Hello everyone,
I wanted to try using Linux as my daily OS (I was using it at work before and seemed to fullfill my needs). So, I started trying various distributions (I have Mint at work), I tried few Ubuntu flavors, Debian and now I am testing Manjaro (seems to work best from all distros I tried). But, I noticed one common issue (might be hardware issue, I hope someone might help me find out) - performance is not consistent depending on power source.
To be precise, I watch youtube videos a lot (I am using Firefox) and I noticed that FHD@60fps stutters, but not always (did not have that issue on Windows). It gets worse when I try to use my computer with no AC power.
But, strange thing is - if I boot my laptop on battery and use it that way - everything is fine. I might connect and disconnect AC - and that will not affect system. But if I try that again (connect and disconnect AC) after a few minutes after boot - it starts to stutter. But, it’s not only the video that stutters - if I try to drag browser window around screen, that stutters too. Connecting AC helps, but microstutters are still noticable. I enabled VAAPI on Firefox but that does not make a difference (altough I see it is using iGPU in intel_gpu_top). When I play video on battery, CPU frequency seems to be locked at about 800-900MHz. On AC it is around 1GHz (I don’t know if it’s proper behaviour).
Basically, that is the behaviour on Manjaro. On previous distros it was way worse - it was stuttering no matter power source. Chromium seems to perform better in that matter, but It also stutters.
Here is output from inxi -Fazy:
Kernel: 6.1.1-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=86303089-0637-43b7-a935-606be0e5aa2c rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Dell product: Inspiron 7577 v: N/A
Mobo: Dell model: 0P9G3M v: A00 serial: <superuser required> UEFI: Dell
v: 1.9.3 date: 12/20/2019
ID-1: BAT0 charge: 31.9 Wh (72.0%) condition: 44.3/56.0 Wh (79.2%)
volts: 16.5 min: 15.2 model: Samsung SDI DELL W7NKD7A type: Li-ion
serial: <filter> status: charging
Device-1: hidpp_battery_0 model: Logitech G305 Lightspeed Wireless Gaming
Mouse serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
Info: model: Intel Core i5-7300HQ bits: 64 type: MCP arch: Kaby Lake
gen: core 7 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 9 microcode: 0xF0
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 900 min/max: 800/3500 scaling: driver: intel_pstate
governor: powersave cores: 1: 900 2: 900 3: 900 4: 900 bogomips: 20004
disabled
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 630 vendor: Dell driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3 bus-ID: 00:02.0
chip-ID: 8086:591b class-ID: 0300
Device-2: NVIDIA GP106M [GeForce GTX 1060 Mobile] vendor: Dell
driver: nvidia v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1c20 class-ID: 0300
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-12:5 chip-ID: 0c45:6718 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.6 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa dri: iris
gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: LG Display 0x053f built: 2016 res: 1920x1080 hz: 60
dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.3.1 renderer: Mesa Intel HD Graphics 630 (KBL
GT2) direct render: Yes
Device-1: Intel CM238 HD Audio vendor: Dell driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3 chip-ID: 8086:a171 class-ID: 0403
Device-2: NVIDIA GP106 High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:10f1
class-ID: 0403
Sound API: ALSA v: k6.1.1-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.63 running: yes
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Dell
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 3b:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp59s0 state: down mac: <filter>
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 3c:00.0 chip-ID: 8086:24fd class-ID: 0280
IF: wlp60s0 state: up mac: <filter>
bus-ID: 1-4:3 chip-ID: 8087:0a2b class-ID: e001
Local Storage: total: 1.86 TiB used: 11.01 GiB (0.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: SX8200PNP
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 42AZS6AC temp: 37.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-22Z10T0
type: HDD rpm: 5400 serial: <filter> rev: 1A01 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Wilk model: N/A
size: 14.45 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: PMAP scheme: MBR
ID-1: / raw-size: 292.97 GiB size: 287.31 GiB (98.07%) used: 10.98 GiB (3.8%)
fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
used: 29.8 MiB (31.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 52.0 C pch: 44.0 C mobo: 44.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 3033
Processes: 215 Uptime: 9m wakeups: 5 Memory: 15.49 GiB used: 3.43 GiB (22.1%)
Init: systemd v: 252 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1144 libs: 317
tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.24
