Laptop's powerbutton sometimes shutdown instead of suspend
Hi people, as the title says, sometimes I press the powerbutton on laptop and and immediately initiates shutdown. I have searched and I haven’t something similar. I have changed the chassis tag from hostnamectl to laptop and of course is set on system settings to suspend. The problem appears random.
Below I’ll attach a log from journactl with the replication of the problem
Jan 07 15:23:50 gogo-82ju kernel: wlp4s0: Limiting TX power to 30 (30 - 0) dBm as advertised by 84:3c:9>
Jan 07 18:15:53 gogo-82ju systemd-logind[1060]: Power key pressed short.
Jan 07 18:15:53 gogo-82ju systemd-logind[1060]: The system will power off now!
Jan 07 18:15:53 gogo-82ju systemd-logind[1060]: System is powering down.
Jan 07 18:15:53 gogo-82ju systemd[1]: Stopping Power Profiles daemon...
Jan 07 18:15:53 gogo-82ju systemd[1]: Stopping Daemon for power management...
Jan 07 18:15:53 gogo-82ju systemd[1]: power-profiles-daemon.service: Deactivated successfully.
Jan 07 18:15:53 gogo-82ju systemd[1]: Stopped Power Profiles daemon.
Jan 07 18:15:53 gogo-82ju systemd[1]: Requested transaction contradicts existing jobs: Transaction for >
Jan 07 18:15:53 gogo-82ju systemd[1]: sys-devices-pci0000:00-0000:00:01.1-0000:01:00.1-sound-card0-cont>
Jan 07 18:15:53 gogo-82ju systemd[1]: sys-devices-virtual-misc-rfkill.device: Failed to enqueue SYSTEMD>
Jan 07 18:15:53 gogo-82ju systemd[1]: sys-devices-pci0000:00-0000:00:08.1-0000:06:00.6-sound-card1-cont>
Jan 07 18:15:53 gogo-82ju systemd[1]: upower.service: Deactivated successfully.
Jan 07 18:15:53 gogo-82ju systemd[1]: Stopped Daemon for power management.
Jan 07 18:15:53 gogo-82ju systemd[1]: upower.service: Consumed 2.453s CPU time, 6.8M memory peak.
Jan 07 18:15:53 gogo-82ju systemd[3031]: Stopped target GNOME power management target.
Jan 07 18:15:54 gogo-82ju systemd[1]: Starting Show Plymouth Power Off Screen...
Jan 07 18:15:54 gogo-82ju systemd[1]: Started Show Plymouth Power Off Screen.
Jan 07 18:15:59 gogo-82ju systemd[1]: systemd-poweroff.service: Deactivated successfully.
Jan 07 18:15:59 gogo-82ju systemd[1]: Finished System Power Off.
Jan 07 18:15:59 gogo-82ju systemd[1]: Reached target System Power Off.
Some more details, please.
Also, provide your system information:
inxi -zv8
Note that any code or command output (such as inxi output) should be placed within a scrollable pre-formatted text enclosure according to forum guidelines.
See here for instructions: :point_down:
[MiniHowTo] Present code or command output
What is a Quark?
Ok thx and sorry for my ignorance :melting_face:
  Kernel: 6.12.63-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    clocksource: hpet avail: acpi_pm
    root=UUID=4d50f3c1-00da-4136-a341-fd5f286a5662 rw quiet splash apparmor=1
  Desktop: GNOME v: 49.2 tk: GTK v: 3.24.51 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 49.2 Distro: Manjaro
    base: Arch Linux
  Type: Laptop System: LENOVO product: 82JU v: Legion 5 15ACH6H
    serial: <superuser required> Chassis: type: 10 v: Legion 5 15ACH6H
  Mobo: LENOVO model: LNVNB161216 v: SDK0R32862 WIN
    serial: <superuser required> part-nu: LENOVO_MT_82JU_BU_idea_FM_Legion 5
    15ACH6H uuid: <superuser required> Firmware: UEFI vendor: LENOVO
    v: GKCN65WW date: 01/16/2024
  ID-1: BAT0 charge: 52.5 Wh (100%) condition: 52.5/60 Wh (87.6%) volts: 17.25
    min: 15.36 model: SMP L20M4PC0 type: Li-poly serial: <filter> charging:
    status: full cycles: 258
  System RAM: total: 16 GiB available: 15.47 GiB used: 4.28 GiB (27.7%)
    (unregistered) size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Hynix
    part-no: HMAA1GS6CJR6N-XN serial: <filter>
  Info: model: AMD Ryzen 7 5800H with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 3 gen: 3 level: v3 note: check built: 2021-22
    microcode: 0xA500012
    desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1514 min/max: 400/4463 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 1514 2: 1514 3: 1514
    4: 1514 5: 1514 6: 1514 7: 1514 8: 1514 9: 1514 10: 1514 11: 1514 12: 1514
    13: 1514 14: 1514 15: 1514 16: 1514 bogomips: 102248
    vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
    xtopology
    affected
  Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Lenovo
    driver: nvidia v: 590.48.01 alternate: nouveau,nvidia_drm
    non-free: 550-580.xx+ status: current (as of 2025-11; EOL~2026-12-xx)
    arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-2023 pcie:
    gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
    ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 01:00.0
    chip-ID: 10de:2560 class-ID: 0300
    compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
    gpu: nv_platform,nvidia,nvidia-nvswitch display-ID: 0
  Monitor-1: eDP-1 model: BOE Display 0x0998 built: 2020 res: 1920x1080
    dpi: 142 gamma: 1.2 chroma: red: x: 0.655 y: 0.329 green: x: 0.298 y: 0.608
    blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
    size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
    modes: 1920x1080
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia
    x11: drv: nvidia inactive: device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 25.3.2-arch1.1
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060 Laptop
    GPU/PCIe/SSE2 memory: 5.86 GiB display-ID: :0.0
  Info: Tools: api: eglinfo,glxinfo gpu: nvidia-settings,nvidia-smi
    x11: xprop,xrandr
  Device-1: NVIDIA GA106 High Definition Audio driver: snd_hda_intel v: kernel
    pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Audio Coprocessor vendor: Lenovo
    driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x,
    snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
    snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 3 speed: 8 GT/s lanes: 16
    bus-ID: 06:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio vendor: Lenovo
    bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.12.63-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
    vendor: Lenovo driver: rtw89_8852ae v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: 1000 bus-ID: 04:00.0 chip-ID: 10ec:8852 class-ID: 0280
  IF: wlp4s0 state: up mac: <filter>
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:2 chip-ID: 0bda:4852
  Report: rfkill ID: hci0 rfk-id: 4 state: down bt-service: enabled,running
  Local Storage: total: 1.49 TiB used: 168.5 GiB (11.0%)
    model: MZVLB512HBJQ-000L2 size: 476.94 GiB block-size: physical: 512 B
    fw-rev: 3L1QEXF7 temp: 23.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Samsung
    model: MZVLW128HEGR-000L2 size: 119.24 GiB block-size: physical: 512 B
    fw-rev: 4L1QCXB7 temp: 37.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM014-SSHD-8GB
    size: 931.51 GiB block-size: physical: 4096 B logical: 512 B type: USB
    rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 5400
    serial: <filter> scheme: GPT
  ID-1: / raw-size: 43.95 GiB size: 42.95 GiB (97.74%) used: 27.96 GiB (65.1%)
    fs: ext4 dev: /dev/nvme1n1p1 maj-min: 259:6 label: N/A
    uuid: 4d50f3c1-00da-4136-a341-fd5f286a5662
  ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
    used: 29 MiB (11.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: SYSTEM_DRV uuid: 32AF-B968
  ID-3: /home raw-size: 72.37 GiB size: 70.68 GiB (97.67%)
    used: 54.98 GiB (77.8%) fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:7
    label: N/A uuid: f93336ae-b6c9-4bde-9c6e-c899793b797d
  ID-4: /run/media/gogo/200E8AC10E8A8F88 raw-size: 889.9 GiB
    size: 889.9 GiB (100.00%) used: 85.05 GiB (9.6%) fs: ntfs dev: /dev/sda5
    maj-min: 8:5 label: N/A uuid: 200E8AC10E8A8F88
  ID-5: /run/media/gogo/LRS_ESP raw-size: 1000 MiB size: 996 MiB (99.60%)
    used: 496.8 MiB (49.9%) fs: vfat dev: /dev/sda3 maj-min: 8:3 label: LRS_ESP
    uuid: F836-8065
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 475.69 GiB fs: ntfs
    label: Windows-SSD uuid: E498B04598B017CE
  ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 1000 MiB fs: ntfs
    label: WINRE_DRV uuid: 3A5CB0EE5CB0A653
  ID-4: /dev/nvme1n1p3 maj-min: 259:8 size: 2.93 GiB fs: vfat
    label: NO_LABEL uuid: AEF6-0A82
  ID-5: /dev/sda1 maj-min: 8:1 size: 1000 MiB fs: ntfs label: WINRE_DRV
    uuid: EAF03294F03266CB
  ID-6: /dev/sda2 maj-min: 8:2 size: 260 MiB fs: vfat label: SYSTEM_DRV
    uuid: 8E35-8688
  ID-7: /dev/sda4 maj-min: 8:4 size: 128 MiB fs: <superuser required>
  ID-8: /dev/sda6 maj-min: 8:6 size: 450 MiB fs: ntfs label: N/A
    uuid: F4BAC1F1BAC1B082
  ID-9: /dev/sda7 maj-min: 8:7 size: 13.84 GiB fs: ntfs label: PBR_DRV
    uuid: FA4C3FC34C3F7A09
  Hub-2: 1-2:2 info: Genesys Logic Hub ports: 3 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 05e3:0610
  Device-1: 1-2.3:4 info: Razer USA DeathAdder V3 type: mouse,keyboard
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1532:00b2 class-ID: 0301
  Device-2: 1-4:3 info: Integrated Express ITE Device(8910) type: keyboard
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:c101 class-ID: 0301
  Hub-3: 2-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-4: 2-2:2 info: Genesys Logic GL3523 Hub ports: 3 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0620
  Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 3-4:2 info: Realtek Bluetooth Radio type: bluetooth
    driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 0bda:4852 class-ID: e001 serial: <filter>
  Hub-6: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  Device-1: 4-1:2 info: ASMedia ASM1051E SATA 6Gb/s bridge ASM1053E ASM1153
    3Gb/s ASM1153E bridge type: mass storage driver: uas interfaces: 1
    rev: 3.0 speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1
    chip-ID: 174c:55aa class-ID: 0806 serial: <filter>
  System Temperatures: cpu: 68.4 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: 1508 pm: pacman pkgs: 1485 libs: 424 tools: gnome-software,pamac
    pm: flatpak pkgs: 23
    1: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    2: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 360
  1: cpu: 22.4% command: firefox pid: 42088 mem: 663.4 MiB (4.1%)
  2: cpu: 15.7% command: localsearch-extractor-3 pid: 44716
    mem: 46.8 MiB (0.2%)
  3: cpu: 8.4% command: firefox pid: 5519 mem: 1211.8 MiB (7.6%)
  4: cpu: 8.3% command: gnome-shell pid: 3305 mem: 472.9 MiB (2.9%)
  5: cpu: 4.5% command: htop pid: 34871 mem: 8.90 MiB (0.0%)
  Memory top: 5 of 360
  1: mem: 1211.8 MiB (7.6%) command: firefox pid: 5519 cpu: 8.4%
  2: mem: 736.8 MiB (4.6%) command: thunderbird pid: 21739 cpu: 0.7%
  3: mem: 663.4 MiB (4.1%) command: firefox pid: 42088 cpu: 22.4%
  4: mem: 483.3 MiB (3.0%) command: nicotine started-by: python pid: 23378
    cpu: 2.0%
  5: mem: 472.9 MiB (2.9%) command: gnome-shell pid: 3305 cpu: 8.3%
  Processes: 360 Power: uptime: 5h 41m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 6.16 GiB services: gsd-power,
    power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
    tool: systemctl
  Compilers: gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: gnome-terminal
    inxi: 3.3.40
Excuse my spam but it happened again, I don’t know what details I have to provide.
This is journalctl when i pressed the powerbutton till the bootup
Jan 08 23:02:24 gogo-82ju systemd-logind[1050]: Power key pressed short.
Jan 08 23:02:24 gogo-82ju systemd-logind[1050]: The system will power off now!
Jan 08 23:02:24 gogo-82ju systemd-logind[1050]: System is powering down.
Jan 08 23:02:25 gogo-82ju systemd[1]: Stopping Power Profiles daemon...
Jan 08 23:02:25 gogo-82ju systemd[1]: Stopping Daemon for power management...
Jan 08 23:02:25 gogo-82ju systemd[1]: power-profiles-daemon.service: Deactivated successfully.
Jan 08 23:02:25 gogo-82ju systemd[1]: Stopped Power Profiles daemon.
Jan 08 23:02:25 gogo-82ju systemd[1]: Requested transaction contradicts existing jobs: Transaction for sound.target/start is destructive (systemd-poweroff.service has 'start' job q>
Jan 08 23:02:25 gogo-82ju systemd[1]: sys-devices-pci0000:00-0000:00:08.1-0000:06:00.6-sound-card1-controlC1.device: Failed to enqueue SYSTEMD_WANTS job, ignoring: Transaction for >
Jan 08 23:02:25 gogo-82ju systemd[3043]: Stopped target GNOME power management target.
Jan 08 23:02:25 gogo-82ju systemd[1]: upower.service: Deactivated successfully.
Jan 08 23:02:25 gogo-82ju systemd[1]: Stopped Daemon for power management.
Jan 08 23:02:25 gogo-82ju dbus-broker-launch[1043]: Activation request for 'org.freedesktop.UPower' failed.
Jan 08 23:02:28 gogo-82ju systemd[1]: systemd-poweroff.service: Deactivated successfully.
Jan 08 23:02:28 gogo-82ju systemd[1]: Finished System Power Off.
Jan 08 23:02:28 gogo-82ju systemd[1]: Reached target System Power Off.
-- Boot 00714db257294b54b2b34ba993ddf920 --
Jan 08 23:02:52 gogo-82ju kernel: thermal_sys: Registered thermal governor 'power_allocator'
Jan 08 23:02:52 gogo-82ju kernel: ACPI: \_SB_.PCI0.GPP0.PG00: New power resource
Jan 08 23:02:52 gogo-82ju kernel: ACPI: \_SB_.PCI0.GPP4.WL00.WRST: New power resource
Jan 08 23:02:52 gogo-82ju kernel: ACPI: \_SB_.PCI0.GP17.XHC1.RHUB.HSP4.BTPR: New power resource
Jan 08 23:02:52 gogo-82ju kernel: pci 0000:01:00.1: extending delay after power-on from D3hot to 20 msec
Jan 08 23:02:52 gogo-82ju kernel: pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
Jan 08 23:02:52 gogo-82ju kernel: pci 0000:06:00.3: extending delay after power-on from D3hot to 20 msec
Jan 08 23:02:52 gogo-82ju kernel: pci 0000:06:00.4: extending delay after power-on from D3hot to 20 msec
Jan 08 23:02:52 gogo-82ju kernel: input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
Jan 08 23:02:52 gogo-82ju kernel: ACPI: button: Power Button [PWRB]
Jan 08 23:02:52 gogo-82ju kernel: input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
Jan 08 23:02:52 gogo-82ju kernel: ACPI: button: Power Button [PWRF]
Jan 08 23:02:52 gogo-82ju kernel: PM: genpd: Disabling unused power domains
Jan 08 23:02:52 gogo-82ju kernel: usb: port power management may be unreliable
Jan 08 23:02:56 gogo-82ju systemd-logind[1034]: Watching system buttons on /dev/input/event2 (Power Button)
Jan 08 23:02:56 gogo-82ju systemd-logind[1034]: Watching system buttons on /dev/input/event0 (Power Button)
Jan 08 23:02:57 gogo-82ju wpa_supplicant[1111]: wlp4s0: CTRL-EVENT-REGDOM-BEACON-HINT before freq=5180 max_tx_power=2000 no_ir=1
Jan 08 23:02:57 gogo-82ju wpa_supplicant[1111]: wlp4s0: CTRL-EVENT-REGDOM-BEACON-HINT after freq=5180 max_tx_power=2000
Jan 08 23:02:58 gogo-82ju wpa_supplicant[1111]: wlp4s0: CTRL-EVENT-REGDOM-BEACON-HINT before freq=5200 max_tx_power=2000 no_ir=1
Jan 08 23:02:58 gogo-82ju wpa_supplicant[1111]: wlp4s0: CTRL-EVENT-REGDOM-BEACON-HINT after freq=5200 max_tx_power=2000
Jan 08 23:02:59 gogo-82ju systemd[1]: Starting Daemon for power management...
Jan 08 23:02:59 gogo-82ju systemd[1135]: Starting GNOME power management service...
Jan 08 23:02:59 gogo-82ju systemd[1]: Started Daemon for power management.
Jan 08 23:02:59 gogo-82ju systemd[1135]: Started GNOME power management service.
Jan 08 23:02:59 gogo-82ju systemd[1135]: Reached target GNOME power management target.
Jan 08 23:02:59 gogo-82ju systemd[1]: Starting Power Profiles daemon...
Jan 08 23:02:59 gogo-82ju systemd[1]: Started Power Profiles daemon.
Jan 08 23:03:01 gogo-82ju kernel: wlp4s0: Limiting TX power to 30 (30 - 0) dBm as advertised by 84:3c:99:59:a0:58
Jan 08 23:03:06 gogo-82ju systemd[1135]: Stopped target GNOME power management target.
Jan 08 23:03:06 gogo-82ju systemd[1135]: Stopping GNOME power management service...
Jan 08 23:03:06 gogo-82ju systemd[3038]: Starting GNOME power management service...
Jan 08 23:03:06 gogo-82ju systemd[1135]: Stopped GNOME power management service.
Jan 08 23:03:06 gogo-82ju systemd[3038]: Started GNOME power management service.
Jan 08 23:03:06 gogo-82ju systemd[3038]: Reached target GNOME power management target.
