(i have nothing plugged in)
tlp-stat -c output:
--- TLP 1.5.0 --------------------------------------------
+++ Configured Settings:
defaults.conf L0004: TLP_ENABLE="1"
defaults.conf L0005: TLP_WARN_LEVEL="3"
defaults.conf L0006: TLP_PERSISTENT_DEFAULT="0"
defaults.conf L0007: DISK_IDLE_SECS_ON_AC="0"
defaults.conf L0008: DISK_IDLE_SECS_ON_BAT="2"
defaults.conf L0009: MAX_LOST_WORK_SECS_ON_AC="15"
defaults.conf L0010: MAX_LOST_WORK_SECS_ON_BAT="60"
/etc/tlp.conf L0116: CPU_ENERGY_PERF_POLICY_ON_AC="performance"
defaults.conf L0012: CPU_ENERGY_PERF_POLICY_ON_BAT="balance_power"
defaults.conf L0013: SCHED_POWERSAVE_ON_AC="0"
defaults.conf L0014: SCHED_POWERSAVE_ON_BAT="1"
defaults.conf L0015: NMI_WATCHDOG="0"
defaults.conf L0016: DISK_DEVICES="nvme0n1 sda"
defaults.conf L0017: DISK_APM_LEVEL_ON_AC="254 254"
defaults.conf L0018: DISK_APM_LEVEL_ON_BAT="128 128"
defaults.conf L0019: DISK_APM_CLASS_DENYLIST="usb ieee1394"
defaults.conf L0020: DISK_IOSCHED="keep keep"
defaults.conf L0021: SATA_LINKPWR_ON_AC="med_power_with_dipm max_performance"
defaults.conf L0022: SATA_LINKPWR_ON_BAT="med_power_with_dipm min_power"
defaults.conf L0023: AHCI_RUNTIME_PM_ON_AC="on"
defaults.conf L0024: AHCI_RUNTIME_PM_ON_BAT="auto"
defaults.conf L0025: AHCI_RUNTIME_PM_TIMEOUT="15"
/etc/tlp.conf L0343: PCIE_ASPM_ON_AC="performance"
/etc/tlp.conf L0344: PCIE_ASPM_ON_BAT="powersave"
defaults.conf L0028: RADEON_DPM_PERF_LEVEL_ON_AC="auto"
defaults.conf L0029: RADEON_DPM_PERF_LEVEL_ON_BAT="auto"
defaults.conf L0030: RADEON_POWER_PROFILE_ON_AC="default"
defaults.conf L0031: RADEON_POWER_PROFILE_ON_BAT="default"
defaults.conf L0032: WIFI_PWR_ON_AC="off"
defaults.conf L0033: WIFI_PWR_ON_BAT="on"
defaults.conf L0034: WOL_DISABLE="Y"
defaults.conf L0035: SOUND_POWER_SAVE_ON_AC="1"
/etc/tlp.conf L0330: SOUND_POWER_SAVE_ON_BAT="3"
defaults.conf L0037: SOUND_POWER_SAVE_CONTROLLER="Y"
defaults.conf L0038: BAY_POWEROFF_ON_AC="0"
defaults.conf L0039: BAY_POWEROFF_ON_BAT="0"
defaults.conf L0040: BAY_DEVICE="sr0"
defaults.conf L0041: RUNTIME_PM_ON_AC="on"
defaults.conf L0042: RUNTIME_PM_ON_BAT="auto"
defaults.conf L0043: RUNTIME_PM_DRIVER_DENYLIST="mei_me nouveau radeon"
defaults.conf L0044: USB_AUTOSUSPEND="1"
defaults.conf L0045: USB_EXCLUDE_AUDIO="1"
defaults.conf L0046: USB_EXCLUDE_BTUSB="0"
defaults.conf L0047: USB_EXCLUDE_PHONE="0"
/etc/tlp.conf L0413: USB_EXCLUDE_PRINTER="0"
defaults.conf L0049: USB_EXCLUDE_WWAN="0"
defaults.conf L0050: USB_AUTOSUSPEND_DISABLE_ON_SHUTDOWN="0"
defaults.conf L0051: RESTORE_DEVICE_STATE_ON_STARTUP="0"
defaults.conf L0052: RESTORE_THRESHOLDS_ON_BAT="0"
defaults.conf L0053: NATACPI_ENABLE="1"
defaults.conf L0054: TPACPI_ENABLE="1"
defaults.conf L0055: TPSMAPI_ENABLE="1"
/etc/tlp.conf L0044: TLP_DEFAULT_MODE="BAT"
/etc/tlp.conf L0087: CPU_SCALING_GOVERNOR_ON_AC="performance"
/etc/tlp.conf L0088: CPU_SCALING_GOVERNOR_ON_BAT="powersave"
/etc/tlp.conf L0136: CPU_BOOST_ON_AC="1"
/etc/tlp.conf L0137: CPU_BOOST_ON_BAT="1"
/etc/tlp.conf L0169: PLATFORM_PROFILE_ON_AC="performance"
/etc/tlp.conf L0170: PLATFORM_PROFILE_ON_BAT="balanced"
/etc/tlp.conf L0445: DEVICES_TO_DISABLE_ON_STARTUP="bluetooth nfc wwan"
/etc/tlp.conf L0479: DEVICES_TO_DISABLE_ON_BAT_NOT_IN_USE="bluetooth nfc wwan"
/etc/tlp.conf L0501: START_CHARGE_THRESH_BAT0="80"
/etc/tlp.conf L0502: STOP_CHARGE_THRESH_BAT0="85"
/etc/tlp.conf L0508: START_CHARGE_THRESH_BAT1="80"
/etc/tlp.conf L0509: STOP_CHARGE_THRESH_BAT1="85"
/etc/tlp.conf L0533: DEVICES_TO_DISABLE_ON_WIFI_CONNECT="wwan"
tlp-stat -s output:
+++ System Info
System = LENOVO ThinkPad T480 20L6S1LV2F
BIOS = N24ET67W (1.42 )
OS Release = Manjaro Linux
Kernel = 5.10.93-1-MANJARO #1 SMP PREEMPT Thu Jan 20 09:46:07 UTC 2022 x86_64
/proc/cmdline = BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=cc7be21e-d9d4-4881-841a-b047d2a1253a rw quiet udev.log_priority=3
Init system = systemd
Boot mode = UEFI
+++ TLP Status
State = enabled
RDW state = enabled
Last run = 05:43:03 PM, 1 sec(s) ago
Mode = battery
Power source = battery
+++ System Info
Boot mode = UEFI
+++ TLP Status
State = enabled
RDW state = enabled
Mode = battery
powerstat outpu:
Running for 300.0 seconds (30 samples at 10.0 second intervals).
Power measurements will start in 180 seconds time.
Time User Nice Sys Idle IO Run Ctxt/s IRQ/s Watts
15:38:20 30.1 0.0 11.6 58.0 0.3 2 14415 6975 5.73
15:38:30 12.0 0.0 7.4 80.4 0.2 2 5857 2889 5.77
15:38:40 18.0 0.0 8.5 73.2 0.3 1 8845 3865 6.86
15:38:50 13.9 0.0 8.0 77.9 0.2 1 7499 2699 6.38
15:39:00 21.2 0.0 10.1 68.5 0.2 2 11941 4392 6.36
15:39:10 15.5 0.0 9.1 75.3 0.2 5 8784 4089 6.58
15:39:20 29.7 0.0 12.8 57.3 0.2 12 16403 5143 7.65
15:39:30 30.3 0.0 13.2 56.2 0.3 7 16897 5400 11.67
15:39:40 13.5 0.0 7.4 78.8 0.4 3 6175 2592 11.38
15:39:50 12.5 0.0 7.6 79.7 0.2 4 6214 2448 8.98
15:40:00 10.8 0.0 6.8 82.2 0.1 4 5444 2180 6.53
15:40:10 30.5 0.0 10.6 58.7 0.2 11 13471 4353 8.82
15:40:20 25.7 0.0 10.2 63.8 0.3 5 15403 4514 11.65
15:40:30 35.8 0.0 11.4 52.7 0.2 12 14914 4734 13.48
15:40:40 17.8 0.0 8.5 73.5 0.1 3 8793 3281 14.66
15:40:50 11.3 0.0 6.8 81.7 0.1 3 5623 2313 8.81
15:41:00 13.2 0.0 7.0 79.4 0.3 4 6541 2558 7.57
15:41:10 30.4 0.0 10.6 58.2 0.8 3 17007 5180 10.65
15:41:20 33.6 0.0 11.1 55.1 0.2 2 15164 4605 13.23
15:41:30 31.0 0.0 11.3 57.5 0.2 4 15038 4585 14.35
15:41:40 33.7 0.0 10.7 55.5 0.1 4 14649 4500 15.43
15:41:50 32.5 0.0 10.5 57.0 0.0 2 14277 4460 15.53
15:42:00 23.6 0.0 9.9 66.4 0.2 2 13409 4160 15.46
15:42:10 19.0 0.0 9.2 71.3 0.5 1 9379 3795 14.21
15:42:20 27.0 0.0 9.5 63.3 0.2 1 14850 4633 10.81
15:42:30 22.0 0.0 9.4 68.4 0.2 6 11122 3808 8.87
15:42:40 13.6 0.0 6.9 79.2 0.3 2 6435 2656 7.75
15:42:50 12.5 0.0 6.4 80.8 0.3 1 4959 2117 6.89
15:43:00 13.8 0.0 7.0 78.8 0.3 1 6051 2543 6.60
15:43:10 18.4 0.0 7.7 73.5 0.3 1 6759 2994 6.21
Average 21.8 0.0 9.2 68.7 0.2 3.7 10744.0 3815.3 9.83
GeoMean 20.2 0.0 9.1 68.0 0.2 2.8 9903.9 3640.8 9.29
StdDev 8.2 0.0 1.9 9.9 0.1 3.1 4128.0 1152.2 3.32
Minimum 10.8 0.0 6.4 52.7 0.0 1.0 4958.8 2116.7 5.73
Maximum 35.8 0.0 13.2 82.2 0.8 12.0 17006.6 6974.9 15.53
Summary:
System: 9.83 Watts on average with standard deviation 3.32
And i also have a “powertop --auto-tune” run at startup.
+++ Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
-/sys/devices/pci0000:00/0000:00:1d.0/0000:04:00.0/0000:05:02.0/0000:3c:00.0/usb3
active_duration=860
autosuspend=0
autosuspend_delay_ms=0
connected_duration=9281654
control=auto
level=auto
runtime_active_time=2249
runtime_status=suspended
runtime_suspended_time=9275325
wakeup=disabled
+++ Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
-/sys/devices/pci0000:00/0000:00:1d.0/0000:04:00.0/0000:05:02.0/0000:3c:00.0/usb4
active_duration=960
autosuspend=0
connected_duration=9281787
control=auto
level=auto
runtime_active_time=2351
runtime_suspended_time=9275365
usb3_hardware_lpm_u1=disabled
usb3_hardware_lpm_u2=disabled
wakeup=disabled
+++ Bus 001 Device 007: ID 06cb:009a Synaptics, Inc. Metallica MIS Touch Fingerprint Reader
-/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9
active_duration=2720
autosuspend=2
autosuspend_delay_ms=2000
connected_duration=3571447
control=auto
level=auto
persist=0
runtime_active_time=2456
runtime_suspended_time=3568757
wakeup=disabled
+++ Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
active_duration=37124
autosuspend=0
connected_duration=54747490
control=auto
level=auto
runtime_active_time=44325
runtime_suspended_time=54698199
wakeup=disabled
+++ Bus 001 Device 003: ID 04f2:b604 Chicony Electronics Co., Ltd Integrated Camera (1280x720@30)
-/sys/devices/pci0000:00/0000:00:14.0/usb1/1-8
active_duration=26524
autosuspend=2
connected_duration=54747060
control=auto
level=auto
persist=1
runtime_active_time=26173
runtime_suspended_time=54715664
+++ Bus 002 Device 002: ID 0bda:0316 Realtek Semiconductor Corp. Card Reader
-/sys/devices/pci0000:00/0000:00:14.0/usb2/2-3
active_duration=54712444
autosuspend=2
connected_duration=54747340
control=auto
level=auto
persist=1
runtime_active_time=54742160
runtime_status=active
runtime_suspended_time=0
usb3_hardware_lpm_u1=enabled
usb3_hardware_lpm_u2=enabled
wakeup=disabled
+++ Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
active_duration=54713157
autosuspend=0
connected_duration=54747927
control=auto
level=auto
runtime_active_time=54742875
wakeup=disabled
+++ Kernel Modules
+ e1000e
Parameters:
copybreak = "256"
+ i801_smbus
+ i915
Parameters:
+ intel_pch_thermal
+ iwlwifi
Parameters:
11n_disable = "0"
amsdu_size = "0"
bt_coex_active = "Y"
debug = "0"
disable_11ac = "N"
disable_11ax = "N"
enable_ini = "Y"
fw_restart = "Y"
led_mode = "0"
nvm_file = "(null)"
power_level = "0"
power_save = "N"
remove_when_gone = "N"
swcrypto = "0"
uapsd_disable = "3"
+ mei_me
+ nvme
Parameters:
io_queue_depth = "1024"
max_host_mem_size_mb= "128"
noacpi = "N"
poll_queues = "0"
sgl_threshold = "32768"
use_cmb_sqes = "Y"
write_queues = "0"
+ pcieport
+ proc_thermal
+ serial
+ skl_uncore
+ snd_hda_intel
Parameters:
align_buffer_size = "-1"
bdl_pos_adj = "-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1"
beep_mode = "N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N"
dmic_detect = "Y"
enable_msi = "-1"
enable = "Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y"
id = "(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)"
index = "-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1"
jackpoll_ms = "0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"
model = "(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)"
patch = "(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)"
pm_blacklist = "Y"
position_fix = "-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1"
power_save = "3"
power_save_controller= "Y"
probe_mask = "-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1"
probe_only = "0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"
single_cmd = "-1"
snoop = "-1"
+ thunderbolt
Parameters:
start_icm = "N"
+ xhci_hcd
Parameters:
link_quirk = "0"
quirks = "0"
What can i do with this?
