Laptop will not wake from suspend
I just got a new laptop and so far the ony issue I’m having is that it won’t wake up from sleep. I’ve included a journalctl log which shows that it appears to enter suspend successfully, but nothing after that. I do not get any response from the system when trying to wake it from sleep - keys and power button do not seem to do anything. I have to hard power down to recover.
One thing I’ve noticed is that it’s trying to use the s2idle mode, which I believe is the only mode the kernel is reporting to support (/sys/power/mem_sleep). This is a brand new laptop, so I would expect it to support the deep/modern mode. However, there are no suspend/sleep related options in BIOS that I can see.
My specific model isn’t listed in the Ideapad section of the Arch wiki, and it doesn’t appear that similar models have known issues.
I tried switching to the testing branch but the behavior is the same.
Any help tracking this down would be appreciated!
inxi:
  Kernel: 6.12.62-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=c78bf19f-3266-421e-84fe-d40733069f69 rw rootflags=subvol=@
    quiet splash resume=UUID=38480ab9-0c42-4a82-a207-4569cc7127f2
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.5.4 tk: Qt v: N/A info: frameworks v: 6.20.0
  Type: Convertible System: LENOVO product: 83KT v: IdeaPad 5 2-in-1 14AKP10
    serial: <superuser required> Chassis: type: 31 v: IdeaPad 5 2-in-1 14AKP10
  Mobo: LENOVO model: LNVNB161216 v: SDK0T76574WIN
    serial: <superuser required> part-nu: LENOVO_MT_83KT_BU_idea_FM_IdeaPad 5
    2-in-1 14AKP10 uuid: <superuser required> Firmware: UEFI vendor: LENOVO
    v: R4CN14WW date: 07/16/2025
  ID-1: BAT0 charge: 55.4 Wh (95.1%) condition: 58.2/57 Wh (102.2%)
    power: 3.4 W volts: 12.78 min: 11.31 model: SMP L23M3PE1 type: Li-poly
    serial: <filter> charging: status: discharging cycles: N/A
  System RAM: total: 16 GiB available: 14.79 GiB used: 2.99 GiB (20.2%)
  Array-1: capacity: 16 GiB slots: 4 modules: 4 EC: None
    max-module-size: 4 GiB note: est.
  Device-1: Channel-A DIMM 0 type: LPDDR5 detail: synchronous unbuffered
    (unregistered) size: 4 GiB speed: 7500 MT/s volts: curr: 0.5 min: 0.5
    max: 0.5 width (bits): data: 32 total: 32 manufacturer: Samsung
    part-no: K3KL8L80DM-MGCU serial: N/A
  Device-2: Channel-B DIMM 0 type: LPDDR5 detail: synchronous unbuffered
  Device-3: Channel-C DIMM 0 type: LPDDR5 detail: synchronous unbuffered
  Device-4: Channel-D DIMM 0 type: LPDDR5 detail: synchronous unbuffered
  Info: model: AMD Ryzen AI 7 350 w/ Radeon 860M bits: 64 type: MT MCP
    arch: Zen 5 gen: 5 level: v4 note: check built: 2024+ process: TSMC n4 (4nm)
    family: 0x1A (26) model-id: 0x60 (96) stepping: 0 microcode: 0xB60000E
    smt: enabled cache: L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 8 MiB
    desc: 8x1024 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 623 min/max: 599/4310 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 623 2: 623 3: 623
    4: 623 5: 623 6: 623 7: 623 8: 623 9: 623 10: 623 11: 623 12: 623 13: 623
    14: 623 15: 623 16: 623 bogomips: 63904
    apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
    avx512dq avx512f avx512ifma avx512vbmi avx512vl avx_vnni bmi1 bmi2 bpext
    bus_lock_detect cat_l3 cdp_l3 clflush clflushopt clwb clzero cmov
    cmp_legacy constant_tsc cpb cppc cpuid cqm cqm_llc cqm_mbm_local
    cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms
    extapic extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr
    fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf
    lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe
    movdir64b movdiri msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke
    osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
    perfctr_llc perfctr_nb perfmon_v2 pfthreshold pge pku pni popcnt pse
    pse36 rapl rdpid rdpru rdrand rdt_a rdtscp rep_good sep sha_ni skinit
    smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm
    svm_lock syscall tce topoext tsc tsc_adjust tsc_scale umip user_shstk
    v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vnmi
    vpclmulqdq wbnoinvd wdt x2avic xgetbv1 xsave xsavec xsaveerptr xsaveopt
    xsaves xtopology
  Type: spec_rstack_overflow mitigation: IBPB on VMEXIT only
    conditional; STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Type: vmscape mitigation: IBPB on VMEXIT
  Device-1: Advanced Micro Devices [AMD/ATI] Krackan [Radeon 840M / 860M
    Graphics] vendor: Lenovo driver: amdgpu v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1, DP-2, DP-3,
    DP-4, DP-5, DP-6, DP-7, HDMI-A-1, Writeback-1 bus-ID: 04:00.0
    chip-ID: 1002:1114 class-ID: 0380 temp: 26.0 C
  Device-2: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2 chip-ID: 04f2:b829
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: 0
  Monitor-1: eDP-1 model: ChiMei InnoLux N140JCA-ELP built: 2024 res:
    mode: 1920x1200 hz: 60 scale: 100% (1) dpi: 162 gamma: 1.2 chroma: red:
    x: 0.592 y: 0.349 green: x: 0.329 y: 0.557 blue: x: 0.153 y: 0.118 white:
    x: 0.314 y: 0.329 size: 301x188mm (11.85x7.4") diag: 355mm (14")
    ratio: 16:10 modes: 1920x1200, 1920x1080, 1600x1200, 1680x1050,
    1280x1024, 1440x900, 1280x800, 1280x720, 1024x768, 800x600, 640x480
  EDID-Warnings: 1: parse_edid: unknown tag 112
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.3.1-arch1.2
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon 860M Graphics (radeonsi
    gfx1152 LLVM 21.1.6 DRM 3.61 6.12.62-1-MANJARO) device-ID: 1002:1114
    memory: 500 MiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.328 layers: 6 device: 0 type: integrated-gpu name: AMD
    Radeon 860M Graphics (RADV GFX1152) driver: mesa radv v: 25.3.1-arch1.2
    device-ID: 1002:1114 surfaces: N/A
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
    bus-ID: 04:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Audio Coprocessor vendor: Lenovo
    driver: snd_acp_pci v: kernel alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
    snd_pci_acp5x, snd_pci_acp6x, snd_rpl_pci_acp6x, snd_pci_ps,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
    snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4 speed: 16 GT/s lanes: 16
    bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio vendor: Lenovo
    bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.12.62-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8922AE 802.11be PCIe Wireless Network Adapter
    vendor: Lenovo driver: rtw89_8922ae v: kernel pcie: gen: 2 speed: 5 GT/s
    lanes: 1 port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8922 class-ID: 0280
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-5:2 chip-ID: 0bda:d922
  Local Storage: total: 953.87 GiB used: 15.29 GiB (1.6%)
    model: MZAL81T0HFLB-00BL2 size: 953.87 GiB block-size: physical: 512 B
    fw-rev: 4L1QKXF7 temp: 25.9 C scheme: GPT
  ID-1: / raw-size: 944.77 GiB size: 944.77 GiB (100.00%)
    used: 15.28 GiB (1.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: c78bf19f-3266-421e-84fe-d40733069f69
    used: 9.6 MiB (3.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 6FD9-257A
  ID-3: /home raw-size: 944.77 GiB size: 944.77 GiB (100.00%)
  ID-4: /var/cache raw-size: 944.77 GiB size: 944.77 GiB (100.00%)
  ID-5: /var/log raw-size: 944.77 GiB size: 944.77 GiB (100.00%)
    dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
    uuid: 38480ab9-0c42-4a82-a207-4569cc7127f2
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Device-1: 1-1:2 info: Chicony Integrated Camera type: video
    driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 04f2:b829 class-ID: fe01
    serial: <filter>
  Hub-2: 2-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 5 rev: 2.0
  Device-1: 3-5:2 info: Realtek Bluetooth Radio type: bluetooth
    driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 0bda:d922 class-ID: e001 serial: <filter>
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-6: 6-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-7: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-8: 8-0:1 info: super-speed hub ports: 1 rev: 3.1
  System Temperatures: cpu: 29.2 C mobo: N/A gpu: amdgpu temp: 26.0 C
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1179 libs: 333 tools: pamac
    1: https://nocix.mm.fcix.net/manjaro/testing/$repo/$arch
    2: https://coresite.mm.fcix.net/manjaro/testing/$repo/$arch
    3: https://ohioix.mm.fcix.net/manjaro/testing/$repo/$arch
    4: https://mirror.telepoint.bg/manjaro/testing/$repo/$arch
    5: https://mirrors.dotsrc.org/manjaro/testing/$repo/$arch
Processes:
  CPU top: 5 of 340
  1: cpu: 7.3% command: firefox pid: 3854 mem: 720.4 MiB (4.7%)
  2: cpu: 4.1% command: firefox pid: 4569 mem: 347.8 MiB (2.2%)
  3: cpu: 3.5% command: kwin_wayland pid: 974 mem: 324.5 MiB (2.1%)
  4: cpu: 1.2% command: firefox pid: 4219 mem: 427.9 MiB (2.8%)
  5: cpu: 0.8% command: firefox pid: 4332 mem: 437.8 MiB (2.8%)
  Memory top: 5 of 340
  1: mem: 720.4 MiB (4.7%) command: firefox pid: 3854 cpu: 7.3%
  2: mem: 471.1 MiB (3.1%) command: plasmashell pid: 1216 cpu: 0.1%
  3: mem: 437.8 MiB (2.8%) command: firefox pid: 4332 cpu: 0.8%
  4: mem: 427.9 MiB (2.8%) command: firefox pid: 4219 cpu: 1.2%
  5: mem: 347.8 MiB (2.2%) command: firefox pid: 4569 cpu: 4.1%
  Processes: 340 Power: uptime: 35m states: freeze,mem,disk suspend: s2idle
    image: 5.89 GiB services: org_kde_powerdevil, power-profiles-daemon,
    upowerd Init: systemd v: 258 default: graphical tool: systemctl
  Compilers: N/A Shell: Bash v: 5.3.8 running-in: konsole inxi: 3.3.40
journalctl:
Dec 14 12:27:04 laptop systemd[1]: Starting Cleanup of Temporary Directories...
Dec 14 12:27:04 laptop systemd[1]: systemd-tmpfiles-clean.service: Deactivated successfully.
Dec 14 12:27:04 laptop systemd[1]: Finished Cleanup of Temporary Directories.
Dec 14 12:30:48 laptop systemd[1]: Created slice Slice /system/dbus-:1.2-org.kde.powerdevil.wakeupsourcehelper.
Dec 14 12:30:48 laptop systemd[1]: Started dbus-:1.2-org.kde.powerdevil.wakeupsourcehelper@0.service.
Dec 14 12:30:48 laptop systemd-logind[680]: The system will suspend now!
Dec 14 12:30:48 laptop systemd[1]: Starting Network Manager Script Dispatcher Service...
Dec 14 12:30:49 laptop systemd[1]: Reached target Sleep.
Dec 14 12:30:49 laptop systemd[1]: Starting System Suspend...
Dec 14 12:30:49 laptop systemd[1]: user@1000.service: Unit now frozen-by-parent.
Dec 14 12:30:49 laptop systemd[1]: session-2.scope: Unit now frozen-by-parent.
Dec 14 12:30:49 laptop systemd[1]: user.slice: Unit now frozen.
Dec 14 12:30:49 laptop systemd[1]: user-1000.slice: Unit now frozen-by-parent.
Dec 14 12:30:49 laptop systemd-sleep[2062]: Successfully froze unit 'user.slice'.
Dec 14 12:30:49 laptop systemd-sleep[2062]: Performing sleep operation 'suspend'...
Dec 14 12:30:49 laptop kernel: PM: suspend entry (s2idle)
Dec 14 12:30:49 laptop kernel: Filesystems sync: 0.004 seconds
Dec 14 12:30:52 laptop kernel: Freezing user space processes
Dec 14 12:30:52 laptop kernel: Freezing user space processes completed (elapsed 0.001 seconds)
Dec 14 12:30:52 laptop kernel: OOM killer disabled.
Dec 14 12:30:52 laptop kernel: Freezing remaining freezable tasks
Dec 14 12:30:52 laptop kernel: Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
Dec 14 12:30:52 laptop kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Dec 14 12:30:52 laptop kernel: [drm] Register(0) [regVPEC_QUEUE_RESET_REQ] failed to reach value 0x00000000 != 0x00000001n
Dec 14 12:30:52 laptop kernel: amdgpu 0000:04:00.0: amdgpu: VPE queue reset failed
Dec 14 12:30:52 laptop bluetoothd[677]: Endpoint unregistered: sender=:1.30 path=/MediaEndpoint/A2DPSource/ldac
Dec 14 12:30:52 laptop kernel: PM: Some devices failed to suspend, or early wake event detected
Dec 14 12:30:52 laptop bluetoothd[677]: Endpoint unregistered: sender=:1.30 path=/MediaEndpoint/A2DPSink/aptx_hd
Dec 14 12:30:52 laptop kernel: [drm] PCIE GART of 512M enabled (table at 0x0000008000900000).
Dec 14 12:30:52 laptop bluetoothd[677]: Endpoint unregistered: sender=:1.30 path=/MediaEndpoint/A2DPSource/aptx_hd
Dec 14 12:30:52 laptop kernel: amdgpu 0000:04:00.0: amdgpu: SMU is resuming...
Dec 14 12:30:52 laptop kernel: amdgpu 0000:04:00.0: amdgpu: SMU is resumed successfully!
Dec 14 12:30:52 laptop kernel: nvme nvme0: D3 entry latency set to 10 seconds
Dec 14 12:30:52 laptop bluetoothd[677]: Endpoint unregistered: sender=:1.30 path=/MediaEndpoint/A2DPSink/aac
Dec 14 12:30:52 laptop kernel: nvme nvme0: 16/0/0 default/read/poll queues
Dec 14 12:30:52 laptop bluetoothd[677]: Endpoint unregistered: sender=:1.30 path=/MediaEndpoint/A2DPSource/aac
Dec 14 12:30:52 laptop kernel: usb 3-5: reset full-speed USB device number 2 using xhci_hcd
Dec 14 12:30:52 laptop bluetoothd[677]: Endpoint unregistered: sender=:1.30 path=/MediaEndpoint/A2DPSink/opus_g
Dec 14 12:30:52 laptop kernel: amdgpu 0000:04:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
Dec 14 12:30:52 laptop bluetoothd[677]: Endpoint unregistered: sender=:1.30 path=/MediaEndpoint/A2DPSource/opus_g
Dec 14 12:30:52 laptop dbus-broker[674]: A security policy denied :1.3 to send method call /midi/profile:org.bluez.GattProfile1.Release to :1.31.
Dec 14 12:30:52 laptop kernel: amdgpu 0000:04:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
Dec 14 12:30:52 laptop bluetoothd[677]: Endpoint unregistered: sender=:1.30 path=/MediaEndpoint/A2DPSink/sbc
Dec 14 12:30:52 laptop systemd[1]: Starting Load/Save RF Kill Switch Status...
Dec 14 12:30:52 laptop kernel: amdgpu 0000:04:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
Dec 14 12:30:52 laptop bluetoothd[677]: Endpoint unregistered: sender=:1.30 path=/MediaEndpoint/A2DPSource/sbc
Dec 14 12:30:52 laptop kernel: amdgpu 0000:04:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 6 on hub 0
Dec 14 12:30:52 laptop bluetoothd[677]: Endpoint unregistered: sender=:1.30 path=/MediaEndpoint/A2DPSource/aptx_ll_1
Dec 14 12:30:52 laptop kernel: amdgpu 0000:04:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 7 on hub 0
Dec 14 12:30:52 laptop bluetoothd[677]: Endpoint unregistered: sender=:1.30 path=/MediaEndpoint/A2DPSource/aptx_ll_0
Dec 14 12:30:52 laptop kernel: amdgpu 0000:04:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 8 on hub 0
Dec 14 12:30:52 laptop bluetoothd[677]: Endpoint unregistered: sender=:1.30 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
Dec 14 12:30:52 laptop kernel: amdgpu 0000:04:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 9 on hub 0
Dec 14 12:30:52 laptop bluetoothd[677]: Endpoint unregistered: sender=:1.30 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
Dec 14 12:30:52 laptop kernel: amdgpu 0000:04:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 10 on hub 0
Dec 14 12:30:52 laptop bluetoothd[677]: Endpoint unregistered: sender=:1.30 path=/MediaEndpoint/A2DPSource/faststream
Dec 14 12:30:52 laptop kernel: amdgpu 0000:04:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 11 on hub 0
Dec 14 12:30:52 laptop bluetoothd[677]: Endpoint unregistered: sender=:1.30 path=/MediaEndpoint/A2DPSource/faststream_duplex
Dec 14 12:30:52 laptop kernel: amdgpu 0000:04:00.0: amdgpu: ring sdma0 uses VM inv eng 12 on hub 0
Dec 14 12:30:52 laptop bluetoothd[677]: Endpoint unregistered: sender=:1.30 path=/MediaEndpoint/A2DPSink/opus_05
Dec 14 12:30:52 laptop kernel: amdgpu 0000:04:00.0: amdgpu: ring vcn_unified_0 uses VM inv eng 0 on hub 8
Dec 14 12:30:52 laptop bluetoothd[677]: Endpoint unregistered: sender=:1.30 path=/MediaEndpoint/A2DPSource/opus_05
Dec 14 12:30:52 laptop kernel: amdgpu 0000:04:00.0: amdgpu: ring jpeg_dec_0 uses VM inv eng 1 on hub 8
Dec 14 12:30:52 laptop bluetoothd[677]: Endpoint unregistered: sender=:1.30 path=/MediaEndpoint/A2DPSink/opus_05_duplex
Dec 14 12:30:52 laptop kernel: amdgpu 0000:04:00.0: amdgpu: ring mes_kiq_3.1.0 uses VM inv eng 13 on hub 0
Dec 14 12:30:52 laptop bluetoothd[677]: Endpoint unregistered: sender=:1.30 path=/MediaEndpoint/A2DPSource/opus_05_duplex
Dec 14 12:30:52 laptop kernel: amdgpu 0000:04:00.0: amdgpu: ring vpe uses VM inv eng 4 on hub 8
Dec 14 12:30:52 laptop bluetoothd[677]: Battery Provider Manager destroyed
Dec 14 12:30:52 laptop kernel: amdgpu 0000:04:00.0: [drm:amdgpu_ib_ring_tests [amdgpu]] *ERROR* IB test failed on vpe (-110).
Dec 14 12:30:52 laptop kernel: [drm:process_one_work] *ERROR* ib ring test failed (-110).
Dec 14 12:30:52 laptop kernel: [drm] ring gfx_32786.1.1 was added
Dec 14 12:30:52 laptop kernel: [drm] ring compute_32786.2.2 was added
Dec 14 12:30:52 laptop kernel: [drm] ring sdma_32786.3.3 was added
Dec 14 12:30:52 laptop kernel: [drm] ring gfx_32786.1.1 ib test pass
Dec 14 12:30:52 laptop kernel: [drm] ring compute_32786.2.2 ib test pass
Dec 14 12:30:52 laptop kernel: [drm] ring sdma_32786.3.3 ib test pass
Dec 14 12:30:52 laptop kernel: OOM killer enabled.
Dec 14 12:30:52 laptop kernel: Restarting tasks ... done.
Dec 14 12:30:52 laptop kernel: random: crng reseeded on system resumption
Dec 14 12:30:52 laptop kernel: Bluetooth: hci0: RTL: examining hci_ver=0c hci_rev=000a lmp_ver=0c lmp_subver=8922
Dec 14 12:30:52 laptop kernel: Bluetooth: hci0: RTL: rom_version status=0 version=1
Dec 14 12:30:52 laptop systemd[1]: Stopped target Bluetooth Support.
Dec 14 12:30:52 laptop kernel: Bluetooth: hci0: RTL: btrtl_initialize: key id 0
Dec 14 12:30:52 laptop kernel: Bluetooth: hci0: RTL: loading rtl_bt/rtl8922au_fw.bin
Dec 14 12:30:52 laptop kernel: Bluetooth: hci0: RTL: loading rtl_bt/rtl8922au_config.bin
Dec 14 12:30:52 laptop kernel: Bluetooth: hci0: RTL: cfg_sz 6, total sz 71307
Dec 14 12:30:52 laptop systemd[1]: Reached target Bluetooth Support.
Dec 14 12:30:52 laptop systemd[1]: Started Load/Save RF Kill Switch Status.
Dec 14 12:30:52 laptop kernel: PM: suspend exit
Dec 14 12:30:52 laptop kernel: PM: suspend entry (s2idle)
This does not look very promising.
So I’m assuming this issue is isolated to the kernel itself? If so, might I have better luck posting on the kernel forums?
It could be related to Plasma. There have recently been some fixes for suspend-related issues, but they may not be in this particular update yet, given that Plasma development moves at a rapid pace, with bugfix releases coming out in rapid succession.
Ah ok. I will install the Gnome version and see if it behaves any differently.
That would be quite the culture shock if you’re used to Plasma, and a high price to pay for wanting the suspend functionality to work, but it’s your computer. :wink: :man_shrugging:
Lol, I’ve used both, but I certainly prefer Plasma. I’m mainly curious to see if the issue really has to do with Plasma. My hope is that I can switch back once the issue has been resolved.
And suspend is working fine with GNOME, good call. I’ll check in over at the Plasma forums and share any updates here.
A short update, in case anyone is interested. This appears to ultimately be a kernel bug, and there are a couple workarounds identified for now. Here are links to the Plasma forums and bugtracker if you want more details.
I am running same plasma version a ThinkPad x14 gen4 AMD using Linux 6.18.
It suspends just fine. I can select suspend in the Plasma Application Launcher from the Power/Session menu - it goes into suspend immediately.
s2idle is the modern mode, my x13 can go a very long time using this suspend.
Yeah one thing I discovered was that entering suspend from the application menu worked fine, but suspend from the sleep timer or closing the lid would hang the system. Others have reported the same behavior in the bug discussion thread.
This does indeed seem to be a KDE issue, in which case, all that can be done is to wait for them to fix it. Monitor the reported issue(s) found and hopefully a resolution will be forthcoming.
You may try entering your bios and check for /config/power/sleep state
there you may select Windows and Linux (s2idle) or since your cpu is quite new install 6.18 kernel
