Long story short, I am in the process of building a new primary system and setting up my existing one as a 24/7 media server. I have two 8TB drives, one is NTFS and the other is ext4. I am transferring files from the NTFS drive to the ext4 drive with the intention of formatting the NTFS drive to ext4 when it completes. I am transferring a lot of data, about 3.3TB of media files. Every 10 mins or so while the file copy is going, it keeps asking for authentication to transfer files. Is there some reason for this? It’s fluctuating between 7-20 hours for the transfer and I’d love to just leave it and let it do its thing, but I can’t because it keeps asking me to authenticate. Shouldn’t I only need to authenticate once unless I’m initiating a new transfer?
Here is the stat output for the ext4 drive I’m transferring to:
Blockquote~ >>> stat /disks/Plex1
File: /disks/Plex1
Size: 4096 Blocks: 8 IO Block: 4096 directory
Device: 801h/2049d Inode: 2 Links: 4
Access: (0777/drwxrwxrwx) Uid: ( 1000/knishofdeath) Gid: ( 1001/knishofdeath)
Access: 2020-10-30 12:51:43.301893362 -0700
Modify: 2020-10-29 21:12:34.050005048 -0700
Change: 2020-10-30 12:51:23.668559926 -0700
Birth: 2020-10-29 21:09:36.000000000 -0700
and stat output for NTFS drive:
Blockquote~ >>>stat /run/media/knishofdeath/easystore
File: /run/media/knishofdeath/easystore
Device: 821h/2081d Inode: 5 Links: 1
Access: 2020-10-25 15:06:17.053616000 -0700
Modify: 2020-10-25 15:05:31.559150000 -0700
Change: 2020-10-25 15:05:31.559150000 -0700
Birth: -
