Laptop won't wake up from sleep
Hello, recently i installed a manjaro on my laptop and sleep refuses to work. The laptop goes to sleep like normal but when i try to wake it up only keyboard lights up but no display output and the laptop needs to be hard reset.
inxi output:
  Kernel: 6.12.21-4-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=99365c0c-398b-43c3-bb8a-0683de2f9b09 rw
    resume=UUID=7b6db7fc-cadc-4c6c-ac76-2fd47b00c666 udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.4 tk: Qt v: N/A info: frameworks v: 6.12.0
  Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A15 FA506NCR_FA506NCR
    v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: FA506NCR v: 1.0 serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends LLC. v: FA506NCR.304
    date: 01/08/2025
  ID-1: BAT1 charge: 44.5 Wh (100.0%) condition: 44.5/48.1 Wh (92.6%)
    volts: 12.8 min: 11.7 model: ASUS A32-K55 type: Li-ion serial: N/A
    status: full
  System RAM: total: 16 GiB available: 15.44 GiB used: 3.42 GiB (22.2%)
  Device-1: Channel-A DIMM 0 type: DDR5 detail: synchronous unbuffered
    (unregistered) size: 8 GiB speed: spec: 5600 MT/s actual: 4800 MT/s volts:
    note: check curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
    manufacturer: Samsung part-no: M425R1GB4PB0-CWMOL serial: <filter>
  Device-2: Channel-B DIMM 0 type: DDR5 detail: synchronous unbuffered
    manufacturer: Samsung part-no: M425R1GB4PB0-CWMOD serial: <filter>
  Info: model: AMD Ryzen 7 7435HS bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x44 (68) stepping: 1 microcode: 0xA404107
    desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1095 min/max: 400/4553 boost: enabled scaling:
    driver: amd-pstate-epp governor: performance cores: 1: 1095 2: 1095 3: 1095
    4: 1095 5: 1095 6: 1095 7: 1095 8: 1095 9: 1095 10: 1095 11: 1095 12: 1095
    13: 1095 14: 1095 15: 1095 16: 1095 bogomips: 99042
    xsaves xtopology
    affected
  Device-1: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: ASUSTeK
    driver: nvidia v: 570.133.07 alternate: nouveau,nvidia_drm
    non-free: 550-570.xx+ status: current (as of 2025-04; EOL~2026-12-xx)
    arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-2023 pcie:
    gen: 2 speed: 5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
    ports: active: none off: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 01:00.0
    chip-ID: 10de:25a2 class-ID: 0300
  Device-2: Shine-optics USB2.0 HD UVC WebCam driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:2 chip-ID: 3277:0029
  Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
    compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 143 s-size: 341x191mm (13.43x7.52")
    s-diag: 391mm (15.39")
  Monitor-1: eDP-1 mapped: DP-2 note: disabled model: ChiMei InnoLux 0x1521
    built: 2020 res: N/A dpi: 142 gamma: 1.2 chroma: red: x: 0.592 y: 0.349
    green: x: 0.329 y: 0.557 blue: x: 0.153 y: 0.118 white: x: 0.314 y: 0.329
    size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9
    modes: 1920x1080
  API: EGL v: 1.5 hw: drv: nvidia nouveau drv: nvidia platforms: device: 0
    drv: nvidia device: 1 drv: nouveau device: 2 drv: swrast gbm: drv: nvidia
    surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 570.133.07
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3050 Laptop
    GPU/PCIe/SSE2 memory: 3.91 GiB
  API: Vulkan v: 1.4.309 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 3050 Laptop GPU driver: nvidia v: 570.133.07
    device-ID: 10de:25a2 surfaces: xcb,xlib
  Device-1: NVIDIA GA107 High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8
    link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:2291 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
    vendor: ASUSTeK driver: snd_pci_acp6x v: kernel alternate: snd_pci_acp3x,
    snd_rn_pci_acp3x, snd_pci_acp5x, snd_acp_pci, snd_rpl_pci_acp6x,
    snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
    snd_sof_amd_vangogh, snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
    vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.12.21-4-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
    vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: Realtek RTL8852BE PCIe 802.11ax Wireless Network
    vendor: AzureWave driver: rtw89_8852be v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:b852
    class-ID: 0280
  Device-1: IMC Networks Bluetooth Radio driver: btusb v: 0.8 type: USB
    rev: 1.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:2 chip-ID: 13d3:3571
  Local Storage: total: 476.94 GiB used: 200 GiB (41.9%)
    model: MZVL8512HELU-00BTW size: 476.94 GiB block-size: physical: 512 B
    fw-rev: KXJ72W1Q temp: 34.9 C scheme: GPT
  ID-1: / raw-size: 456.64 GiB size: 448.41 GiB (98.20%) used: 200 GiB (44.6%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 99365c0c-398b-43c3-bb8a-0683de2f9b09
    used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 311E-D2BB
  ID-1: swap-1 type: partition size: 20 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
    uuid: 7b6db7fc-cadc-4c6c-ac76-2fd47b00c666
  Device-1: 1-4:2 info: Shine-optics USB2.0 HD UVC WebCam type: video
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 3277:0029 class-ID: 0e02
    serial: <filter>
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 3 rev: 2.0
  Device-1: 3-3:2 info: IMC Networks Bluetooth Radio type: bluetooth
    driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 13d3:3571 class-ID: e001 serial: <filter>
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-6: 6-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
  Hub-7: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-8: 8-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-9: 9-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Device-1: 9-1:2 info: MOSART Semi. 2.4G RF Keyboard & Mouse
    type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    chip-ID: 3938:1032 class-ID: 0301
  Hub-10: 10-0:1 info: super-speed hub ports: 1 rev: 3.1
  System Temperatures: cpu: 43.6 C mobo: 35.2 C gpu: nvidia temp: 36 C
  Fan Speeds (rpm): cpu: 2600
  Packages: 1345 pm: pacman pkgs: 1328 libs: 380 tools: pamac pm: flatpak
    pkgs: 17
    1: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    2: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    3: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    4: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    5: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    6: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    7: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    8: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 364
  1: cpu: 4.1% command: opera pid: 1407 mem: 477.4 MiB (3.0%)
  2: cpu: 3.1% command: Xorg pid: 827 mem: 81.8 MiB (0.5%)
  3: cpu: 2.8% command: opera pid: 1739 mem: 350.9 MiB (2.2%)
  4: cpu: 2.3% command: konsole pid: 2126 mem: 180.0 MiB (1.1%)
  5: cpu: 2.2% command: opera pid: 1469 mem: 252.0 MiB (1.5%)
  Memory top: 5 of 364
  1: mem: 868.1 MiB (5.4%) command: pamac-manager pid: 2423 cpu: 1.8%
  2: mem: 477.4 MiB (3.0%) command: opera pid: 1407 cpu: 4.1%
  3: mem: 439.3 MiB (2.7%) command: plasmashell pid: 1084 cpu: 1.0%
  4: mem: 350.9 MiB (2.2%) command: opera pid: 1739 cpu: 2.8%
  5: mem: 302.5 MiB (1.9%) command: opera pid: 2066 cpu: 1.3%
  Processes: 364 Power: uptime: 6m states: freeze,mem,disk suspend: s2idle
    image: 6.15 GiB services: org_kde_powerdevil, power-profiles-daemon,
    upowerd Init: systemd v: 257 default: graphical tool: systemctl
  Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.37
    running-in: konsole inxi: 3.3.38
hi
have you connected a network drive via sshfs? sometimes i have the same effect when i have another system connected.
No I haven’t connected any network drives with sshfs, the laptop wouldn’t wake up right after a fresh new install so I doubt its anything I installed.
try switching to Wayland for now.
it’s a wide spread issue currently with waking from sleep being kind of broken.
Switching to Wayland unfortunately did not change anything.
have you found a solution for this in the meantime?
i had the error again today and that without having connected a drive with sshfs. so far i have always blamed the error on it.
the only thing i noticed was that i had a doublecommander open (qt6 application). i haven’t had it open for a while. can you possibly establish a connection between an application (possibly even qt) and the error?
