I very recently installed a new SSD on my laptop to add storage. I cloned the old SSD onto the new one (clonezilla with a live USB), and formatted everything on the old one. Everything on my system works fine, but my computer won’t shut down from the GUI.
sudo shutdown now
works fine, however when shutting down from the GUI I continue to see the mouse and a black screen, and it never (5+ minutes) shuts down. In that state I am able to switch to TTY and enter commands.
I found this post and tried adding the options, but the issue persists. IDK if the output from update grub is helpful.
$ sudo update-grub
Found linux image: /boot/vmlinuz-6.11-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.11-x86_64.img
Found initrd fallback image: /boot/initramfs-6.11-x86_64-fallback.img
Found linux image: /boot/vmlinuz-6.11-rt-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.11-rt-x86_64.img
Found initrd fallback image: /boot/initramfs-6.11-rt-x86_64-fallback.img
Found linux image: /boot/vmlinuz-6.6-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.6-x86_64.img
Found initrd fallback image: /boot/initramfs-6.6-x86_64-fallback.img
Found linux image: /boot/vmlinuz-6.6-rt-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.6-rt-x86_64.img
Found initrd fallback image: /boot/initramfs-6.6-rt-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.15-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.15-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
Root filesystem isn't btrfs
If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
/usr/bin/grub-probe: warning: unknown device type nvme1n1.
done
$ inxi-Fazy
Kernel: 6.11.0-6-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.11-x86_64
root=UUID=2dc1aead-efcd-4b0a-9cab-d13b0c8c0d48 rw quiet
resume=UUID=55a4bfc8-2bef-4478-be36-a0e9946e9f1d udev.log_priority=3
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.5.0
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming F15 FX506HEB_FX566HEB
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: FX506HEB v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: FX506HEB.310
date: 11/25/2021
ID-1: BAT1 charge: 72.6 Wh (84.8%) condition: 85.6/90.2 Wh (94.8%)
volts: 16.5 min: 15.9 model: ASUS A32-K55 type: Li-ion serial: N/A
status: not charging
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard
status: discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: discharging
Info: model: 11th Gen Intel Core i5-11400H bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8D (141) stepping: 1
microcode: 0x52
Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
smt: enabled cache: L1: 480 KiB desc: d-6x48 KiB; i-6x32 KiB L2: 7.5 MiB
desc: 6x1.2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 2400 min/max: 800/4500 scaling: driver: intel_pstate
governor: powersave cores: 1: 2400 2: 2400 3: 2400 4: 2400 5: 2400 6: 2400
7: 2400 8: 2400 9: 2400 10: 2400 11: 2400 12: 2400 bogomips: 64536
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: ASUSTeK driver: i915
v: kernel alternate: xe arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 0000:00:02.0
chip-ID: 8086:9a68 class-ID: 0300
Device-2: NVIDIA GA107M [GeForce RTX 3050 Ti Mobile] vendor: ASUSTeK
driver: nvidia v: 550.120 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 bus-ID: 0000:01:00.0
chip-ID: 10de:25a0 class-ID: 0300
Device-3: Sonix USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:4 chip-ID: 322e:202c
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.88x11.22")
s-diag: 1052mm (41.43")
Monitor-1: DP-1-0.2 pos: right res: 1920x1080 hz: 60 dpi: 102
size: 480x270mm (18.9x10.63") diag: 551mm (21.68") modes: N/A
Monitor-2: eDP-1 pos: primary,left res: 1920x1080 hz: 144 dpi: 142
size: 344x194mm (13.54x7.64") diag: 395mm (15.55") modes: N/A
drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: iris
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.2.2-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (TGL GT1)
device-ID: 8086:9a68 memory: 7.5 GiB unified: yes
API: Vulkan v: 1.3.295 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3050 Ti Laptop GPU driver: nvidia v: 550.120
device-ID: 10de:25a0 surfaces: xcb,xlib
Device-1: Intel Tiger Lake-H HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:43c8 class-ID: 0403
Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 0000:01:00.1 chip-ID: 10de:2291 class-ID: 0403
Device-3: Logitech G435 Wireless Gaming Headset
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-4.2:6 chip-ID: 046d:0acb class-ID: 0300
serial: <filter>
API: ALSA v: k6.11.0-6-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.3 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-3: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
Device-1: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
v: kernel bus-ID: 0000:02:00.0 chip-ID: 8086:2725 class-ID: 0280
Device-2: Realtek vendor: ASUSTeK driver: r8169 v: kernel port: 3000
bus-ID: 0000:03:00.0 chip-ID: 10ec:8162 class-ID: 0200
Device-3: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-4.1:3
chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp0s20f0u4u1 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-14:5 chip-ID: 8087:0032
class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.3
lmp-v: 12 status: discoverable: no pairing: no class-ID: 6c010c
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 1.38 TiB used: 197.76 GiB (14.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFM512GD3JX013N
lanes: 4 tech: SSD serial: <filter> fw-rev: 41000C20 temp: 40.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Crucial model: CT1000P3PSSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR413 temp: 54.9 C
scheme: GPT
ID-1: / raw-size: 195.79 GiB size: 192.16 GiB (98.14%)
used: 32.48 GiB (16.9%) fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:4
ID-2: /boot/efi raw-size: 513 MiB size: 512 MiB (99.80%)
used: 300 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:3
ID-3: /home raw-size: 720.58 GiB size: 708.2 GiB (98.28%)
used: 138.52 GiB (19.6%) fs: ext4 dev: /dev/nvme1n1p4 maj-min: 259:6
ID-1: swap-1 type: partition size: 14.65 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:5
System Temperatures: cpu: 46.0 C mobo: N/A
Fan Speeds (rpm): cpu: 3200
Memory: total: 16 GiB note: est. available: 15.36 GiB used: 3.69 GiB (24.0%)
Processes: 301 Power: uptime: 10m states: freeze,mem,disk suspend: s2idle
avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend,
test_resume image: 6.12 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Packages: 1723 pm: pacman pkgs: 1718 libs: 426 tools: pamac pm: flatpak
pkgs: 5 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.32 running-in: konsole inxi: 3.3.36
Could you please help me figure this out? Thanks!
