I’m the Manjaro noob from Mint land.
This is what gets my laptop scrolling worked out in mint / ubuntu distros – xserver-xorg-input-synaptics-hwe-18.04
I can’t find it in the AUR. Any idea where it is hiding?
It’s xf86-input-synaptics in the repos
, but it’s been depreciated in favor of libinput
Warning: xf86-input-synaptics is no longer actively updated. If possible, use libinput.
Can you check if libinput debug-events
shows any “POINTER_AXIS” events when you try to scroll? And post the output of libinput list-devices
This is on an older computer, a Toshiba P855-S5312.
Kernel: Linux 5.8.18-1-MANJARO
event9 POINTER_AXIS +88.479s vert 0.00/0 horiz 1.37/0* (finger)
event9 POINTER_AXIS +88.505s vert 0.00/0 horiz 1.03/0* (finger)
event9 POINTER_AXIS +88.531s vert 0.00/0 horiz 0.11/0* (finger)
event9 POINTER_AXIS +88.638s vert 0.00/0* horiz 0.00/0* (finger)
event9 POINTER_BUTTON +88.638s BTN_LEFT (272) pressed, seat count: 1
sudo libinput list-devices
Device: Power Button
Kernel: /dev/input/event2
Group: 1
Seat: seat0, default
Capabilities: keyboard
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Middle emulation: n/a
Calibration: n/a
Scroll methods: none
Click methods: none
Disable-w-typing: n/a
Accel profiles: n/a
Rotation: n/a
Device: Video Bus
Kernel: /dev/input/event8
Group: 2
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: n/a
Kernel: /dev/input/event0
Group: 3
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: n/a
Device: Lid Switch
Kernel: /dev/input/event1
Group: 4
Capabilities: switch
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: n/a
Device: TOSHIBA Web Camera - HD: TOSHIB
Kernel: /dev/input/event13
Group: 5
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: n/a
Device: AT Translated Set 2 keyboard
Kernel: /dev/input/event3
Group: 6
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: n/a
Device: SynPS/2 Synaptics TouchPad
Kernel: /dev/input/event9
Group: 7
Capabilities: pointer gesture
Tap-to-click: disabled
Tap-and-drag: enabled
Tap drag lock: disabled
Left-handed: disabled
Nat.scrolling: disabled
Middle emulation: disabled
Calibration: n/a
Scroll methods: *two-finger edge
Click methods: *button-areas clickfinger
Disable-w-typing: enabled
Accel profiles: flat *adaptive
Rotation: n/a
Device: Toshiba input device
Kernel: /dev/input/event7
Group: 8
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: n/a
Hm? I have this Toshiba laptop and another Asus that doesn’t play well with libinput. When I installed the xserver-xorg-input-synaptics-hwe-18.04 on one of the other distros on this computer it fixed the scroll problem. It also fixed the scroll problem on my Asus notebook.
If it has been depreciated I’m not sure what do do now?
"This is done via the “xserver-xorg-input-synaptics-hwe-18.04” package. By selecting it, the infamous libinput driver gets stepped over.
This solution was a game changer for the touchpad on my Asus."
Old link but this has been discussed before and if it is still relevant – well that may be a problem for me.
It seems that scrolling is detected. Please post the output of head -n 999 /etc/X11/xorg.conf.d/*
It isn’t that it doesn’t scoll vertically, it is slow and just moves one screen. So if I want to scroll a lot of pages, I have to do it little by little.
Seems that I have nothing for it configed in the X11 ??? I have a keyboard in conf.d and that is all that is in there.
sudo head -n 999 /etc/X11/xorg.conf.d/*.
head: cannot open ‘/etc/X11/xorg.conf.d/*.’ for reading: No such file or directory
You have a stray ‘.’ at the end of the command.
The title seems to indicate that it doesn’t scroll, not that it’s slow.
Which desktop environment are you using? Post the output of inxi -Fazy
as well.
I don’t like using things that won’t get updated but I went to the link below and installed the Xf86-input-synaptics. It works but as the warning says we should use libinput] if possible.
So I am hoping to make that possible.
So although I get smooth scrolling, I lose some other features. The XF86 won’t disable when a regular mouse is attached and it won’t disable while typing.
$ inxi -Fazy
Kernel: 5.8.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=a134f762-8815-4897-a16b-fb8896a0449b rw
Desktop: Cinnamon 4.6.7 tk: GTK 3.24.23 dm: LightDM 1.30.0
Distro: Manjaro Linux
Type: Laptop System: TOSHIBA product: dynabook T652/58GBS v: PT65258GBHBS3
serial: <filter> Chassis: type: 10 v: * serial: <filter>
Mobo: TOSHIBA model: QFKAA v: 1.00 serial: <filter> UEFI: TOSHIBA v: 6.60
date: 12/07/2012
ID-1: BAT1 charge: 40.7 Wh condition: 40.7/48.6 Wh (84%) volts: 12.4/10.8
model: COMPAL PABAS0241231 type: Li-ion serial: <filter> status: Full
Info: Dual Core model: Intel Core i5-3210M bits: 64 type: MT MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
L2 cache: 3072 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19961
Speed: 1197 MHz min/max: 1200/3100 MHz Core speeds (MHz): 1: 1197 2: 1197
3: 1197 4: 1197
Type: l1tf
Type: srbds status: Vulnerable: No microcode
Device-1: Intel 3rd Gen Core processor Graphics vendor: Toshiba driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:0166
Device-2: Chicony TOSHIBA Web Camera - HD type: USB driver: uvcvideo
bus ID: 1-1.4:3 chip ID: 04f2:b307 serial: <filter>
Display: x11 server: X.Org 1.20.9 driver: intel unloaded: modesetting
alternate: fbdev,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: LVDS1 res: 1366x768 hz: 60 dpi: 99 size: 350x190mm (13.8x7.5")
diag: 398mm (15.7")
OpenGL: renderer: llvmpipe (LLVM 11.0.0 256 bits) v: 4.5 Mesa 20.2.3
compat-v: 3.1 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Toshiba
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:1e20
Sound Server: ALSA v: k5.8.18-1-MANJARO
vendor: Toshiba driver: r8169 v: kernel port: 3000 bus ID: 01:00.0
chip ID: 10ec:8168
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Centrino Wireless-N 2200 driver: iwlwifi v: kernel
port: 3000 bus ID: 02:00.0 chip ID: 8086:0890
Local Storage: total: 931.51 GiB used: 10.51 GiB (1.1%)
ID-1: /dev/sda vendor: Seagate model: ST1000LM024 HN-M101MBB
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: 0002 scheme: GPT
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 4060 bus ID: 00:1f.2 chip ID: 8086.282a rev: 04
ID-1: / raw size: 37.90 GiB size: 37.06 GiB (97.77%) used: 8.61 GiB (23.2%)
fs: ext4 dev: /dev/sda8
ID-2: /home raw size: 51.13 GiB size: 50.08 GiB (97.94%)
used: 1.87 GiB (3.7%) fs: ext4 dev: /dev/sda9
ID-1: swap-1 type: partition size: 1.95 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda10
System Temperatures: cpu: 54.0 C mobo: N/A
Processes: 210 Uptime: 8m Memory: 7.66 GiB used: 1.07 GiB (13.9%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1181 lib: 342
flatpak: 0 Shell: Bash v: 5.0.18 running in: gnome-terminal inxi: 3.1.08
" Warning: xf86-input-synaptics is no longer actively updated. If possible, use [libinput]
I guess I reached an unsolvable point. I’ve removed the X86 and went back to the default driver. I just won’t have a fluidly scrolling experience when using a browser. I can handle that much better than a touch pad that won’t shut off when the mouse is plugged in or shut off when typing without an external mouse.
So far this forum has offered me a lot of help as I get accustomed to the world of Manjaro.
Thanks.
