro.ynh.ovh/stable/$repo/$arch
14: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
15: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
16: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
17: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
18: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
19: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
20: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
21: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
22: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
23: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
24: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
25: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
26: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
27: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
28: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
29: https://linorg.usp.br/manjaro/stable/$repo/$arch
30: https://mirrors.xtom.ee/manjaro/stable/$repo/$arch
31: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
32: https://manjaro.kurdy.org/stable/$repo/$arch
33: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
34: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
35: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
36: http://mirror.terrahost.no/linux/manjaro/stable/$repo/$arch
37: https://mirrors.manjaro.org/repo/stable/$repo/$arch
38: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
39: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
40: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
41: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
42: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
43: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
44: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
45: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
46: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
47: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
48: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
49: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
50: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
51: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
52: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
53: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
54: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
55: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
56: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
57: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
58: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
59: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
60: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
61: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
62: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
63: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
64: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
65: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
66: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
67: https://mirror.albony.xyz/manjaro/stable/$repo/$arch
68: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
69: https://repos.silknet.com/manjaro/stable/$repo/$arch
70: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
71: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
72: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
73: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
74: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
75: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
76: https://mirrors2.manjaro.org/stable/$repo/$arch
77: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
78: http://manjaro.mirror.ac.za/stable/$repo/$arch
79: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
80: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
81: https://muug.ca/mirror/manjaro/stable/$repo/$arch
82: http://ftp.dei.uc.pt/pub/linux/manjaro/stable/$repo/$arch
83: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
84: http://mirror.fcix.net/manjaro/stable/$repo/$arch
85: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
86: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
87: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
88: https://mirror.easyname.at/manjaro/stable/$repo/$arch
89: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
90: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
91: https://mirror.23m.com/manjaro/stable/$repo/$arch
92: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
93: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
94: http://manjaro.grena.ge/stable/$repo/$arch
95: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
96: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
97: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
98: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
Mini-PC is connected with HDMI
Version ???
Tks !!!
If I change the resolution, it blink and doesn’t stick.
I want make everything bigger
I will try what @brucew suggested to see if it help (Try adjusting the zoom level, not the resolution.)
JF
yoda9898:
The inxi
output was only needed once .
Please read the following links; in particular those marked with to learn how to format code and command output as preformatted text.
I have corrected the mess you made this time, but in future you are expected do it yourself, and properly.
It might also be beneficial if you take extra time to read and understand instructions you are given, rather than blindly copy/pasting the commands.
Also, please avoid consecutive posts. Instead, edit your post if you have additional content to add.
Your three consecutive posts have been merged for you.
Required reading
Bruce, tks !!!
Zoom level is not perfect but it will help a lot and do the job for now.
It doesn’t zoom everything ( system tray at the bottom etc) but what is important is now readable…
Bear in mind too that TVs and computer monitors are optimized differently. TVs are optimized for smoothest-looking picture, monitors for sharpest, crispest edges. So while I can (and sometimes do) simultaneously put the same image, from the same video card on both my monitor and TV, the monitor is much better looking for text, windows and computery stuff, while the TV looks much better when playing movies.
200% agree…
It’s just that I was disappointed Linux Mint (Ubuntu) was able to deal with my large TV screen in a simple way…
All my PCs ( Wife, My laptop and Desktop) and my old TV-PC ( replacing it) were on Manjaro(for years) and I want to avoid the new member of the family (TV PC Mini-PC) not being part of the fun (Team Manjaro ) LOL
tks
NOte : I speak french, sorry if I make some weird sentences from time to time.
It’s okay. I’m a native English speaker and make weird sentences all the time. For fun, you should hear my Japanese!
LOL You choosed the perfect nickname/handle for that kind of comment LOL
Sound Of Thunder THOR would have been good too
I know you are right asking people to post the right way… No worries
It’s just that I post once or 2 times per year and sometime forget about Manjaro Forum Best practices
HDMI cables are the primary way to connect smart devices to a TV or home theater set-up. Computer monitors, laptops, HD TVs, and game consoles all use HDMI. HDMI cables can pass video, audio, and limited control signals like HDMI-CEC.
The HDMI specification on:
a. your display (TV)
b. your source (PC) and
c. the cable linking them (HDMI cable),
must ALL have matching:
resolution
refresh rate
Otherwise, either the display will go blank, or it will say “no signal detected”.
The same is true for DisplayPort (DP) port / cable.
Tks @anon39617291
Bu why is Linux Mint able to do it without problem ?
I know I am not helping with this reply but my point is :
If Mint is handling it properly, it some kind of show my display, source pc ( already above in the thread ) and my TV ( Spec above in the thread) and cable are not the problems,
I will google or GROK to learn about HDMI Cable refresh rate, wow…
Sometime we don’t know that we don’t know… And WYKYK
tks for the link about HDMI cables !!!
I must admit that it’s not because MINT does it well that my cables are good…
brucew:
zoom level
Bruce : zoom level FIXED everything ( workaround)
I just discovered I needed to log out and back in for the system Tray Panel (bottom bar) to also being zoomed !!!
I’m good with your solution if fixes everything
No, no, I’m no deity. Just look at my avatar and you’ll see; thunder is rather quiet in space. And because I just finished watching the original Alien movie (again), I can also remind you…
In space, nobody can hear you scream.
Easy to forget, I suppose, but that’s why we remind you.
Good luck with your TV.
system
Closed
5 April 2025 17:13
19
