Laptop webcam not found
My problem is that my webcam is not found, e.g., I open a chatting webpage, where the webcam can be activated, my webcam is not found. Also, if I open the software Cheese, no camera is detected. My laptop has a webcam and it less than 2 months old. Thus, the webcam should work - I hope so.
inxi -Fazy
  Kernel: 6.1.25-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=63b2f8c5-f2f0-4bef-ac7d-dd3cb1e8a805 rw quiet splash apparmor=1
    security=apparmor resume=UUID=cdf4758c-33a8-42e1-a9f5-1adf0e58fc7c
    udev.log_priority=3
  Desktop: Cinnamon v: 5.6.8 tk: GTK v: 3.24.37 vt: 2 dm: GDM v: 43.0
  Type: Laptop System: Acer product: Aspire A515-57G v: V1.21
    serial: <superuser required>
  Mobo: ADL model: Ganymede_ADU v: V1.21 serial: <superuser required>
    UEFI: Insyde v: 1.21 date: 03/10/2023
  ID-1: BAT1 charge: 18.3 Wh (34.5%) condition: 53.0/53.0 Wh (100.0%)
    volts: 14.4 min: 15.4 model: PANASONIC AP19B5L type: Li-ion serial: <filter>
    status: discharging
  Info: model: 12th Gen Intel Core i5-1235U bits: 64 type: MST AMCP
    arch: Alder Lake level: v3 note: check built: 2021+
    process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 4
    microcode: 0x429
  Topology: cpus: 1x cores: 10 mt: 2 tpc: 2 st: 8 threads: 12 smt: enabled
    cache: L1: 928 KiB desc: d-8x32 KiB, 2x48 KiB; i-2x32 KiB, 8x64 KiB
    L2: 6.5 MiB desc: 2x1.2 MiB, 2x2 MiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 1068 high: 2500 min/max: 400/4400:3300 scaling:
    driver: intel_pstate governor: powersave cores: 1: 720 2: 546 3: 828 4: 686
    5: 900 6: 819 7: 863 8: 2500 9: 764 10: 2500 11: 806 12: 891
    bogomips: 59916
  Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
    filling, PBRSB-eIBRS: SW sequence
  Device-1: Intel Alder Lake-UP3 GT2 [Iris Xe Graphics]
    vendor: Acer Incorporated ALI driver: i915 v: kernel arch: Gen-12.2
    process: Intel 10nm built: 2021-22+ ports: active: eDP-1
    empty: DP-1,DP-2,HDMI-A-1 bus-ID: 0000:00:02.0 chip-ID: 8086:46a8
    class-ID: 0300
  Device-2: Quanta ACER HD User Facing type: USB driver: N/A bus-ID: 3-7:2
    chip-ID: 0408:4033 class-ID: fe01 serial: <filter>
  Display: x11 server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1 driver: X:
    loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
  Monitor-1: eDP-1 model: ChiMei InnoLux 0x15e7 built: 2016 res: 1920x1080
    hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
    ratio: 16:9 modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 23.0.2 renderer: Mesa Intel Graphics (ADL GT2)
    direct-render: Yes
  Device-1: Intel Alder Lake PCH-P High Definition Audio
    vendor: Acer Incorporated ALI driver: sof-audio-pci-intel-tgl
    alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
    chip-ID: 8086:51c8 class-ID: 0401
  API: ALSA v: k6.1.25-1-MANJARO status: kernel-api with: aoss
    type: oss-emulator tools: alsamixer,amixer
  Server-2: PipeWire v: 0.3.70 status: off tools: pw-cli
  Server-3: PulseAudio v: 16.1 status: active tools: pacat,pactl
  Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
    vendor: Lite-On driver: mt7921e v: kernel bus-ID: 0000:2b:00.0
    chip-ID: 14c3:7961 class-ID: 0280
  IF: wlp43s0 state: up mac: <filter>
    vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
    bus-ID: 0000:2c:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp44s0 state: down mac: <filter>
  Device-1: Lite-On Wireless_Device type: USB driver: btusb v: 0.8
    bus-ID: 3-10:4 chip-ID: 04ca:3802 class-ID: e001 serial: <filter>
  Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
    v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
  Local Storage: total: 1.38 TiB used: 104.64 GiB (7.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Micron model: 2450 MTFDKBA512TFK
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 type: SSD serial: <filter> rev: V5MA010 temp: 42.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Crucial model: CT1000P3SSD8
    lanes: 4 type: SSD serial: <filter> rev: P9CR30A temp: 43.9 C
  ID-1: / raw-size: 467.84 GiB size: 459.43 GiB (98.20%)
    used: 104.64 GiB (22.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:3
    used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:2
  ID-1: swap-1 type: partition size: 8.8 GiB used: 1024 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:4
  System Temperatures: cpu: 44.0 C mobo: N/A
  Processes: 308 Uptime: 1h 2m wakeups: 5776 Memory: 15.33 GiB
  used: 6.41 GiB (41.8%) Init: systemd v: 252 default: graphical
  tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
  pkgs: 1463 libs: 329 tools: gnome-software,pamac pm: rpm pkgs: 0 pm: flatpak
  pkgs: 0 Shell: Zsh v: 5.9 running-in: kitty inxi: 3.3.26
ls /dev/video*
zsh: no matches found: /dev/video*
lspci
0000:00:00.0 Host bridge: Intel Corporation Device 4601 (rev 04)
0000:00:02.0 VGA compatible controller: Intel Corporation Alder Lake-UP3 GT2 [Iris Xe Graphics] (rev 0c)
0000:00:04.0 Signal processing controller: Intel Corporation Alder Lake Innovation Platform Framework Processor Participant (rev 04)
0000:00:06.0 System peripheral: Intel Corporation RST VMD Managed Controller
0000:00:06.2 PCI bridge: Intel Corporation 12th Gen Core Processor PCI Express x4 Controller #2 (rev 04)
0000:00:07.0 PCI bridge: Intel Corporation Alder Lake-P Thunderbolt 4 PCI Express Root Port #0 (rev 04)
0000:00:08.0 System peripheral: Intel Corporation 12th Gen Core Processor Gaussian & Neural Accelerator (rev 04)
0000:00:0d.0 USB controller: Intel Corporation Alder Lake-P Thunderbolt 4 USB Controller (rev 04)
0000:00:0d.2 USB controller: Intel Corporation Alder Lake-P Thunderbolt 4 NHI #0 (rev 04)
0000:00:0e.0 RAID bus controller: Intel Corporation Volume Management Device NVMe RAID Controller
0000:00:14.0 USB controller: Intel Corporation Alder Lake PCH USB 3.2 xHCI Host Controller (rev 01)
0000:00:14.2 RAM memory: Intel Corporation Alder Lake PCH Shared SRAM (rev 01)
0000:00:15.0 Serial bus controller: Intel Corporation Alder Lake PCH Serial IO I2C Controller #0 (rev 01)
0000:00:15.1 Serial bus controller: Intel Corporation Alder Lake PCH Serial IO I2C Controller #1 (rev 01)
0000:00:16.0 Communication controller: Intel Corporation Alder Lake PCH HECI Controller (rev 01)
0000:00:17.0 System peripheral: Intel Corporation RST VMD Managed Controller
0000:00:19.0 Serial bus controller: Intel Corporation Alder Lake-P Serial IO I2C Controller #0 (rev 01)
0000:00:19.1 Serial bus controller: Intel Corporation Alder Lake-P Serial IO I2C Controller #1 (rev 01)
0000:00:1d.0 PCI bridge: Intel Corporation Device 51b0 (rev 01)
0000:00:1d.3 PCI bridge: Intel Corporation Device 51b3 (rev 01)
0000:00:1f.0 ISA bridge: Intel Corporation Alder Lake PCH eSPI Controller (rev 01)
0000:00:1f.3 Multimedia audio controller: Intel Corporation Alder Lake PCH-P High Definition Audio Controller (rev 01)
0000:00:1f.4 SMBus: Intel Corporation Alder Lake PCH-P SMBus Host Controller (rev 01)
0000:00:1f.5 Serial bus controller: Intel Corporation Alder Lake-P PCH SPI Controller (rev 01)
0000:2b:00.0 Network controller: MEDIATEK Corp. MT7921 802.11ax PCI Express Wireless Network Adapter
0000:2c:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
10000:e0:06.0 PCI bridge: Intel Corporation 12th Gen Core Processor PCI Express x4 Controller #0 (rev 04)
10000:e0:17.0 SATA controller: Intel Corporation Alder Lake-P SATA AHCI Controller (rev 01)
10000:e0:1c.0 System peripheral: Intel Corporation RST VMD Managed Controller
10000:e0:1c.4 PCI bridge: Intel Corporation Device 51bc (rev 01)
10000:e1:00.0 Non-Volatile memory controller: Micron Technology Inc Device 5411 (rev 01)
10000:e2:00.0 Non-Volatile memory controller: Micron/Crucial Technology P2 NVMe PCIe SSD (rev 01)
Please confirm if the camera worked on windows or any other linux os? My research suggests that this is due to missing driver. There 3 ways to solve this problem. First will be switch to windows if camera is that important for your usage. Second would be to compile a kernel with the driver support yourself as mentioned in the second link or wait for a newer kernel. Try installing kernel linux63 aka version 6.3 and boot into that to see if it works.
I have tried the kernel version 63 - the camera still could not be found. Now, I try to install windows using a virtual machine. The software which I intend to use for that is called boxen. Thank you for your reply, I will keep you updated.
Boxen does not allow me to specify the installation path of widows. Oracle VirtualBox is better, however, windows 11 says, my laptop would not fulfil the minimal requirements. This is not true, since it originally came with windows 11. Anyhow, I do not want to devote too much time to this issue. I just wait for updates.
Thank you for your time and effort. This thread can be closed.
