Hi all, recently I realized my laptop wasn’t suspending as expected. One night after I close the lid and expecting it to suspend itself, after I came back from outside the laptop fan is at full throttle, and the laptop is quite hot. I opened the lid and it’s only black screen, and it doesn’t respond to any key press except force shutdown with the power button long-pressed.
I did a test by pressing the “Suspend” from the power menu during a normal session. It goes to black screen and freezes like before. Leaving it there to run will result in fan speed going up as well.
I couldn’t find closely related issue, and I hope to be more cautious on shoving any command I found online to the terminal. Could you advice me on proper steps to troubleshoot this?
Thanks!
Kernel: 5.13.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=0325b5b7-65b5-48a0-b18f-5736752533a5 rw quiet splash apparmor=1
security=apparmor resume=UUID=2bc1cb5e-5be0-4d1a-af6e-e2a0dedc24a9
udev.log_priority=3
Desktop: GNOME 40.4 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
Type: Laptop System: LEVEL 51 product: NP5x_NP7xHH_HJ_HK v: N/A
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LEVEL 51 model: NP5x_NP7xHH_HJ_HK serial: <filter> UEFI: INSYDE
v: 1.07.01TASP3 date: 05/07/2021
ID-1: BAT0 charge: 43.6 Wh (100.0%) condition: 43.6/49.4 Wh (88.3%)
volts: 17.2 min: 15.2 model: Notebook BAT type: Li-ion serial: <filter>
status: Full
RAM: total: 15.41 GiB used: 5.45 GiB (35.4%)
Info: 6-Core model: 11th Gen Intel Core i5-11400H bits: 64 type: MT MCP
arch: Tiger Lake family: 6 model-id: 8D (141) stepping: 1 microcode: 2C
cache: L2: 12 MiB bogomips: 64536
Speed: 3945 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 3945 2: 3194
3: 1978 4: 926 5: 2086 6: 1571 7: 4300 8: 1237 9: 940 10: 4066 11: 3491
12: 2456
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2 avx512_vnni
avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2 cdp_l2 clflush
clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl
dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma
fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp hwp_notify
hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid invpcid_single
lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp rep_good
sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: CLEVO/KAPOK
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:9a68 class-ID: 0300
Device-2: NVIDIA GA107M [GeForce RTX 3050 Ti Mobile] driver: nvidia
v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:25a0 class-ID: 0300
Device-3: Acer BisonCam NB Pro type: USB driver: uvcvideo bus-ID: 3-8:2
chip-ID: 5986:9102 class-ID: 0e02
Display: wayland server: X.org 1.20.13 compositor: gnome-shell driver:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa display-ID: 0
OpenGL: renderer: Mesa Intel UHD Graphics (TGL GT1) v: 4.6 Mesa 21.2.1
direct render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: CLEVO/KAPOK
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:43c8 class-ID: 0403
Sound Server-1: ALSA v: k5.13.15-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.35 running: yes
Device-1: Intel Tiger Lake PCH CNVi WiFi driver: iwlwifi v: kernel
port: 5000 bus-ID: 00:14.3 chip-ID: 8086:43f0 class-ID: 0280
vendor: CLEVO/KAPOK driver: r8169 v: kernel port: 3000 bus-ID: 02:00.0
bus-ID: 3-14:3 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 953.87 GiB used: 163.93 GiB (17.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Lexar model: 1TB SSD
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: V1.3 temp: 41.9 C scheme: GPT
ID-1: / raw-size: 936.61 GiB size: 920.84 GiB (98.32%)
used: 163.93 GiB (17.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 0325b5b7-65b5-48a0-b18f-5736752533a5
label: NO_LABEL uuid: AE77-E049
ID-1: swap-1 type: partition size: 16.95 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: 2bc1cb5e-5be0-4d1a-af6e-e2a0dedc24a9
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Device-1: 3-8:2 info: Acer BisonCam NB Pro type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 5986:9102
class-ID: 0e02
Device-2: 3-14:3 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 20 Gb/s
System Temperatures: cpu: 49.0 C mobo: N/A
Processes: 356 Uptime: 59m wakeups: 3 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1237 pacman: 1231 lib: 302
flatpak: 0 snap: 6 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.06
