My laptop will not boot when it is on battery. It begins to boot, shows some bootup text, then shuts off. It boots fine when plugged with a cord. It also boots fine on the battery when booting into Windows, and can run for about 4 hours before needing a charge. Any suggestions would be appreciated.
Kernel: 5.10.61-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=9ce0d192-74cb-480c-a301-5218e56ae9d2 rw apparmor=1
security=apparmor resume=UUID=5b9fd5b9-6a63-41d5-977e-336d40f2ebaf
udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
Type: Laptop System: Micro-Star product: GF65 Thin 9SD v: REV:1.0
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Micro-Star model: MS-16W1 v: REV:1.0 serial: <filter>
UEFI: American Megatrends v: E16W1IMS.108 date: 12/04/2019
ID-1: BAT1 charge: 48.7 Wh (100.0%) condition: 48.7/51.3 Wh (94.9%)
volts: 12.8 min: 11.4 model: MSI Corp. MS-16W1 type: Li-ion serial: N/A
status: Full
RAM: total: 31.2 GiB used: 4.38 GiB (14.0%)
Info: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
microcode: EA cache: L2: 12 MiB bogomips: 62431
Speed: 1220 MHz min/max: 800/1800 MHz Core speeds (MHz): 1: 1220 2: 1133
3: 1778 4: 1504 5: 1396 6: 1160 7: 1132 8: 1253 9: 1355 10: 1597 11: 1109
12: 1152
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Micro-Star MSI
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: Micro-Star MSI
driver: nvidia v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:2191 class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,nv,vesa
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 121 s-size: 404x227mm (15.9x8.9")
s-diag: 463mm (18.2")
Monitor-1: eDP-1 res: 1920x1080 hz: 120 dpi: 142 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.2.1
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Sound Server-1: ALSA v: k5.10.61-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.34 running: yes
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
port: 6000 bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
vendor: Micro-Star MSI driver: r8169 v: kernel port: 3000 bus-ID: 04:00.0
IF: enp4s0 state: down mac: <filter>
IF-ID-1: wgpia0 state: unknown speed: N/A duplex: N/A mac: N/A
IP v4: <filter> scope: global
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:3 chip-ID: 8087:0aaa class-ID: e001
Report: hciconfig ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 3.0
lmp-v: 5.1 sub-v: 100 hci-v: 5.1 rev: 100
Info: acl-mtu: 1021:4 sco-mtu: 96:6 link-policy: rswitch sniff
link-mode: slave accept
service-classes: rendering, capturing, object transfer, audio, telephony
Local Storage: total: 953.88 GiB used: 295.75 GiB (31.0%)
ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Samsung model: MZVLV512HCJH-000L2
lanes: 4 type: SSD serial: <filter> rev: 5L0QBXV7 temp: 42.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital
model: PC SN530 SDBPNPZ-512G-1032 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 21101000 temp: 45.9 C scheme: GPT
ID-1: / raw-size: 127.8 GiB size: 125.3 GiB (98.04%)
used: 107.79 GiB (86.0%) fs: ext4 dev: /dev/nvme1n1p4 maj-min: 259:4
label: N/A uuid: 9ce0d192-74cb-480c-a301-5218e56ae9d2
ID-2: /boot/efi raw-size: 501 MiB size: 500 MiB (99.80%)
used: 26.1 MiB (5.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1 label: N/A
uuid: 9146-CB96
ID-3: /home raw-size: 316.65 GiB size: 310.67 GiB (98.11%)
used: 109.34 GiB (35.2%) fs: ext4 dev: /dev/nvme1n1p3 maj-min: 259:3
label: N/A uuid: 301dc4d2-0455-4799-ae01-db9895f819f7
ID-4: /home/<filter>/d_drive raw-size: 176.24 GiB size: 176.24 GiB (100.00%)
used: 78.6 GiB (44.6%) fs: ntfs dev: /dev/nvme0n1p3 maj-min: 259:8
label: d_drive uuid: 43FBFFD71AD3FC68
ID-1: swap-1 type: partition size: 32 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme1n1p2 maj-min: 259:2 label: N/A
uuid: 5b9fd5b9-6a63-41d5-977e-336d40f2ebaf
ID-1: /dev/nvme0n1p1 maj-min: 259:6 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p2 maj-min: 259:7 size: 300.03 GiB fs: ntfs label: c_drive
uuid: B6AA1017AA0FD2B3
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Device-1: 1-4:2 info: Microsoft Nano Transceiver 1.1
type: Keyboard,HID,Mouse driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 045e:07fd class-ID: 0301
Device-2: 1-14:3 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 69.0 C mobo: N/A
Processes: 354 Uptime: 14m wakeups: 1 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 2185 pacman: 2134 lib: 466
flatpak: 36 snap: 15 Shell: Bash v: 5.1.8 running-in: xfce4-terminal
inxi: 3.3.06
